Dew Shade Removal: FS-78 new
      #3432903 - 11/06/09 01:17 PM
After six happy years of ownership the day has come. My FS-78's heretofore-untouched objective needs a bath. Before tugging on and/or twisting on the dew shade, I figured I would ask here.
How does one remove the dew shade on a Takahashi FS-78?
- Jim
"I do not know what I may appear to the world; but to myself I seem to have been only like a boy playing on the seashore, and diverting myself in now and then finding a smoother pebble or a prettier shell than ordinary, whilst the great ocean of truth lay all undiscovered before me."
- Sir Issac Newton
Theodore Mattas
Reged: 11/12/04
Loc: Thessaloniki, Greece
Re: Dew Shade Removal: FS-78 new [Re: jrbarnett]
      #3433145 - 11/06/09 03:27 PM
You don't!
I faced the same problem with my old FS-102 (the one with non retractable dew shield) when cleaning time came and did the job without removing the dew shield.
I think that if you try to "force" things you will damage the dew shield, so since your model is not the retractable version you do absolutely nothing!
Teo
Takahashi TOA-130S
Zeiss Abbe II ortho set
edif300
Reged: 02/24/07
Loc: Basque Country
Re: Dew Shade Removal: FS-78 new [Re: Theodore Mattas]
      #3433166 - 11/06/09 03:40 PM
You can remove the dew shield by unscrewing it:
unscrewed dew shield
Iņaki
Astroargazkigintza
Erik Bakker
Reged: 08/10/06
Loc: Haren, The Netherlands, Europe
      #3433250 - 11/06/09 04:22 PM
Hi Jim,
When I clean my fluorites, I unscrew the dewcap and then unscrew the lenscell from the tube. Same should work for your FS 78. Afther that, you have a package that iis easy to clean gently and perfectly. No collimation or other isssues afterwards, just extremely clean and transparent optics. Be gentle though, both while unscrewing and while cleaning your optics.
Clear skies,
Erik
Visual astronomer, main instruments:
Fully mounted Questar 7 P-BB
Celestron C 102F f/8.8 fluorite
Vixen FL 70S f/8 fluorite
Celestron C 55F f/8 fluorite
Sets of Zeiss, TeleVue and Brandon eyepieces
Zeiss 7x50 Marine B/GA
Zeiss TM german equatorial
Gitzo 224 with Manfrotto 501 fluid head
Unitron alt-az mount
      #3433601 - 11/06/09 07:28 PM
Thanks Teo.
I know Thessaloniki well. In 1985 I worked one summer on a wheat farm near Thessaloniki. I really loved Greece. I bet Thessaloniki has changed a lot since 1985 though.
- Sir Issac Newton
Re: Dew Shade Removal: FS-78 new [Re: Erik Bakker]
      #3433774 - 11/06/09 09:12 PM
Thanks Erik and Inaki.
Mine is the blue band style like the FS-102 in Inaki's photo.
I'm pretty sure the interior (focuser side) glass surface is clean. I have lots of dew spots and some contaminants on the front facing surface though, so I'll probably leave the cell attached. I was thinking I would lock it down on the teegul mount, and clean the front surface that way.
I haven't decided what I'll use to clean it though.
- Sir Issac Newton
Erik Bakker
Reged: 08/10/06
      #3434262 - 11/07/09 08:29 AM
Hi Jim,
I use pure alcohol (96%, highest grade) (like Opticon, a professional optics firm that makes high-end optics for the major observatoties and created their legendary 10" SCT many years ago). It works very well on the fluorite doublets (even the fluorite element) Just be gentle in applying the alcohol. Check with the Astro-Physics and TeleVue, they have good instructions on cleaning on their sites.
Unscrewing the dewcap is not a matter of brute force, because that will slightly deform the dewcap, making it feel like glued-on. So have someone hold the tube with cell for you, then gently turn the dewcap counterclockwise with 2 hands. Make sure you apply rotational force to the dewcap and don't squeeze the dewcap. The slightest squeezing will lock the dewshield in place. This deformation only lasts while you apply squeezing forces, after that it returns to it's original round shape.
Clear skies,
Erik
Theodore Mattas
Reged: 11/12/04
Re: Dew Shade Removal: FS-78 [Re: jrbarnett]
      #3434426 - 11/07/09 10:49 AM
Use Baader's "Optical Wonder".
Absolutely amazing product..when you finish, the lens will look as if it was never cleaned, as if it is brand new.
Roland Christen at Astro-physics uses this fluid!
Teo
Takahashi TOA-130S
25 registered and 21 anonymous users are browsing this forum.
Moderator:  desertstars, Remy Bosio, Jason B, LLEEGE
