watcher
Reged: 11/21/07
Loc: St. Louis, MO
Just ordered an EQ2
      #3730841 - 04/07/10 04:18 PM
I've been putting together one of those Carton 60/1000 refractors that most of you have probably heard about. Being a 60mm and nearly exclusively for lunar and planetary, I figured it should have an EQ mount that's both light, an sturdy enough for a 60mm. I decided on an EQ2. they are not too easy to find.
Orion is the only one I could find that sells the mount separately. But, their offering doesn't use a dovetail for mounting a scope. Celestron sells one with their Astromaster 90mm, but besides being more money as a package, it's a little too stylized to go with a classic long tube 60mm. Finally, I found the Sky-Watcher Great start 80mm EQ2 at Adorama. It comes with a dovetail, a pretty decent looking optical tube, and a bunch of accessories for 50 bucks less than the Orion mount alone! I think it's a discontinued item, so I grabbed one.
The aluminum legs will have to be replaces with wood, but otherwise, it's just the ticket. Being for planetary at higher powers, I would like a tracking motor. Do any of you know which one would be better. Orion has one that seems to offer a greater amount of control, and Celestron has one that is much cheaper, that has sidereal as well as other tracking rates, that has to be detached to use the slow motion controls. Anybody use or have opinions on the two types?
Joe
Javier1978
Reged: 02/12/09
Re: Just ordered an EQ2 new [Re: watcher]
      #3731453 - 04/07/10 09:22 PM
Hi Joe,
I think it is always useful to use the mount RA clutch and be able to use the slow motion controls without detaching the tracking motor, so Orionīs seems the best option for me.
Javier.
SteveG
Reged: 09/27/06
Loc: Seattle, WA
Re: Just ordered an EQ2 new [Re: Javier1978]
      #3733221 - 04/08/10 06:06 PM
I recently installed a Celestron motor drive on my Vixen Polaris mount. It's the little box that mounts directly to the slow-motion shaft, and does not have a hand-controller. It is so simple and works perfectly, running off an internal 9v battery. It is permanently attached, so to move to tube in RA I simply loosen the RA lock, and then tighten it once centered. The motor has a speed adjustment and I have the RA speed nailed perfectly for my mount. I love the lack of wires and hand controller. I bought it new on Ebay for $20 plus shipping.
If I'm not mistaken, the EQ2 has a clutch built-in to the mount head. It's a lever that is mounted next to that little wheel on the side.
This is like the one I'm talking about only it's for your mount - you'll notice that one buyer hated it:
http://www.buytelescopes.com/Products/9632-Orion-astrotrack-electronic-motor-drive-for-eq-2.aspx
DavidD
Reged: 07/23/09
Loc: Phoenix, AZ
Re: Just ordered an EQ2 new [Re: SteveG]
      #3733365 - 04/08/10 07:20 PM
I have an EQ2 mount that I got with my Sky-Watcher. The only motor I could track down to fit was the one from Orion. Make sure you get the EQ2 one. The pictures on the web site weren't correct. The motor mounts over a shaft on the mount, and the clutch parts are built into the mount. You can disengage the motor using the metal disk with tab that is hanging on the mount, and engage it when you are ready to track. It comes with a hand control, too, that you can use to adjust the RA with the motor.
If you need more info, I can dig it up. I also found the instructions for installing and using the part somewhere online.
watcher
Reged: 11/21/07
Loc: St. Louis, MO
Re: Just ordered an EQ2 new [Re: DavidD]
      #3733472 - 04/08/10 08:19 PM
Thanks guys. As much as I like uncluttered and simple, especially for an occasional use fun scope, I think being able to use the slow mo controls might be worth the extra $$$ for a long scope like my 60/1000. That, and the ability to use a power supply when I use it at home, leads me to choose the Orion.
Thanks again
Joe
Doug76
Long Achro Junkie
Reged: 12/05/07
Loc: Refractor Heaven
      #3733522 - 04/08/10 08:59 PM
I think despite the light weight of that scope I would have opted for the EQ3 mount. Much sturdier, not too much heavier or more expensive. You can never have too much mount.
watcher
Reged: 11/21/07
Loc: St. Louis, MO
Re: Just ordered an EQ2 new [Re: Doug76]
      #3733611 - 04/08/10 10:18 PM
Got that covered Doug. If I'm not happy with the 2, I can always go to my CG-4 Omni mount. Just want the 2 for the "classic looks", and for down and dirty g&g. If it works well enough, I'll stick with the combination.
Joe
Doug76
Long Achro Junkie
Reged: 12/05/07
      #3733658 - 04/08/10 10:47 PM
It should be fine, has a 9lb capacity, and it does look more classic, doesn't it?
DavidD
Reged: 07/23/09
Loc: Phoenix, AZ
      #3733857 - 04/09/10 01:14 AM
Mine came with a rings setup instead of a dovetail. I wanted to be able to use it for a couple of scopes, one which already had a dovetail. I ended up getting an ADM dovetail saddle for it. Anthony custom drilled the holes to fit, and shaved a bit off the clearance to accommodate the smaller dovetail of the other scope. I added a dovetail to the rings, and now all parts are interchangeable.
watcher
Reged: 11/21/07
Loc: St. Louis, MO
      #3734008 - 04/09/10 04:46 AM
In case anyone checking out this thread is interested in the Great start 80 EQ, I think I got the last one from Adorama. OPT has them on sale now for even less! Getting mine today. It really looks like a nice beginners scope for $100.00.
