Albie
Reged: 02/22/05
Loc: Alberta,Canada
Hello everybody.Can anyone explain exit pupil to me?I know how to figure out the values and have a slight understanding about the way it affects light reception but am not sure how it relates to what I will see through my ep's(what are minimum and maximum values I should avoid and why).I have a 130mm f/7 newtonian.I tried to find that info in Cloudy Nights but only managed to find a bit on exit pupils and binoculars.
-------------------- Skywatcher 10" f/4.7 Dob with Moonlight CR1
Televue 2x barlow and 5T6,7T6,9T6,16T5 and 26T5 Televue Naglers.
SkyMaster 15x70,Regal LX 8x42 and Noble 10x28
ScottAz
Fleet Navigator
Reged: 02/06/05
Loc: Millington, TN
Hi Albie. Try this: http://televue.com/engine/page.asp?ID=141
-------------------- Scott Azmus
SV80BV, NexStar 11, & 18" Obsession
Many Views Yield Truth
Albie
Reged: 02/22/05
Loc: Alberta,Canada
I'm still confused.
Patrick
Reged: 05/16/03
Loc: Franklin, Ohio
Albie,
Here is a good article in the CN Reports area pertaining to exit pupil.
http://www.cloudynights.com/lab/technical/binoexit.pdf
Patrick
Discovery 10" f/6 Split Tube Dob
Celestron C6 SCT
Denk Binoviewers
AT66ED Refractor
Oberwerk Ultra 15x70 Binocular
475B Geared Tripod & 501HDV Head
Oberwerk 9x60 Binocular
Celestron Regal 8x42 Binocular
Canon 30D DSLR
Mini EQ1
My Astronomy Pages
markf
Reged: 10/13/04
Loc: Houston, TX
Hi Albie,
It refers to the size of the light cone that "exits" the eyepiece. Think of it as a cylinder of light. The exit pupil is the diameter of this cylinder.
The average human eye has a pupil size of about 7mm when fully dialted. So the view in an eyepiece will get brighter with larger exit pupils until you reach the 7mm size. Then it won't get any brighter.
I've heard that having an exit pupil larger than 7mm wastes light, making it sound like you lose image resolution or something like that. Personally I think that while not all the light enters your eyes, you don't lose any image details. It's just that an 8mm exit pupil is not any brighter than a 7mm exit pupil. I think Al Nagler said something to this effect, too, on his web page.
Hope this helps some
Mark
-------------------- Celestron C6N on a CG5-GT
Orion 80mm Refractor (guidescope)
ToUCam Pro II
Canon Digital Rebel
http://www.carsandfish.com/astroweb
Edited by markf (03/08/05 02:11 PM)
Reged: 06/16/04
Loc: San Diego, California
I've heard that having an exit pupil larger than 7mm wastes light, making it sound like you lose image resolution or something like that. Personally I think that while not all the light enters your eyes, you don't lose any image details. -----------
An exit pupil which is larger than the opening of your own pupil effectively "masks" the telescopes aperture so that in theory you do lose resolution. When your eye is open to 7mm, you are this is not a limiting factor because you eye cannot resolve the detail anyway. This can be an issue during the day when your pupil might only be open a 2 mm or less.
jon
markf
Reged: 10/13/04
Loc: Houston, TX
Ah! That makes sense. Thanks for the clarification Jon  Mark
ToUCam Pro II
Canon Digital Rebel
Albie
Reged: 02/22/05
Loc: Alberta,Canada
Is there a minimum exit pupil size that you would want to stay away from, or is that scope(apature,focal length,etc.) dependant?What is the minimum useful exit pupil size or is it relevent?
Edited by Albie (03/08/05 04:26 PM)
EdZ
Professor EdZ
Reged: 02/15/02
Patrick has already provided a link to my article on exit pupil vs. eye pupil.
Jon has already reinforced that any exit puil larger than your eye does indeed cause a loss. The losses are total light and resolution. But as Jon points out and the article clearly explains, these large exit pupils can only be achieved by using low magnifications, and that is not where you are attempting to achieve maximum resolution.
