Announcements and News >> Discussion of CN Articles, Reviews, and Reports
Pages: 1 | 2 | 3 | (show all)
Mike LofflandAdministrator
Web Guru (Astronomics)
Reged: 09/03/04
Loc: Norman, Oklahoma
The South Cave Collimator System
      #3506829 - 12/17/09 02:32 PM
nirvanix
Reged: 06/07/07
Loc: Saskatoon, SK
Re: The South Cave Collimator System new [Re: Mike Loffland]
      #3506976 - 12/17/09 03:50 PM
That's very interesting. I'm definitely going to give it a try. Thank you.
Vic Menard
Reged: 07/21/04
Loc: Bradenton, FL
Re: The South Cave Collimator System new [Re: nirvanix]
      #3508319 - 12/18/09 09:43 AM
Wow! I've read the article 3 times now, and I'm still not sure I completely understand it. But I've put together a few notes...
First, the unusual terms, "slewing, elevating, and shunting", are equivalent to skew error, tilt adjustment (confined to the plane defined by the primary mirror axis and the mechanical focuser axis), and offset adjustment (moving the secondary mirror closer to or farther away from the primary mirror only). What I commonly refer to as rotation, tilt, and offset adjustments.
Correcting "error 1" by adjusting secondary mirror rotation to align the pupil and primary mirror center spot with the vertical axis (assuming the focuser is positioned on the top of the OTA) can be a useful signature when secondary mirror adjustment screws 1 and 2 are set equally to minimize skew error (the most common, combined tilt/rotation error). You can use the crosshairs on a good sight tube to accomplish the same adjustment.
Using the center mounting screw to balance adjustments to screw 1 (step 3, correcting vertical or horizontal ovals), is potentially useful to reduce the possibility of creating a skew error (by balancing screw 1 with equal, but opposite, adjustments to screws 2 and 3), but it further impacts the offset adjustment closer to or further from the primary mirror. (Four screw tilt adjustment secondary mirror holders, like the AstroSystems holders, simplify the tilt adjustment.)
I don't quite understand step 4, in particular, the implication (and the meaning) of "splashy" ovals.
Also, assuming an accurately placed center spot, I don't understand why there should be a "displacement along the vertical axis...between the peephole reflection and primary marker...for reflectors shorter than f/6...when full optical alignment has been achieved". Since the alignment of the peephole reflection and the primary marker is essentially equivalent to a Cheshire alignment, the author seems to be advocating "better" secondary mirror alignment over precision primary mirror axial alignment, which, especially at shorter focal ratios, is the most critical alignment of the three Newtonian alignments (primary mirror axis, focuser axis, and secondary mirror alignments, listed in the order of their importance).
The author also notes his difficulties using a Cheshire with an f/4.4 optic, which I suspect could be alleviated with a "calibrated" primary mirror center spot.
Finally, aligning the crosshairs on a translucent front cover in the method described is akin to aligning to the spider vanes (with a carefully centered spider), which can be problematic with the commonly used offset procedures. If, however, the secondary mirror is mechanically offset away from the focuser side of the OTA, the method described could be used to improve coaxial alignment between the primary mirror axis and the OTA axis. While this can be important for precision DSC performance (or for some Newtonian applications with front mounted correctors), it should not be perfected at the expense of the more critical, primary mirror axial alignment.
Starman1
Vendor (EyepiecesEtc.com)
Reged: 06/24/03
Loc: Los Angeles
Re: The South Cave Collimator System new [Re: Vic Menard]
      #3508594 - 12/18/09 12:13 PM
This reminds me of some collimation techniques from the '60s. In those days, and primarily as a long focal-length telescope collimation protocol, you aligned the primary first and the secondary second.
Here's how it was done:
--the secondary mirror was removed, leaving a spider in the tube with a hole in the center. This hole was meticulously centered in the tube. Looking through this tube toward the primary, one centered the eye's pupil in the reflection from the primary and centered the pupil with a dot or ring on the primary. After this, the primary was not touched and all adjustment was done with the secondary.
