Tim A.
Reged: 09/19/07
Loc: 40 30'N 105 3'W
Big achro vs. mount
      #3471965 - 11/28/09 12:07 AM
I have a CR150-HD, a nice 6" f/8 achromat on a CG5-GT mount. I have to take care to keep my eye off the EP to afford the most stable views. I've been wondering if a longer dovetail bar might make things more rigid. The stock dovetail is 13", and the longest replacement I've seen is the AstroTech 15" dovetail bar.
Would the extra dovetail length make any difference?
-- Tim
Colorado
Tim -- Colorado
  • 12.5" f/5 Dob (Starbucket)
  • Celestron CPC800
  • Celestron CR-150 HD on CG5-GT
  • Galileoscope
  • Oberwerk Deluxe II 20x80 & Ultra 10x50
  • Celestron Regal LX 8x42
  • Bio-binoculars 1x6
    "Me? Crazy? Oh, yeah. Crazy like an ox!"
  • Karl_Bonner_1982
    Reged: 05/13/09
    Loc: Springfield, Oregon (4.5ish ma...
    Re: Big achro vs. mount new [Re: Tim A.]
          #3471980 - 11/28/09 12:16 AM
    The three main factors are tube weight, tube length and distribution of weight. A compact tube with an even weight distribution will be more stable than a long skinny tube that's heavy at both ends.
    I'm beginning to think that my Meade-2 mount is a little weak for the Mak...or maybe the bearings are just a bit loose?
    Current equipment:
    Orion 8x40 fully coated binocs
    Orion 90mm f/10 achro refractor
    Celestron 102mm f/5 rich field refractor
    Eyepieces: 25, 20, 12.5, 10, 7.5 (all plossls), borrowing 40mm Plossl and 2x shorty barlow
    "We're here, we love refractors, get used to it!"
    stevew
    Reged: 03/03/06
    Loc: Vancouver
          #3471986 - 11/28/09 12:22 AM
    -- Tim
    Colorado
    A 2 inch longer dove tail would make no difference.
    Try a bigger mount, or just stronger legs on your CG5 mount.
    Steve
    So long, and thanks for all the fish....
    CHASLX200
    Reged: 09/29/07
    Loc: Tampa area Florida
    Re: Big achro vs. mount new [Re: stevew]
          #3472297 - 11/28/09 09:01 AM
    The CG5 will never be any good for a 6" F8 Achro. You need a bigger mount like the G11.
    Chas
    Luigi
    Reged: 07/03/07
    Loc: MA
    Re: Big achro vs. mount new [Re: CHASLX200]
          #3472426 - 11/28/09 10:34 AM
    A longer dovetail can be counterproductive. The dovetail flexes more than the tube of the telescope and a longer one will flex even more easily. Shortening the distance between the tube rings will help, as will getting a stiffer dovetail. Better yet, do both.
    17.5" f/5 Dob. IM-715 MCT. 120ED. Lunt 60mm Ha.
    Zeiss, Leica, Fujinon, Nikon, Pentax, Bushnell bins
    Phil Cowell
    Reged: 05/24/07
    Loc: Southern Tier NY
          #3472448 - 11/28/09 10:51 AM
    Chas
    A CGEM does the job just as well for a lot less money and zero learning curve, the HC is identical to the CG5.
    If it'll fit on a sig you don't have enough
    Steve Fisher
    "Curmudgeon in Training"
    Reged: 08/12/06
    Loc: Utah
    Re: Big achro vs. mount new [Re: Phil Cowell]
          #3472539 - 11/28/09 11:45 AM Attachment (31 downloads)
    We have looked several times at the possibility of building a Hargreaves strut for my friend Bills C6R that he mounts on an Atlas.
    We have been stopped by the tapered cell that the C6R uses. I had the thought several months ago that a strut could be mounted from the dewshield to the counter weight shaft.
    I'll guarantee that if you can devise a strut it will be more than usable with the CG 5 but a larger mount would be best.
