dweller25
Reged: 08/30/07
Loc: Lancashire, UK
Mars - 3rd January 2010 - PM new
      #3539077 - 01/04/10 02:34 PM Attachment (76 downloads)
Mars drawn at 23:30UT at an altitude of 40 degrees.
Seeing III with moments of IV.
CM = 259'
Takahashi FS128 refractor plus binovewer at x238.
Notes :
Syrtis Major easily seen to the North of the drawing along with Mare Tyrrhenum and Mare Serpentis. Hellas looked quite dim.
A very obvious bright edge to the limb of Mars to the East of the drawing.
The Hyblaeus extension could occasionally be see when the seeing improved.
Utopia and Casius easily seen to the South of the drawing bordering the Polar ice cap.
This is the best view of Mars I have ever had.
Edited by dweller25 (01/06/10 06:18 AM)
Jef De Wit
Reged: 03/06/09
Loc: Hove, Belgium
Re: Mars - 3rd January 2010 - PM new [Re: dweller25]
      #3539101 - 01/04/10 02:49 PM
Another nice Mars-sketch! If the Mars-sketches will continue to be post at this rate at CN... I will know all the main feature of Mars by the end of january
I can't find all the names you mentioned on the ALPO-map of Mars. Which map do you use?
Edited by Jef De Wit (01/04/10 02:50 PM)
Tommy5
Reged: 03/28/04
Loc: Chicagoland
Re: Mars - 3rd January 2010 - PM new [Re: Jef De Wit]
      #3539467 - 01/04/10 06:02 PM
Very good sketch of mars thanks for posting.
Kris.
Reged: 09/16/04
Loc: Belgium
Re: Mars - 3rd January 2010 - PM new [Re: Tommy5]
      #3540324 - 01/05/10 05:18 AM
excellent sketch, you're already capturing more detail with every sketch you make
Aetheria is a good catch, did you note a bright patch just to the left of it?
Are you sure about Nilosyrtis? if so that's great!
dweller25
Reged: 08/30/07
Loc: Lancashire, UK
Re: Mars - 3rd January 2010 - PM new [Re: Kris.]
      #3540338 - 01/05/10 06:06 AM
Hello Kris - thanks. The more I observe the more I see, patience plays a big part.
What map do you use to name the features ? - what is the standard ?
I now have downloaded three maps that do not agree with each other !!!!
Help :-)
Edited by dweller25 (01/05/10 06:16 AM)
sixela
Reged: 12/23/04
Loc: Boechout, Belgium
      #3540386 - 01/05/10 07:34 AM Attachment (60 downloads)
I think what you're calling Nilosyrtis is actually Casius. I caught something which is probably Nilosyrtis on the same night; I just posted the sketch in Kris's "1 jan" thread, but I'll post the coloured sketch here for comparison.
I think Nilosyrtis is the faint whisp between Casius and Syrtis Major.
Sketched at roughly 1u00-1u30 UT (though the position I put Aetheria probably has to have been earlier than that, so it's probably too much to the right, and yours is much more accurately positioned - I also distinctly saw it as a black spot close to the north pole and a very faint extension; by the time I drew the rest it probably faded from visibility close to the limb).
dweller25
Reged: 08/30/07
Loc: Lancashire, UK
Re: Mars - 3rd January 2010 - PM new [Re: sixela]
      #3540472 - 01/05/10 08:55 AM
Kris, Sixela,
Yes I have wrongly labelled Casius as Nilosyrtis.
I need a good map the one I have is misleading.
Jef De Wit
Reged: 03/06/09
Loc: Hove, Belgium
      #3541147 - 01/05/10 02:20 PM
Dweller
Casius is on the map. Nilosyrtis wasn't. I downloaded also the maps that Carlos put in a post some time ago. But they are all small and confusing....
@ Alexis: thanks for the correction.
CarlosEH
Reged: 01/19/05
Loc: Pembroke Pines, Broward County...
      #3541169 - 01/05/10 02:28 PM Attachment (53 downloads)
Dweller,
Another excellent observation of Mars. You have recorded much detail across the martian disk. I have labeled the major albedo features visible. I hope that this proves helpful.
It is very confusing in regards to the nomenclature of Mars. There exists many maps with variations of different regions. I rely upon the map produced by Shiro Ebisawa (Japan) who based his map upon Eugene. M. Antoniadi. The official Martian nomenclature is decided upon by the planetary nomenclature committee of the International Astronomical Union (IAU).
Links;
http://alpo-j.asahikawa-med.ac.jp/Latest/map123.JPG (Ebisawa Mars map)
http://marsprogram.jpl.nasa.gov/MPF/mpf/marswatch/marsnom.html (ALPO Mars map)
Sixela- An excellent observation of Mars. You have also recorded much detail. Thank you for sharing it with us all.
I look forward to your future observations.
Carlos
dweller25
Reged: 08/30/07
Loc: Lancashire, UK
Re: Mars - 3rd January 2010 - PM new [Re: CarlosEH]
      #3541251 - 01/05/10 03:02 PM
Hello Carlos,
Thanks for the feedback and the labelling.
The links for the maps are excellent, I prefer the ALPO version as it is more in line with my scope/eyes ability.
CarlosEH
Reged: 01/19/05
      #3541825 - 01/05/10 07:22 PM
Dweller,
I also like the ALPO map for it's easier readibility and closer appearance to the eye. I am happy to label your excellent observation.
Carlos
Kris.
Reged: 09/16/04
Loc: Belgium
      #3542683 - 01/06/10 05:47 AM
oops, i've been wrong all the time concerning Aetheria & Hyblaeus Extension. this map makes you think the Hyblaeus Extension is Aetheria!
dweller25
Reged: 08/30/07
Loc: Lancashire, UK
Re: Mars - 3rd January 2010 - PM [Re: Kris.]
      #3542690 - 01/06/10 06:13 AM
Kris
oops 2 - I used that same map too and made the same conclusion !!
This is the map I used that called Casius Nilosyrtis ...
http://www.astro.virginia.edu/class/oconnell/astr121/im/BW-mars-map.jpg
I will use the ALPO map Carlos pointed me to from now on.
0 registered and 3 anonymous users are browsing this forum.
Moderator:  cildarith, JayinUT, WOBentley