--the secondary was replaced and a peephole eyepiece was placed in the focuser. The peephole, the peephole reflection, the inside of the peephole eyepiece's reflection, and the primary mirror's reflection were all made concentric. This resulted in having the primary's reflection in the secondary appear offset toward the end of the secondary nearer the primary. Collimation was decent, but edge-of-field illumination was far from even. That uneven illumination would get worse for shorter f/ratio scopes (remember, most scopes of the time were f/8 at shortest, and typically f/10-f/12)
The reason I bring this up is that the template-on-paper routine reminds me of the older collimation. Unless I misunderstand what's going on, it seems this aligns the primary axis to the tube's center axis, and ignores any necessary offset for the secondary (which would have the secondary shadow appear off-center if mechanical offset was built into the secondary holder), which is probably why the author comments that it seems to have poor results at shorter f/ratios--the primary reflection in the secondary would appear dramatically offset from concentricity.
Maybe I'm mis-reading this. I think I'm more confused than Vic.
peter clark
Reged: 09/25/07
      #3532994 - 01/01/10 06:14 AM
For,unto me a new collimator was given,
a gift from God in plastic, hard cheese to those in metal.
So, cracklin' Meade and Celestron Office gid on board before the 60's return leaves you behind at light speed.
Yes, I'll be delighted with a gift of the 1000th collimating front cover off your production line and it doesn't have to be in solid silver!
peter clark
Reged: 09/25/07
      #3532997 - 01/01/10 06:19 AM Attachment (330 downloads)
please see attached
peter clark
Reged: 09/25/07
Re: The South Cave Collimator System new [Re: Starman1]
      #3533003 - 01/01/10 06:31 AM Attachment (262 downloads)
Please see the attachments (2) to be sure.
peter clark
Reged: 09/25/07
      #3533005 - 01/01/10 06:35 AM Attachment (278 downloads)
please see attached + 1 to fo0llow
peter clark
Reged: 09/25/07
      #3533015 - 01/01/10 06:52 AM Attachment (180 downloads)
please see attached table Figure 4. The blank on the 20" line is because of owner's condensation problem. We'll be on a walk Sunday, so now it's only freezing hard I'll try to encourage him to complete collimating.
Vic Menard
Reged: 07/21/04
Loc: Bradenton, FL
Re: The South Cave Collimator System new [Re: peter clark]
      #3538781 - 01/04/10 11:34 AM
Having read your response (why was it an attachment?), I think I now understand what you're attempting to convey and stand by my earlier appraisal. (I still don't understand exactly what you mean by "slew sideways" when describing a secondary mirror alignment step.)
From your commentary, it appears you have access to an older edition of New Perspectives.... I apologize if you found it difficult to understand--the fifth edition is a complete rewrite and is a bit clearer regarding secondary mirror alignment.
Your comment recommending "the 3rd paragraph of Testing Optics, by P.J. Violin", was also a bit confusing. Are you commenting on aligning spherical mirrors or did you mean the 4th (...get the collimation DEAD ON) or 5th (Here's how I collimate a scope. First, I use a steel ball...) paragraph?
Regarding the Cheshire, you noted in your original article, "...at f 4.4 its peephole surround, primary doughnut and cross hairs combine into one large unclear black blob..." and "...difficulty with collimating ‘fast’ ‘scopes had been news to me until the day of the Cheshire..." My comment in response, advocating a calibrated primary mirror center spot, stands. If the cross hairs are problematic, using an actual Cheshire eyepiece instead of a combo tool will resolve that issue. CatsEye Collimation offers calibrated Cheshires and primary mirror center spots that should resolve any other issues (their center spots also work quite well with other commercially available Cheshire derivatives, including combo tools, collimating caps, and Barlowed lasers).
Jim Rosenstock
Reged: 07/14/05
Loc: MD, south of the DC Nebula
      #3539022 - 01/04/10 01:58 PM
Wow...great new strides....
....in making collimation even more incomprehensible!