    Steve
    8" f/12 D&G Achromat Refractor Delivered 08/27/09
    6" D&G f/12 Achromat Refractor
    66mm f/6.1 William Optics Petzval
    6" f/8 Celestron Starhopper
    "Never try to teach a pig to sing, It wastes your time and it annoys the pig". (Robert Heinlein)
    Phil Cowell
    Reged: 05/24/07
    Re: Big achro vs. mount new [Re: Steve Fisher]
          #3472562 - 11/28/09 12:08 PM
    Hi Steve,
    I run a C6R on an Atlas and at times on my CGE Pro. Mine has a Losmandy D Dovetail and on the rare occasions I use it on my AS-GT I use the ADM Vixen to Losmandy adapter and it's rigid. Almost like a double thickness Dovetail.
    Bill Cowles
    Reged: 04/16/06
    Loc: Utah
          #3472571 - 11/28/09 12:12 PM Attachment (38 downloads)
    Here is my C6-R on an Atlas with an ADM saddle, plus more weight to the back. The Atlas or CGEM are much better than the CG-5 and the CGE would be even better. Going to the CGE will be double the cost and greater weight to transport and setup.
    Bill
    Lunt LS60TS50DS/B1200/FT (on order)
    TV Gensis/Solarmax 60 filter
    PST DS/Herschel Wedge/C4-R
    C6-R /Atlas Goto/Moonlite CF2
    12" LightBridge/Round Table
    MCHP/8" Orion OTA/Ultima 2000
    10" Discovery /Celestron SE-4
    Bill Cowles
    Reged: 04/16/06
    Loc: Utah
          #3472581 - 11/28/09 12:18 PM Attachment (34 downloads)
    The longer dovetail can help, but it's better to have a longer and better saddle. Here is my new ADM dual saddle compared to the stock Atlas saddle, big difference and more secure and steadier.
    Bill
    Bill Cowles
    Reged: 04/16/06
    Loc: Utah
    Re: Big achro vs. mount new [Re: Bill Cowles]
          #3472586 - 11/28/09 12:21 PM Attachment (33 downloads)
    I have also replaced the stock dovetail with a solid one.
    Bill
    cuzimthedad
    Just Be Cuz
    Reged: 04/09/06
    Loc: Sonoma, Northern California
          #3472587 - 11/28/09 12:22 PM
    Hi Steve,
    I agree with Phil. If you are willing to upgrade to a beefier mount then go with the CGEM. I had the Meade equivalent of yours, the LXD75 AR-6, and did something a bit different. I upgraded the ota with an Antares 1529. It's a shorter tube achro, f/6.5, than the CR150 so the moment arm is more stable allowing a shorter damping time. It is acceptable. However, at some point in time I will probably upgrade to the CGEM.
    Dan
    20" f/5 Obsession
    Antares 1529
    Various Naglers, Ethos, UO Orthos
    Gone but not forgotten: Meade 5K UWAs & Plossls, WO UWANs, TV Plossls & T6 Naglers, Tak LEs, 13 & 17 Ethos, Vixen LVWs, Orion Stratus, Meade 12" LX200R, TV Genesis and TV102, Meade AR6, WO 80SD. All these helped to get me to what I own today.
    The Off Fisher Lane Irregulars
    AV in CMH
    Reged: 11/07/05
    Loc: Columbus Ohio
          #3472625 - 11/28/09 12:42 PM
    Tim,
    For what it is worth, I had a CR6 on a CG5 and I found that if the OTA is very carefully balanced and everything is tight, starting with the Legs to hub connections the setteling time is 1 or 2 at most.
    I replaced the tripod legs with very solid wooden legs and this made the biggest difference of all.
    Good luck, don't give up,
    Anthony
    cuzimthedad
    Just Be Cuz
    Reged: 04/09/06
    Re: Big achro vs. mount new [Re: AV in CMH]
          #3472670 - 11/28/09 01:13 PM
    Another help would be the use of anti vibration pads.
