sailor70623
Reged: 01/12/08
Loc: Ok.
iOptron SmartStar GPS new
      #3643568 - 02/23/10 06:49 PM
Has anyone tried this mount? How much weight will it handle? How do you like the set up? I know the tripod it comes with is a bit on the lite side, but figured I'd re-do that. The mount I'm asking about is their CHEAP one. The one that comes in sets, like with an 80mm Achro, or a small 90mm Mak, or a very cheap Newt. I want to know if would handle at least a 102mm ED? Thinking of getting it just because it's so cheap. Might make a good travel scope mount. After putting it on some oak legs.
sailor70623
Reged: 01/12/08
Loc: Ok.
Re: iOptron SmartStar GPS new [Re: sailor70623]
      #3644178 - 02/24/10 12:35 AM
Gee, I thought some-one would have tried this mount.
Lenardo
Reged: 02/19/09
Loc: Ma
      #3653489 - 02/28/10 09:31 PM
works Very well, i have one for a 4.5" reflector and am going to switch it for a mak-possibly a 102mm- might spring for 127 for my kids to use (lower eyepiece placement)
except for a bit of cord wrap potential problems the goto works well, the alignment is fairly easy once you get used to do it, it takes ~5 minutes total to be viewing from setup to viewing
Preston Smith
The Travel Scope Guy
Reged: 04/24/05
Loc: Eureka, Pa
      #3653529 - 02/28/10 09:48 PM
Hi Sailor,
The Basic Cube will not properly support a 102ED scope becuase of the combined effect of the length and weight.
The Cube Pro will but you will need a stronger base than the stock tripod.
Here's how I modified my Cube Pro using a 4" Aluminum tube that you can purchase from Velocity Air:
Modified Cube Pro Base
sailor70623
Reged: 01/12/08
Loc: Ok.
Re: iOptron SmartStar GPS new [Re: Preston Smith]
      #3653731 - 03/01/10 12:41 AM
Guess I'll stay with a simple Alt/Az for my quick look travel scope then. Thanks for the info.
Scruffy
Reged: 01/23/10
Loc: Arkansas
Re: iOptron SmartStar GPS [Re: sailor70623]
      #3656072 - 03/02/10 10:05 AM
Have you looked at the Quarter Hitch or Gyro?
4 registered and 36 anonymous users are browsing this forum.
