Helix
Vendor (Helix Mfg)
Reged: 07/11/04
Loc: Mars, Pennsylvania
GIRO alignment question new
      #338688 - 02/09/05 05:11 PM
Hi Folks,
When mounting 2 scopes on a GIRO can both scope be aligned exactly on the same object without adjusting the mount ? In other words, I point the right scope at the object, is the left scope connected and aligned exactly at the same point in the sky without adjusting the left scope ?
Tim
msp
Reged: 11/18/04
Loc: Wolverhampton UK
Re: GIRO alignment question new [Re: Helix]
      #338745 - 02/09/05 06:02 PM
Tim,
Generally yes, it depends on magnification. Both can be aligned perfectly in alt by slackening the two allen screws on the arm, and lining up with any distant object.
With my set up of a TV85 and TMB105, I tend to keep a wide field eyepiece in the TV85 (27mm Pan), and high power eyepieces in the TMB. An object central in the TMB will be just off centre in the TV85.
Although I have just stripped and re-greased it, in doing so I removed the stainless steel collar, from the stainless steel arm, and adjusted everything with just the two aluminium arms on, which has reduced the spacing between the scopes, unfortunately due to cloud I have not had chance to try this out .
As I use a dovetail and plate for mounting, I have a theory that I could either introduce an adjuster screw at the back of the collar on the Giro arm to kick the back of the scope out, or simply use a thin packer or shim between the plate and the back scope ring, a small washer should do.
Having said that I find it fairly intuitive to know where the object is from one to the other, but having the 27mm Pan in the TV85 helps
Martyn
TV85
TMB105LW
FS128 'Big Brother'
Helix
Vendor (Helix Mfg)
Reged: 07/11/04
Re: GIRO alignment question new [Re: msp]
      #339894 - 02/10/05 07:32 PM
Thanks for your input !!
Tim
msp
Reged: 11/18/04
      #342535 - 02/13/05 05:56 PM
Tim, that did the trick, keeping both saddle plates an equal distance from the centre axis results in an object central in both eyepieces.
Thanks for asking the question and getting me thinking about it, saves messing about trying to shim or otherwise align the scopes, I shall now kick myself for not thinking of the obvious solution a long time ago
Martyn
TV85
TMB105LW
FS128 'Big Brother'
Oldfield
Reged: 03/20/02
Loc: Hong Kong
      #343977 - 02/15/05 01:32 AM
I've replaced the two screws on the second arm to those with a larger knob, so the alignment is now very easy.
The Home Astronomer from a city where most people are proud of the light pollution
Toys: C5, Ranger, Borg 45ED II, SM40/BF10, Unistar Light, TG-SP II, LXD55, ToUCam Pro, DMK 31AF03, Canon 10x30 IS, Pentax PCF III 10x50...
My observation log and ideas My General Blog
Larry F
Reged: 05/24/04
Loc: Westchester, NY
Re: GIRO alignment question [Re: Oldfield]
      #344154 - 02/15/05 08:45 AM
"Exactly at the same point in the sky". By my calculations, to be "exactly" spot on when sighting Sirius (8.6 ly distant), the two scopes have to be adjusted out of parallel by something on the order of 3e-16 degrees. That's for "exactly". If you want to be sloppy about alignment, that's your choice.
C5 Orange Tube SCT
Orion 127 Mak
SV Nighthawk (1st generation)
CPC 800 XLT SCT
Coronado Maxscope 40
5 1/4" f/5.2 home-built Newtonian
Denk II Binos
Giro 2/Tech2000 Giro Driver/Tech2000 QuickDraw Pier
A zillion eyepieces and some more mounts
Mason & Hamlin BB 214 cm (piano)
My Gallery
14 registered and 19 anonymous users are browsing this forum.
Moderator:  Charlie Hein, FAB
Home
