powerstroke01
Reged: 06/19/07
Loc: Western Sierra Nevada Foothill...
Using SBIG St-237 on a Losmandy G-11 Gemini
      #3680597 - 03/14/10 03:43 PM
Im reallllyyyy confused now. Ive been doing lots of reading and have read that i need to use an Optocoupler with this camera/mount... First off... WHY?
Ive also read that i dont need one. But i was unsure why.. Could someone explain this to me? lol
I just want a definate answer..
And has anyone used this camera with this mount as an autoguider?
Sorry for all the questions.
powerstroke01
Reged: 06/19/07
Re: Using SBIG St-237 on a Losmandy G-11 Gemini new [Re: powerstroke01]
      #3680607 - 03/14/10 03:46 PM
And yes i have the round din connectors... if that helps.
jrcrillyAdministrator
Refractor wienie no more
Reged: 04/30/03
Loc: NE Ohio
      #3680614 - 03/14/10 03:48 PM
The standard 492 controller requires isolation; the Gemini controller does not.
bseltzer
Reged: 10/28/07
Loc: East S.F.Bay, CA
      #3680634 - 03/14/10 03:56 PM
The definite answer is "It depends..."
Seriously, which incarnation of the Gemini do you have? If it has the rectangular RJ-something-or-other connections to the motors, then an opto-coupler would be a good idea. Helps to prevent ground loops. OTOH, if your Gemini is the more recent type with round, DIN type motor connectors and the lighted rocker type on/off switch, then you'll probably be fine without an isolating autoguider cable.
I have the later version Gemini and have done auto-guiding with both an ST-4K and ST-2K without an opto-coupler cable with no problem whatsoever. That said, I went ahead and bought one of Tom H.'s opto-coupler isolated cables on the theory that it was cheap insurance since mine is a mobile set up, and the array of things I have connected to my power source changes from time to time.
Bert
powerstroke01
Reged: 06/19/07
Re: Using SBIG St-237 on a Losmandy G-11 Gemini new [Re: bseltzer]
      #3680667 - 03/14/10 04:09 PM
Bert
Thanks! I have the version with the round plugs and the lighted rocker switch..
bseltzer
Reged: 10/28/07
      #3682490 - 03/15/10 02:05 PM
Then you should be good to go. Be aware that if you connect the guider cable to the Gemini before you have the camera under software control, you likely will get a guider port error message from the Gemini. This is normal because the camera may send what the Gemini interprets as contradictory signals to the guider port until whatever camera software you're using gets control of it. This is annoying, but harmless. It's another reason to get the Tom H. isolater guider cable. It does away with these spurious error messages.
Bert
powerstroke01
Reged: 06/19/07
      #3682755 - 03/15/10 03:59 PM
I just dont want to fry something.. heh
Do you have a link to that isolator guide cable?
Edited by powerstroke01 (03/15/10 04:00 PM)
bseltzer
Reged: 10/28/07
      #3682915 - 03/15/10 04:55 PM
Don't have a link, but you can reach Ton Hilton at tom@arizonaskys.com. He's not making these commercially any more, but he does turn them out on an "as needed" basis when he gets enough requests.
Bert
29 registered and 28 anonymous users are browsing this forum.
