droid
rocketman
Reged: 08/29/04
Loc: ohio
Just a note I was not trying to make you look foolish, lol.
-------------------- 12 inch Truss Reflector "John"
102mm Celestron C102HD
Tasco 7TE5 60mm Classic
Tasco 9TE5 60mm Classic
Celestron Ultima 2000 SCT
Remains of an 8 inch dob
Celestron Comet catcher(orange tube)
1960 Edscorp Space Conquerer 6inch f/8
10x50 Bushnell Binoculars.
11T 4.5 inch Tasco reflector Lunograsso?
60mm Telescope Club
rwiederrich
Goldfinger
Reged: 11/17/05
Loc: Bremerton Washington
Only I can do that Andy...... I know you weren't..
Many of the issues I have been dealing with have been simply machine issues. I've never made a mirror by machine before....there is a learning curve..I am climbing. it's quite steap at present..but it isn't that high.
One thing is for sure.....once I get it down with your mirror....I'll have it down. Second the Porter machine definately hoggs out mirrors much faster then this machine does. it isn't a problem..really...just gives me time to focus and to make repairs to the Porter permanently.
I've also been giving my 10"f/15 refractor a lot of thought while *hogging* out your mirror. I have finally figured out my machining approach to attaching the tube adapter ring to the tube and making it collimated.
Plus.... old renters are out and we are getting ready for new ones....
Rob
-------------------- www.goldmtobservingcenter.com
A great place for amateur astronomers, and ATM's to come and enjoy their hobby.
http://tech.groups.yahoo.com/group/HomemadeRefractorTelescopes/ My homemade refractor group.
www.vimeo.com/6014031
droid
rocketman
Reged: 08/29/04
Loc: ohio
Might be a blessing in disguise, by hogging slower, maybe your able to avoid over shooting your depth, I dont know just looking for the silver lining
60mm Telescope Club
rwiederrich
Goldfinger
Reged: 11/17/05
Might be.....however...I check the hogging process often..the f/3.8 got that way because I had to rehog it out and in doing so I went deeper then intended.
Still....I'm taking this mirror from infancy to maturity....by way of extreme care and applied experience....gained from past failures.
Its hogging is nearly as smooth as fine grinding...too..since using the new diamond cutter.
Not much more to go.
Rob
droid
rocketman
Reged: 08/29/04
Loc: ohio
Diamond cutter..? like the ones I use to mill aluminum?...or something else entirely?
60mm Telescope Club
rwiederrich
Goldfinger
Reged: 11/17/05
A diamond stone cutting blade. A wet blade for cutting stone/glass/tile/cement.....
Rob
droid
rocketman
Reged: 08/29/04
Loc: ohio
Waiting for the new pitch? As I was reading about all your problems with the pitch I see there is actually a thread on the topic,lol. Dont know as it would help you though.
60mm Telescope Club
rwiederrich
Goldfinger
Reged: 11/17/05
Finished hogging the blank out...now I'm making the new grinding tool.....pouring die stone and epoxying pennies....
Fun stuff.
Soon we will be grinding.
Rob
rwiederrich
Goldfinger
Reged: 11/17/05
I epoxied the pennies on the grinding tool..so tomorrow we can begin fine ginding.
Here is an image of the freshly hogged mirror.....doing it on this machine produced some unique swirly paterns.....cool.
Rob
droid
rocketman
Reged: 08/29/04
Loc: ohio
Spirograph???
60mm Telescope Club
rwiederrich
Goldfinger
Reged: 11/17/05
Spirograph???
After fine grinding.....I think I'm ready to begin polishing.
Rob
rwiederrich
Goldfinger
Reged: 11/17/05
After some more polishing on the fast 13"f/3.8..it tested better...the parabola is looking better and so is the finish.
I built a nifty polishing tool that is set to off set to one side of the stroke...causing the center to push down while not over stroking the outer zones..or the edge. Creating the initial parabola. It's working well...and I'm making great headway.
Here is the latest shadowgram of the f/3.8.
Rob(the guy who doesn't know what he's doing)
droid
rocketman
Reged: 08/29/04
Loc: ohio
interesting photo...what am I looking at???? sorta looks like a donut ring raised with a low center and edge?????
60mm Telescope Club
rwiederrich
Goldfinger
Reged: 11/17/05
A parabaloid shadowgram is indicitive of this type of image. Kinda like a donut. Slower parabaloids such as an f/6~9 would show less of a pronounced central dip or bowl with a zone 7 hill around the mirror.
The shadowgram is taken within the caustic zone of the returning light rays. This is where the KE intersects the returning rays. It appears as if the center (being a shorter radius) is a depression while the marginal zone (which is of a longer radius) appears turned outward..so it looks convexed
Being this mirror is an f/3.8 the shadows between the zones is much more pronounced. This mirror still need further polishing and figuring to soften the zones and bring the center out a bit. This mirror is slightly hyperbolic. In My uneducated view.
Rob(I'm sure the experts will pipe in and correct me)
johnnyha
Reged: 11/12/06
Great job Rob that looks like a dramatic improvement!
-------------------- Johnny
Spicewood, TX
Sherman Oaks, CA
rwiederrich
Goldfinger
Reged: 11/17/05
Thanks Johnny.....
I've worked hard to make it so. I've worked with making modified polishing tools to polish only the needed areas and I combined modified strokes to permit the tool to work only the areas I want to work.
Plus using the appropriate pitch for the temp of the shop is imperative to good contact(this I learned)
Droid's mirror is getting a bit more fine grinding so I can begin to see a slight polishing of the surface from the pennies. This method works well for me and then the polishing will continue with #55 Gugolz premium pitch.
Making mistakes is the best way to learn and grow....and I've made my share. No better way to become experienced....IMV
Again thanks.
Rob
neo
Reged: 02/12/08
Loc: Iasi, Romania
F/3.8?? Man Rob, you have guts no argue about it!  It will be quiet tough to figure such a fast mirror. But I see you're on the right track. In the end this mirror will be killer with a good coma corrector . Can't wait to see its first light !
Alex
-------------------- Russian 15x50 binos
Home made 8" f/5 Newton on eq mount
Home made 70mm f/6 (Rodenstock Rotelar lens) Apo refractor
www.astronomy.ro
GlennLeDrew
Reged: 06/18/08
Loc: Ottawa, Ontario, Canada
Alex, With the right test apparatus, it's not all that more difficult to figure fast aspheres. I make 12" f/2 fused silica primaries for a field-corrected Dall-Kirkham. Polishing to a sphere after 5 micron grinding takes about 2 days, and figuring the asphere (with 10.5 waves of deformation below the 70.7% zone) takes a week or so.
-------------------- Home-made 11X50 right angle bino, 8.1 deg. FOV
Modified 26X100 bino, 3.5 deg. FOV
Home-made Mk II RA bino, using interchangeable objectives and eyepieces
My Gallery
Mediocre minds discuss people. Good minds discuss events. Great minds discuss ideas.
droid
rocketman
Reged: 08/29/04
Loc: ohio
BY HAND ..OR BY MACHINE...?
60mm Telescope Club
GlennLeDrew
Reged: 06/18/08
Aspherizing by hand on a spindle, using all sub-diameter tools of 3" down to 3/4".
My Gallery