Listen guys, I have a stash of rare, vintage model "Rosenstock Collimation Wizard Tools", that I'm selling for $25 each, while they last.
Each RCWT (formerly used in the photographic industry to store rolls of an archaic medium, "film") has been precisely center-punched with a peephole that permits trouble-free alignment of your optics in just minutes.
RCWTs are available in three basic colors; black, grey, and white. I'll be producing a small run of "Gold anniversary models", but these will be strictly limited to however long my can of gold spray paint lasts...
Let me know that you read about it on CN, and I'll knock $5 off the price. Except for the Gold anniversary models...everybody pays full price for them!
peter clark
Reged: 09/25/07
      #3541346 - 01/05/10 03:31 PM Attachment (242 downloads)
scrub first attachment
peter clark
Reged: 09/25/07
      #3545786 - 01/07/10 03:15 PM Attachment (256 downloads)
Ball by ball practical version
Vic Menard
Reged: 07/21/04
Loc: Bradenton, FL
      #3550428 - 01/09/10 07:11 PM
I can't open the attachment.
Can somebody else open it and post it in this thread?
peter clark
Reged: 09/25/07
      #3551124 - 01/10/10 05:39 AM
To Saskatoon observer. Best of luck. [4]now reads,'Dusplace the secondary mirror slightly down the tube if [3]........
and is for any required movement to achieve 90 degree reflection optically. n.b. if collimation writers confuse, just pretend you are Isaac Newton doing it for the first time, but with modern materials around you. Peter C.
peter clark
Reged: 09/25/07
Re: The South Cave Collimator System new [Re: Jim Rosenstock]
      #3551360 - 01/10/10 09:39 AM
Hi Jim,
Thanks. My first blog for the popular press begins,'Look through the special pephole at the reflection of its red painted peprimeter, the primary mirror centre douhgnut and the crosshairs of my transluscent CFC invention. If their centres afe displaced to one side, Fig.2, rotate the seconary mirror until there is no displacement, Fig.3. This ends Newtonian secondary mirror collimating difficulties for amateurs at last. With the drawings, the practical have a choice of a good read on, or to roll their sleeves up and get on with it.
The popular editorial preference for this subject matter is naturally first for acceptance by the BAA as a long winded thorough good paper or long letter, edited by them, agreed with me, then published in the Journal of the BAA.
peter c
peter clark
Reged: 09/25/07
      #3551367 - 01/10/10 09:45 AM Attachment (169 downloads)
Sorry about fig.4. I'll try againbetween all the snow clearing we are doing in the UK this year.
peter clark
Reged: 09/25/07
      #3551597 - 01/10/10 11:33 AM Attachment (227 downloads)
vic. please see 2nd attachment to you. Have a good day.
peter clark
Reged: 09/25/07
      #3551613 - 01/10/10 11:41 AM Attachment (208 downloads)
2nd attempt at 2nd reply to you, Vic.
Jason D
Reged: 10/21/06
Loc: California
      #3551734 - 01/10/10 12:35 PM Attachment (143 downloads)
Why can’t you post your thoughts directly into this forum instead of loading them in documents?
I read your article several times. I believe I understand – though I am not 100% sure I do.
Your device is akin to a cheshire. Actually it has the exact functionality. However, instead of adjusting the primary mirror to line up the primary's center spot reflection with the tool’s face reflection (cross-hairs in your case), you adjust the secondary mirror. Basically, the device and methods you have described only aligns the primary mirror axis. They do not align the focuser axis.
Refer to the attachment.
You start off with a misaligned scope (figure A)
You adjust the secondary mirror until the primary mirror's center spot reflection aligns with the tool’s cross-hairs reflection (figure B)
Now if you perform a star test then you are only fine tuning the primary axis alignment which is the same as figure B
Figure C should be your target which aligns both the focuser and primary axes but there is nothing in your description the covers the focuser axial alignment.
Jason
Edited by Jason D (01/10/10 01:23 PM)
0 registered and 3 anonymous users are browsing this forum.
Moderator:  droid, iceblaze
