Cotts
Just Wondering
Reged: 10/10/05
Loc: Toronto, Ontario
M809 Mak/Cass on Discmount DM6 new
      #3622260 - 02/13/10 08:51 AM Attachment (81 downloads)
I took delivery of my new DM6 at the Winter Star-Freeze and it worked spectacularly! With just a simple 5-minute balancing it was super-smooth and changing eyepieces was a snap. No more "tighten-clutch - loosen-clutch" stuff for me! The Sky Commander was very accurate: after a two star alignment it put all the objects in the center of the field of a 17 Ethos (120x). Thanks to Tom Peters for such a great product! A photo or two follow.......
Dave
Cotts
Just Wondering
Reged: 10/10/05
Re: M809 Mak/Cass on Discmount DM6 new [Re: Cotts]
      #3622264 - 02/13/10 08:52 AM Attachment (80 downloads)
And.....
Cotts
Just Wondering
Reged: 10/10/05
      #3622266 - 02/13/10 08:53 AM Attachment (83 downloads)
And finally.....
Herenomore
Reged: 11/29/04
      #3623017 - 02/13/10 05:17 PM
Congratulations Dave I liked your "Winter Star-Freeze" comment. The weather has been sort of on-off down here in south Florida the past week...but AFAIK no one has yet had to shovel any snow That said, with temps in the mid-40's tonight, it'll be one of those (rare) occasions when we'll be dealing with cool-down.
Enjoy your new set-up,
lazhow
Reged: 11/11/07
Loc: Boynton Beach,FL
      #3623822 - 02/14/10 09:14 AM
Great shots David;
I was suppose to go to the WSP but I got so disappointed that my M809 had not arrived I felt I did not wish to go.
I been at the party many times and I hope you had several clear nights to try out your new DM 6 which I have found a pleasure to use on my equipment.
I gave up my goto equipment years ago since I found it easier to use and just as effective as you learn to get more out of your Sky Commander DCS.
So enjoy
Howard
jason_milani
Reged: 09/03/04
Loc: Northeast Ohio
Re: M809 Mak/Cass on Discmount DM6 new [Re: lazhow]
      #3631504 - 02/17/10 10:41 PM
Very, very nice setup. Once the Discmount is "dialed in" for tension, it's a breeze to change out eyepieces without worrying about the telescope moving on you.
Good choice!
martym
Reged: 02/15/10
Re: M809 Mak/Cass on Discmount DM6 new [Re: jason_milani]
      #3635365 - 02/19/10 08:06 PM
I think you should drill and tap the opposite side of the block so that you can mount a laptop on a platform then connect the sky commander to it and show real time position on a planatarium program like I do with Guide 8. The laptop weight is opposite the OTA which is good, and the up-down, right-left movements are on screen in AZ mode.
martym
Reged: 02/15/10
Re: M809 Mak/Cass on Discmount DM6 new [Re: martym]
      #3635375 - 02/19/10 08:16 PM
I'm kind of surprised that Mr. Peters hasn't offered something like that already as an accessory. The vertical slot could be used in liew of tapped holes as attachment for an aluminum fabrication or casting.
Ed Kessler
Reged: 05/17/06
Loc: Millersburg, PA
      #3635416 - 02/19/10 08:43 PM
That would actually be a very simple mod. Good idea! You should send this one to Tom.
martym
Reged: 02/15/10
Re: M809 Mak/Cass on Discmount DM6 [Re: Ed Kessler]
      #3635471 - 02/19/10 09:16 PM
Well it works real good because the laptop stays in front of you at eye level and swings with the mount as it is rotated to different parts of the sky. The serial cord from the sky commander to the laptop is less than 2 feet long so no tangled cords. If you have another little support on the back side of the disk mount block like I use for a small lead-acid motorcycle battery it powers the sky commander with 12 volts for heating the display and for fast rotation. Again, no cord wrap.
21 registered and 37 anonymous users are browsing this forum.