Joe
EdZ
Professor EdZ
Reged: 02/15/02
      #3734070 - 04/09/10 07:00 AM
The Orion EQ2 mount is identical to the Celestron CG3 mount.
BTW, on the Orion website, when you are looking at the EQ2 mount page, they show a drive on the side of the page, the EQ-2M. That is NOT the correct drive for the EQ2 mount.
I have both the EQ2 and the CG3 and I have both the correct EQ2 Orion drive and the CG3 Celestron drive.
The corerect drive has a gear sticking out of the black motor box. That gear meshes with the large gear attached to the mount. The clutch allows you to disengage the two gears by tilting the motor box. So the clutch is useless without the correct motor.
The drive shown has a black plastic piece that slips over an axle.
edz
watcher
Reged: 11/21/07
Loc: St. Louis, MO
Re: Just ordered an EQ2 new [Re: EdZ]
      #3734345 - 04/09/10 10:18 AM
OK. Now I'm confused. Which motor do I order, if not the EQ2M?
Joe
EdZ
Professor EdZ
Reged: 02/15/02
      #3734412 - 04/09/10 10:51 AM
http://www.celestron.com/c3/product.php?ProdID=279
this is the correct motor for the EQ2/CG3
notice the small gear under the spring. That gear meshes with the large gear wheel on the EQ2 mount. The long T bolt gets locked down when in use and gets loosened when you want to use the clutch to disengage the motor. The clutch separates the two gear wheels. The spring facilitates the function of the clutch by allowing the gears to reengage when the clutch is released.
edz
take note here the difference in these two motors
the correct syle motor
http://www.amazon.com/dp/B0000XMWC6/ref=asc_df_B0000XMWC61083685?smid=A1MX591ICBLWRE&tag=dealtmp419993-20&linkCode=asn&creative=380341&creativeASIN=B0000XMWC6
the INCORRECT style motor
http://www.telescope.com/control/product/~category_id=drives_controllers/~pcategory=accessories/~product_id=07827?id=cadf
DavidD
Reged: 07/23/09
Loc: Phoenix, AZ
      #3734419 - 04/09/10 10:56 AM
As I stated before, the picture on the Orion site is incorrect. They lump all the drives onto one page (and thus all with one picture), and you select the one you want from the drop down box. I have one that is mounted and working, so I know it is the correct one. The part description from my email invoice reads:
EQ-2M Orion Electronic Telescope Drive System #07827
I actually bought mine while the Orion sale was going on, so got it for $62 instead of $73. Also, if you poke around a bit, you might be able to find a code for free shipping on an order over $100 (if you need anything else).
DavidD
Reged: 07/23/09
Loc: Phoenix, AZ
      #3734429 - 04/09/10 11:01 AM
The one Edz pointed to is the one that I got from Orion using the information I gave above. I couldn't find it anywhere else, and the Celestron site didn't have it when I was looking. I sent Orion emails to confirm it was the correct drive and they assured me it was, and they were correct.
watcher
Reged: 11/21/07
Loc: St. Louis, MO
      #3734438 - 04/09/10 11:04 AM
Bummer. Guess I'll have to hunt used, or do without.
DavidD
Reged: 07/23/09
Loc: Phoenix, AZ
      #3734452 - 04/09/10 11:12 AM
Ironically, this is the correct picture for the EQ-2M, not the 1M as the page states:
http://www.telescope.com/control/product/~category_id=drives_controllers/~pcategory=accessories/~product_id=07826/~sSearchSession=9af42772-f382-406a-b558-096184ae0773
DavidD
Reged: 07/23/09
Loc: Phoenix, AZ
      #3734470 - 04/09/10 11:18 AM
PM sent. I didn't find any used.
DavidD
Reged: 07/23/09
Loc: Phoenix, AZ
      #3735250 - 04/09/10 04:55 PM
The OPT scope/mount looks like the same mount I have that uses fixed rings instead of a dovetail. Does the Adorama scope definitely have a dovetail?? Otherwise you'll need to do like I did and retrofit an ADM saddle to the mount.
watcher
Reged: 11/21/07
Loc: St. Louis, MO
      #3736351 - 04/10/10 09:41 AM
I swear, I saw one of the listings for the Skywatcher that said dovetail. It might have been OPT, but I can't find any of the adds that list it now. At any rate, I got the package yesterday, and it is not a dovetail. Maybe OPT corrected their print when they got it back in stock, and put it on special? Not a real big deal though. ADM will add a touch of class. The aluminum legs will have to go too, eventually, but the are a little sturdier than I thought they would be, even with the 80mm tube attached.
David,gotta go run some errands today,but will PM you about the OTA later.
Joe
18 registered and 41 anonymous users are browsing this forum.
