Jeff55
Reged: 04/14/05
Loc: Boston MA
Can't Balance CGEM In DEC new
      #3589967 - 01/28/10 05:44 PM
Note my hardware below...my mount easily balances in RA BUT as much as I move the scope back and forth on the mounting rail my C9.25 with Megrez 90 guidescope will not balance in DEC....any suggestions before I tear my hair out.
Reged: 07/06/07
Re: Can't Balance CGEM In DEC new [Re: Jeff55]
      #3589973 - 01/28/10 05:49 PM
Not that unusual. If you can't move the guidescope far enough forward (or back) to balance in dec, you can add some small weights (with Velcro or whatever) where appropriate. Keep in mind that precise dec balance is usually less important than RA balance.
highfnum
Reged: 09/06/06
Loc: NE USA
Re: Can't Balance CGEM In DEC new [Re: rmollise]
      #3590406 - 01/28/10 10:02 PM
thx for posting this - I had same issue
Remi2306
journeyman
Reged: 11/22/06
Re: Can't Balance CGEM In DEC new [Re: highfnum]
      #3629841 - 02/17/10 09:03 AM
I purchased the following from Losmandy. It mounts on the bottom dovetail without having to add a rail. Works like a charm!
DWS $85.00
Dovetail adapter with a 5 inch long threaded stainless steel shaft and 5 lb weight. Mounts to D series dovetail plates, is used for the balancing of a fork mounted telescope. Wt. 6 lbs. total.
Jeff55
Reged: 04/14/05
Loc: Boston MA
Re: Can't Balance CGEM In DEC [Re: Remi2306]
      #3631491 - 02/17/10 10:34 PM
It balances the DEC on my CGEM...without the DDWS it would be impossible.
31 registered and 42 anonymous users are browsing this forum.