You will find all of that (clearly, I hope) explained in the article. The article uses a lot of references to binoculars, but all the same applies equally to telescopes. After you read my article, you may want to visit the "Discuss this article" forum posts and read what Bill Ferris has to say about Extended Objects which is a better explanation for that specific topic than I gave.
edz
-------------------- Teach a kid something today. The feeling you'll get is one of life's greatest rewards.
member#21
markf
Reged: 10/13/04
Loc: Houston, TX
OK, I'll read more into it. Just from what I've read so far, and what you've stated, about the magnification being so low, and that you're not tryng to acheive maximum resolution at that low of a magnification, it seemed to me to suggest that it's not generally a major loss.
Mark
ToUCam Pro II
Canon Digital Rebel
sixela
Reged: 12/23/04
Loc: Boechout, Belgium
No, but you can look at it another way: a larger true field of view is the only reason to go to very large exit pupils, as the objects won't become any brighter even with lower magnifications.
400mm f/4.46 David Lukehurst truss Dobsonian on Tom Osypowski equatorial platform
Orion Starblast (114mm f/4 reflector, Alt/Az)
Reged: 06/16/04
No, but you can look at it another way: a larger true field of view is the only reason to go to very large exit pupils, as the objects won't become any brighter even with lower magnifications. ----
Very true...
One issue that has not been mentioned yet:
The reflector, the Central Obstruction and the Exit Pupil...
If you look at the eyepiece from a distance during the day, you will see a circle of light. To first order this is the exit pupil. If the scope in question has a secondary mirror obstructing the light path, you will see a dark spot in the center of the exit pupil, this dark spot is caused by the central obstruction.
The size of the dark "hole" in the exit pupil can easily be estimated. The size of the exit pupil is equal to the focal length of the eyepiece divided by the focal ratio of the telescope.
The central obstruction has its own "focal ratio" which can be found either by dividing the eyepiece focal length by scope's focal ratio or by dividing the focal length of the scope by the diameter of the obstruction. The diameter of the hole is then calculated in the same manner as the exit pupil.
Imagine an F4 scope with a 25% central obstruction viewing during the day or maybe the full moon. The eyepiece is a beautiful 32mm TeleVue Widefield...
The exit pupil is a slightly wasteful 8mm (32mm/F4=8mm) and the exit pupil of the hole in the center is 2mm (8mm/25%= 2mm)
Now it turns out that when the light is bright, your own eye contracts down so that it only open about 2mm.
This means what you see when the light is bright is often not the image but the dark spot in the center. Not a good thing.
This same thing can happen with an SCT that is used with a focal reducer, normally F6.3. SCT's normally have central obstructions larger than Newtonians so the effective focal ratio of the central obstruction can be about the same as a Newtonian with similar consequences.
jon
lighttrap
Reged: 02/06/04
Loc: cloudy, foggy, humid NC, US
Albie, most folks eyes don't really resolve very well under 0.5mm exit pupil. Also, aside from wide field applications, a good many folks find that eyepieces that produce something in the neighborhood of a 2mm exit pupil are favored for many general situations. The fastest way to figure exit pupil for eyepieces is to divide the focal length of the eyepiece by the focal ratio of the scope. Thus, a 38mm eyepiece used in an f/7 scope gives an exit pupil of ~5.43, whereas a 6mm eyepiece used in the same f/7 scope gives an exit pupil of ~0.86mm. In theory, if your viewing conditions support it, you should be able to go all the way down to a 4mm eyepiece for a 0.58mm exit pupil. But, you may well find you prefer less magnification and a larger exit pupil for most of your viewing.
If you wish to figure exit pupil for binoculars, a more useful formula is objective size in mm divided by magnification. Thus a set of 10x50s have a 5mm exit pupil. This also works for scopes, but is more cumbersome than the first method.
-------------------- 18" Starsplitter II f/4.5
8" Hardin Dob f/6
C5 workhorse mini SCT f/10 or f/6.3
70mm TV Ranger dual purpose birding/astro
77mm Leica Televid APO
16x70 Fujinons on UA Deluxe Mt.
