Mark Harry
Reged: 09/05/05
Loc: Northeast
1/2" thick quartz-where? new
      #3440560 - 11/10/09 04:50 PM
Just a suppose, but if I wanted to make a doublet using quartz, where could I get a piece or two with 1/2" thickness at 4.5-6" diameter?
How is a piece graded for lens use?
Mark
So many projects, so little time!
ed_turco
Reged: 08/29/09
Re: 1/2" thick quartz-where? new [Re: Mark Harry]
      #3442035 - 11/11/09 12:59 PM
Quartz suitable for lens work is called "Dynasil". A piece from one of the outlets is going to cost a pretty penny but you might pick up something from SS. Hope this helps.
mark cowan
Vendor (Obsidian Optics)
Reged: 06/03/05
Loc: salem, OR
      #3442492 - 11/11/09 05:07 PM
Mark,
Chris at RecoLabs has, among many 14.7x.8" fused silica pieces, a small % that pass refractive tests for me...place the quasi plano-plano part in front of a mirror under test on the stand and look at the Ronchi bands. The ones that show Ronchi bands are transmission grade, IMO, and a few of these parts have been sold for lens work (all quartz Schupmans, mostly), but there aren't any reports about utility.
I asked him to sort out a few of these when he has the time, I'm interested in getting them as well. It might work for you. They can be waterjetted to size.
Best,
Mark
Mark Harry
Reged: 09/05/05
Loc: Northeast
Re: 1/2" thick quartz-where? new [Re: mark cowan]
      #3443380 - 11/12/09 06:52 AM
Ed, I wonder if what you're calling "Dynasil" is what we used to call "Excimer"(sp?) I know that stuff would make a lens, but it was very scarce, likely not attainable by some idiot like me experimenting.
Mark, do you put the stuff right up to the mirror? I have 3 pieces from Chris, but they are way off of flat, and somewhat irregular; so wouldn't likely show meaningful bands anyway. ???
M.
kfrederick
Reged: 02/01/08
      #3443419 - 11/12/09 07:41 AM
MARK maybe check with RAY at n------ glass .What you making??
Gregory Rohde
Vendor (Superior Optical Supply)
Reged: 05/02/07
Loc: Portland Oregon
      #3443681 - 11/12/09 10:54 AM
Mark -
I have several pieces that were end cuts from 6.1" and 7.0" cores that are .4 - .75" thick. And ALL of my "N" type quartz is refractive grade.
Bear in mind though that quartz has a low index of refraction. All of the pieces that I have sold in the past for lenses have been pretty thick to account for a steep curve.
Greg
mark cowan
Reged: 06/03/05
Loc: salem, OR
      #3443993 - 11/12/09 01:47 PM
M.
Right, and I've only done this to compare a couple of plano-plano (polished both sides) pieces. The surface on those parts is at least a couple waves, so if I saw wavy but intact lines I consider it good. The stuff with micro-bubbles (shows a laser track) showed a complete mess on transmission.
The reason I didn't mention Greg's material is I haven't personally tested any of it for transmission quality, as I've only had it here unpolished, and for the same reason I can't get a laser into it to check for bubbles. But if he says it's refractive grade I'd take it as true, wouldn't be that hard to test before finishing a piece, anyway.
If the lenses you're talking about are for a Chief I know Ed said the lenses could be fairly thin in quartz, and you could build an all-quartz Chief.
Best,
Mark
Ed Jones
Reged: 04/06/04
Loc: Sin-sin-atti
Re: 1/2" thick quartz-where? [Re: mark cowan]
      #3444382 - 11/12/09 05:47 PM
United Lens Co. has fused quartz but it will be more expensive.
Ed Jones
10 registered and 11 anonymous users are browsing this forum.
