Equipment Discussions >> Classic Telescopes
Pages: 1 | 2 | 3 | (show all)
mikey cee
Reged: 01/18/07
Loc: bellevue ne.
Tasco 20TE's Rebirth
      #3434505 - 11/07/09 11:37 AM Attachment (29 downloads)
The big Tasco "Observatory" model sitting on my garage work bench. Cosmetic surgery awaits......
7x35 and 10x50 sears tower binocs, 3" f/10 edmunds reflector, 2.4" f/11.7 manon refractor, 6" f/8 jaegers refractor, "The 8 Ball" 8" f/13.3 brandt refractor, 3" f/15.8 sans&streiffe refractor, 3.1" f/15 selsi refractor(towa 339), 2.4" f/15 sears refractor, selsi 30x30mm spyglass, criterion 5-draw 25x45x75x spyglass(1957), 4.25" f/14.8 tasco 20te.
mikey cee
Reged: 01/18/07
Loc: bellevue ne.
Re: Tasco 20TE's Rebirth new [Re: mikey cee]
      #3434517 - 11/07/09 11:41 AM Attachment (16 downloads)
First all parts and their relationships are noted and labeled as such.
akman1955
Reged: 09/07/09
Loc: Alaska, USA
      #3434528 - 11/07/09 11:45 AM
That is one impressive telescope mikey! john
mikey cee
Reged: 01/18/07
Loc: bellevue ne.
      #3434539 - 11/07/09 11:50 AM Attachment (16 downloads)
Egg trays from our old Hotpoint refridgerator make excellent temporary parts bins. Every screw, washer, nut and spacer will be removed and individually dipped in naval jelly and power brushed with a Dremel tool by hand. This is a very tedious and time consuming process. The only part not removed from the OTA was the rear mounting bracket from the front sliding tube weight. It's mounting nuts and washers were behind a glare stop that was too far down the tube to reach by hand.
mikey cee
Reged: 01/18/07
Loc: bellevue ne.
      #3434544 - 11/07/09 11:52 AM Attachment (23 downloads)
Immediately after labeling and orientation the lens cell was removed and inspected. Hey I just noticed something....did you?
Edited by mikey cee (11/07/09 02:35 PM)
mikey cee
Reged: 01/18/07
Loc: bellevue ne.
      #3434553 - 11/07/09 11:56 AM Attachment (13 downloads)
Notice how the collimation ring is a seperate entity from the lens cell. After blowing and dusting large tube "debris" from the rear element the lens unit was safely stored away from the work area.
mikey cee
Reged: 01/18/07
Loc: bellevue ne.
      #3434558 - 11/07/09 11:59 AM Attachment (15 downloads)
A view down the tube from the front end. It appears that the glare stop was put into place first then the tube was swabbed with flat black paint.
Jae
Reged: 04/13/06
Loc: near Boston
      #3434560 - 11/07/09 12:00 PM
Mike,
Unbelievable dedication that I believe in and admire.
Jae
mikey cee
Reged: 01/18/07
Loc: bellevue ne.
Re: Tasco 20TE's Rebirth new [Re: Jae]
      #3434665 - 11/07/09 01:01 PM Attachment (11 downloads)
Cradle dings and scrapes are glazed and hand sanded. All prep work and painting was done on the patio for easy spotting of any missed issues.
mikey cee
Reged: 01/18/07
Loc: bellevue ne.
      #3434668 - 11/07/09 01:04 PM Attachment (11 downloads)
Next the CW's are power sanded. All surfaces are primed.
mikey cee
Reged: 01/18/07
Loc: bellevue ne.
      #3434672 - 11/07/09 01:08 PM Attachment (12 downloads)
When sanding the tube you get below that "yellowed" aging. Then I primed pop cans and applied primer and the finish coats. This is as close as I could get!
mikey cee
Reged: 01/18/07
Loc: bellevue ne.
      #3434679 - 11/07/09 01:13 PM Attachment (11 downloads)
Now to the finishing paint. I find those cheap spray can guns the easiest to use. You have more control over short bursts by squeezing than tiring out your index fingers. Here are the finished CW's.
mikey cee
Reged: 01/18/07
Loc: bellevue ne.
      #3434681 - 11/07/09 01:15 PM Attachment (14 downloads)
Next the main tube. Jury rigged to rotate by hand at my discretion.
Chuck Faranda
Reged: 03/31/07
Loc: Florida
      #3434688 - 11/07/09 01:18 PM
Mike,
Great restoration sequence. Can you give detaiuls on the paint you used?
Chuck Faranda
See my vintage scopes at http://ccdastro.com/vintage.html
mikey cee
Reged: 01/18/07
Loc: bellevue ne.
      #3434689 - 11/07/09 01:18 PM Attachment (11 downloads)
The accessory tubes get their just rewards.
mikey cee
Reged: 01/18/07
Loc: bellevue ne.
      #3434701 - 11/07/09 01:28 PM Attachment (14 downloads)
And last but not least the pier. I didn't disturb the "velvet" crinkle finish on the lower black part. I toothbrushed naval jelly onto the chromed bolts. After cleaning and polishing them I placed 5/8" plastic furniture leg tips over each one before I sprayed. Beats the heck out of removing them which is a job or masking them.
mikey cee
Reged: 01/18/07
Loc: bellevue ne.
Re: Tasco 20TE's Rebirth new [Re: Chuck Faranda]
      #3434704 - 11/07/09 01:31 PM
Chuck I used Ace Epoxy Enamel. I find it gives a nice satin finish rather than a gloss finish. Mike
mikey cee
Reged: 01/18/07
Loc: bellevue ne.
      #3435211 - 11/07/09 07:26 PM Attachment (16 downloads)
Shown here are the rechromed items. The large main focus tube of 1/16" thick solid brass.....had to weigh a pound. Next is the drawtube for the 25x50mm guidescope. Then the front and rear tube weight rods. Lastly the threaded CW rod.
mikey cee
Reged: 01/18/07
Loc: bellevue ne.
      #3435218 - 11/07/09 07:32 PM Attachment (14 downloads)
Here we see the finished tailpiece and drawtube assembly installed. I reversed the secondary drawtube and fabricated a new visual back. Then internal glides were installed to accept the Unitron drawtube. Three nylon locking screws then secure the drawtube allowing rotation of the Unihex A.
mikey cee
Reged: 01/18/07
Loc: bellevue ne.
Re: Tasco 20TE's Rebirth [Re: mikey cee]
      #3435222 - 11/07/09 07:36 PM Attachment (10 downloads)
Here is a view of one of the numerous steps that I discussed earlier. All items that needed polished turned out like new.
7 registered and 7 anonymous users are browsing this forum.
Moderator:  RLTYS, Glassthrower, Clive Gibbons