12x50 Nikon SE
8x30 Nikon E2s
and many others
Albie
Reged: 02/22/05
Loc: Alberta,Canada
Thankyou, that was the answer I've been waiting for.Not having tried all the pieces I want to get and also being a bit green I was a bit confused about exit pupil.I wanted to get a 4mm ep(.57 exit p.) and 6mm(.87) and wasn't sure if those low exit pupil figures result in poor light reception to the point of uselessness regardless of sky conditions.I think I have a handle on it now. The articles I was directed to were also helpful.Thanks people.For you wizards of the sky who hate repeating yourself to us greenbacks,have patience as we are but newborns learning the sky.I myself am 3months old and am getting more curious as I delve into this hobby.I felt like maybe I asked a stupid question?Well it's clarified now and thanks again.
Edited by Albie (03/08/05 11:44 PM)
lighttrap
Reged: 02/06/04
Albie, your question wasn't stupid. It was helpful. And in fact, I immortalized it in the Best of the Beginner's forum pinned to the top of this forum so now we may refer and learn from the responses to your question.
Keep well in mind that you may find that your local conditions are more limiting than your equipment. I find that's true more often than not. Tonight, nothing beyond a 1mm exit pupil was at all useful. Sometimes it's more restricted than that. So it goes.
Mike Swaim
8" Hardin Dob f/6
12x50 Nikon SE
8x30 Nikon E2s
and many others
markf
Reged: 10/13/04
Loc: Houston, TX
Could minimum exit pupil be the true source of the 40-50x per inch of aperture rule?
I have a 6" scope, that is f/5. The max recommended magnification is about 300x. If I use a 2.5mm eyepiece, I get, 300x. I also have a .5mm exit pupil.
Mark
ToUCam Pro II
Canon Digital Rebel
sixela
Reged: 12/23/04
They're simply equivalent.
The source is that a given circular aperture diffracts a point source into an Airy disc (i.e., blurs it), and once this Airy disc becomes large enough to see very clearly (which depends on the resolving power of the human eye, obviously), there's little point in increasing magnification.
Although that isn't true in the *strictest* sense, given that some contrast details have to made larger to be seen than those used to determine the resolving power of the eyes.
But it's a good rule of thumb.
BillFerris
Reged: 07/17/04
Hi Mark,
See David Knisely's message #364280 in the "Eyepieces" forum for a good summary of the physics and physiology behind the "50X per inch" guideline: Re: Eyepiece question - 233x or 260x?
Bill in Flagstaff
-------------------- Grand Canyon Adventure
Lowering the Threshold
18" Obsession
4.5" Meade 4500
10x50 Swift Audubon
Cosmic Voyage
markf
Reged: 10/13/04
Loc: Houston, TX
Hi Bill,
I had known that resolution limits was the reason for the magnification limit for a given aperture, not counting atmosphere of course.
But I had noticed that Mike's answer of .5mm minimum exit pupil, coincided with the max magnification, at least for my scope; I should see if it's true for other apertures (now where's my calculator..)
This is a case where someone new to this concept asked a question (thanks Ablie! ) and I see that I don't have a full understanding of exit pupil. I think it's a bit better now.
But to be honest, at least for telescopes, I still can't see why it's much of a factor? Ok, exit pupils larget than 7mm "wastes" aperture, and technically will cause loss of detail, but at the low magnifications we're talking about, it seems to be something the average backyard astronomer is not going to notice. Except on reflectors/SCTs/Maks where the central obstruction becomes a true obstruction And on the other end, it would seem that to get below .5mm exit pupil, you're fast approaching the max magnification of a given instrument.
It seems most useful in estimating what your view in a given eyepiece will be like, or if you're comparing different magnifications. Or perhaps, maybe it's just over my head and I'll just forget about it and go outside and look at more stars (Especially now that the Sun has returned to these parts )
Mark
ToUCam Pro II
Canon Digital Rebel
Albie
Reged: 02/22/05
Loc: Alberta,Canada
Well thank you very much.That takes some pressure off(me and my fragile psyche).Glad to be part of something helpful.I am beginning to experience varying sky conditions.I've noticed how hard it is to focus on certain objects after a rain(it rained here the other night).I also noticed how a bit of cloud can be helpful as well.I also just bought a televue 15mm plossl and feel that it is my best ep to date.The first use of it was dissappointing(night after the rain)I couldn't get it to snap into focus very well.Last night the views through the televue 15 were wonderful,almost 3-d like.So much to learn and much more to experience!
