mandotrout
Reged: 01/25/09
Loc: Montana, USA
Photoshop hints? new
      #3636402 - 02/20/10 11:57 AM
Can anybody tell me how, or direct me to an online tutorial, to create a template in PS for my sketches that includes a perfect circle for the sketch and a place for entering text to describe the object, equipment, conditions, etc.: something similar to what I see on so many of the great sketches on this forum. I'm not having any luck figuring it out on my own.
Jeff
BillP
Reged: 11/26/06
Loc: Vienna, VA
Re: Photoshop hints? new [Re: mandotrout]
      #3636445 - 02/20/10 12:22 PM Attachment (47 downloads)
I don't know if there is a tutorial some place, but basically each item is a layer and each layer you manipulate independently. So in my template there is a layer for the sketch, then a back bacground layer, then a black mask layer with a central portion that has a perfectly round hole to view the sketch thru in case it was not perfectly round when I sketched it, and seperate layers for each segment of text, like the header, footer, etc. So you need to have the layers window showing - it's in the pull down menu where the Show Brushes is. They whatever layer is hilighted is what you will be modifying when working. If you want, send me a PM with your email address and I'll send you my Photoshop template so you can use, modify, or experiment with.
Edited by BillP (02/20/10 12:25 PM)
mandotrout
Reged: 01/25/09
Loc: Montana, USA
Re: Photoshop hints? [Re: BillP]
      #3636480 - 02/20/10 12:49 PM
Thanks Bill, that's exactly what I was looking for. I'll send you a PM.
Jeff
1 registered and 2 anonymous users are browsing this forum.
Moderator:  cildarith, JayinUT, WOBentley
