whduke
Reged: 04/22/08
Loc: Clayton NC
Just thought i would post these images of Mars. Im still very new at the settings for Mars, but I expect the results will get better as the disk gets bigger. Processing is a lot different for Mars. I did have a problem with my computer not letting me shoot at 60Fps, so this was shot at 30Fps, with very low gain.
-------------------- CELESTRON 9.25
Mount EQ-CG5
DMK21AU04
Astronomik LRGB
Orion Filter Wheel
Neximage Camera
Powermate 2.5x
whduke
Reged: 04/22/08
Loc: Clayton NC
And a sneak peak at Saturn.
Mount EQ-CG5
DMK21AU04
Astronomik LRGB
Orion Filter Wheel
Neximage Camera
Powermate 2.5x
Lunatiki
Reged: 08/07/05
Loc: Amarillo, TX
Nice work Mitch. Was that Mars from this morning?
-------------------- Mars Watch
All images taken with:
Celestron CPC 1100
DBK 21AF04.AS
K3ccd/Registax4/PSP8/Maxim DL IP
ALPO Member #4287
whduke
Reged: 04/22/08
Loc: Clayton NC
Yep 4am with a freeze warning!! Very cold!! I still have to figure out the settings, and processing. With the disk so small it really takes some different processing, and image setup as well.
Mount EQ-CG5
DMK21AU04
Astronomik LRGB
Orion Filter Wheel
Neximage Camera
Powermate 2.5x
Lunatiki
Reged: 08/07/05
Loc: Amarillo, TX
If Mikes image was from this morning too, you both shot at about the same CM. Mine was from an hour later. In your image, it looks like you caught some morning limb clouds, but I can't see any at all in Mikes. If Mikes is from this morning, I'll be a bit perplexed.
Celestron CPC 1100
DBK 21AF04.AS
ALPO Member #4287
whduke
Reged: 04/22/08
Loc: Clayton NC
Yep we both shot at the same time, is that clouds? Im going to get a 3x TV barlow for good seeing. This powermate 2.5x is not cutting it.
Mount EQ-CG5
DMK21AU04
Astronomik LRGB
Orion Filter Wheel
Neximage Camera
Powermate 2.5x
Lunatiki
Reged: 08/07/05
Loc: Amarillo, TX
As far as settings, it looks to me like you have them down pretty good. Thats a fine result in every way, including color. I'd just say remember you can shoot a 4 minute avi at this point get get a lot of frames.
Celestron CPC 1100
DBK 21AF04.AS
ALPO Member #4287
Lunatiki
Reged: 08/07/05
Loc: Amarillo, TX
To me, they look like clouds, but I see none whatsoever in Mikes image. They do burn off quick, if they are clouds, which is why I would say I don't see them in my image. I honestly think they are real features, but they should be showing up in Mikes. Can you split the bmp into R G and B and post them?
Celestron CPC 1100
DBK 21AF04.AS
ALPO Member #4287
whduke
Reged: 04/22/08
Loc: Clayton NC
The RGB channels were 2minutes each. The total frames per channel were around 3600, and I stacked about 800 per channel. I will try to post the raws soon.
Mount EQ-CG5
DMK21AU04
Astronomik LRGB
Orion Filter Wheel
Neximage Camera
Powermate 2.5x
whduke
Reged: 04/22/08
Loc: Clayton NC
Red
Mount EQ-CG5
DMK21AU04
Astronomik LRGB
Orion Filter Wheel
Neximage Camera
Powermate 2.5x
whduke
Reged: 04/22/08
Loc: Clayton NC
Green
Mount EQ-CG5
DMK21AU04
Astronomik LRGB
Orion Filter Wheel
Neximage Camera
Powermate 2.5x
whduke
Reged: 04/22/08
Loc: Clayton NC
blue
Mount EQ-CG5
DMK21AU04
Astronomik LRGB
Orion Filter Wheel
Neximage Camera
Powermate 2.5x
Lunatiki
Reged: 08/07/05
Loc: Amarillo, TX
Hard to tell, but it looks like your blue image is showing the the clouds I see in RGB. Can't seem them in the Red, which would be typical of morning limb blue/water ice clouds. I'm no expert, but I think they are water/ice clouds and not artifacts. But Mikes image is of such high quality he should have picked them up too. Perhaps Christophe Pellier will read this thread and chime in.
Celestron CPC 1100
DBK 21AF04.AS
ALPO Member #4287
whduke
Reged: 04/22/08
Loc: Clayton NC
I have 4 caps, and it shows in each image. I only used wavlettes in IRIS fine 2.3, and finest 3.3. I exposed the histogram at around 240 for each channel, is that too high? Im very new to imaging this planet. By the way here is another shot.
Mount EQ-CG5
DMK21AU04
Astronomik LRGB
Orion Filter Wheel
Neximage Camera
Powermate 2.5x
whduke
Reged: 04/22/08
Loc: Clayton NC
and this is the first shot taken at 440am
Mount EQ-CG5
DMK21AU04
Astronomik LRGB
Orion Filter Wheel
Neximage Camera
Powermate 2.5x
whduke
Reged: 04/22/08
Loc: Clayton NC
How about this image no wavlettes, just crisp filter which does not introduce artifacts like the other filters. The so called clouds still show up.
Mount EQ-CG5
DMK21AU04
Astronomik LRGB
Orion Filter Wheel
Neximage Camera
Powermate 2.5x
Mike Phillips
Reged: 02/21/06
Loc: Swift Creek, NC - 35.682 N, 78...
Very nice dude! I think yours is as good or better than mine!
Cold indeed!
-------------------- Gallery/Blog/RSS/Tutorials
Mike's Lesson on Seeing, Collimation and Focusing
**NEW** VIDEO HowTo: Planetary Processing Routine v8 **NEW**
Lunatiki
Reged: 08/07/05
Loc: Amarillo, TX
That last shot doesn't make it look like there are as many clouds as the first one. And the last shot seems to show some typical limb brightening. Maybe there aren't as many clouds there as I though, which would explain why Mike's image didn't pick any up.
Celestron CPC 1100
DBK 21AF04.AS
ALPO Member #4287
whduke
Reged: 04/22/08
Loc: Clayton NC
Mike's image did pickup some of the clouds, but i believe the difference is that mine is a little overexposed. If you look a little bit above the bottom white limb you can see more detailed clouds. I did have the histo right at 250 actually. With the brightness of Mars varying due to its fuzzy appearance, I might need to lower the histo. What would our fellow forum members recommend?
Mount EQ-CG5
DMK21AU04
Astronomik LRGB
Orion Filter Wheel
Neximage Camera
Powermate 2.5x
Lunatiki
Reged: 08/07/05
Loc: Amarillo, TX
Honestly Mitch, I think you are makng the best out of what the seeing you have will alllow. Like my image, I can see how much better the image could be if it weren't for the seeing. Its been poor-average here at best, and being in an El Nino pattern, I'm afraid most of the US will be that way though the winter.
Celestron CPC 1100
DBK 21AF04.AS
ALPO Member #4287