    Dan
    20" f/5 Obsession
    Antares 1529
    Tommy5
    Reged: 03/28/04
    Loc: Chicagoland
    Re: Big achro vs. mount new [Re: cuzimthedad]
          #3473112 - 11/28/09 07:25 PM
    My Cr-150 with the CG-5 and vibration pads is fine for visual as long as there is no wind, the only time the view wobbles is when i touch the focuser to move it, an helical focuser worked wonders for me, a motor focuser is also a great idea to get a decent focus in real time. A larger mount is a nice luxury but i would rather spend the money on a larger/better optical scope, it is usually better to buy a scope and a mount together much cheaper then buying separate.
    John Fitzgerald
    In Focus
    Reged: 01/04/04
    Loc: AR
    Re: Big achro vs. mount new [Re: Tommy5]
          #3473180 - 11/28/09 08:32 PM
    After a year, I sold the CG-5 that came with my CR150 HD and bought an Atlas mount from Orion. IMO it's the perfect match for the OTA for visual observing. That was six years ago and it's still going strong.
    letimotif
    No Complaints
    Reged: 05/20/07
    Loc: No Idea, but I know my speed!
    Re: Big achro vs. mount new [Re: John Fitzgerald]
          #3473217 - 11/28/09 09:06 PM
    Some things that might help:
    1. An Orion Skyview Pro Mount Extension will fit the CG5-GT. That'll let you keep the tripod legs collapsed and the mount a bit more sturdy.
    2. Orion's Electronic Accu-Focuser is an inexpensive add on. It will not eliminate image shift with the stock R&P focuser, but you can velcro the controller to the tripod legs or the mount extension above, and while using it keep your mits off the OTA when you focus. Works great.
    3. Right now, if you go to Highpoint Scientific's ebay site you'll see a CGEM mount on sale for $1,150 (new open box) or $1,199, both with free shipping. These are fine deals on the mount if you can swing the price.
    Ah, but a man's reach should exceed his grasp, or what's a Heaven for?
    Tim A.
    Reged: 09/19/07
    Re: Big achro vs. mount new [Re: letimotif]
          #3473573 - 11/29/09 04:07 AM
    First, thanks to all for the flurry of answers! Never at a loss for words, we CNer's, are we?
    I suppose I should have known there would be calls to put a bigger horse under this caballero. I'd love to. Ain't gonna happen. (Contract work dried up & blew away this year.) In truth, this isn't that bad a problem; I can live with it. (Again, this is a CG-5GT on a steel-tube tripod.)
    But it's good to know that a longer dovetail bar wouldn't help. Now that I think about the mechanics, of course it wouldn't help! At least that's 50 bucks I don't need to throw into the pit! I'd also thought of a longer saddle plate, but I don't think that's an option on this mount.
    2. Orion's Electronic Accu-Focuser is an inexpensive add on. It will not eliminate image shift with the stock R&P focuser, but you can velcro the controller to the tripod legs or the mount extension above, and while using it keep your mitts off the OTA when you focus. Works great.
    Well, I've already taken care of the first two items. The power focuser (it ain't "electronic") makes a huge difference, especially at higher magnifications. The mount extension is good for the reason you mentioned, plus it completely eliminates any chance of collisions with the tripod during slews.
    As for the CGEM, I'd love to, but needs must, you see. Wind, yeah, that can be an issue, but I bet this sail would flap a little even on a CGEM.
    Anyway, when everything is tight and well balanced, it's easy to get good views with this rig. In fact, I used it on Halloween to treat neighborhood ghosties to views of the moon from the driveway.
    -- Tim
    Colorado
    Tim -- Colorado
  • Celestron CPC800
  • Galileoscope
  • Pages: 1
    29 registered and 24 anonymous users are browsing this forum.
    Moderator:  desertstars, Jason B, LLEEGE
