Agnosticus
Reged: 09/12/04
Loc: 43N, 89W, Earth
CG-5 Goto mount problem...
      #3741353 - 04/12/10 08:46 PM
Hi everyone,
For whatever reason, my used (but newly purchased) Celestron CG-5 GOTO mount is acting like it's possessed. When I turn it on, put in all the requisite info, and start the automatic 2-star alignment, it ends up slewing...and slewing...and slewing, until it's pointed at the ground. Then it keeps intermittent little movements indefinitely (until I end up having to switch it off). Any ides?
hfjacinto
I think he's got it!
Reged: 01/12/09
Loc: Land of clouds and LP
Re: CG-5 Goto mount problem... new [Re: Agnosticus]
      #3741363 - 04/12/10 08:51 PM
I never had this issue, but I have had slew speed up or slow down. Check the battery connection, it might be loose. I usually use a knife to pry apart the connection and that seems to always help.
jfusto
journeyman
Reged: 09/24/08
Re: CG-5 Goto mount problem... new [Re: hfjacinto]
      #3741372 - 04/12/10 08:59 PM
Are you polar aligned before you start the 2-star alignment procedure?
RTLR 12
Reged: 12/04/08
Re: CG-5 Goto mount problem... new [Re: jfusto]
      #3741392 - 04/12/10 09:09 PM
Sounds like a power issue. Check your power supply, cables and connections. You will also need to do a factory reset and re-enter your info and settings.
Stan
Agnosticus
Reged: 09/12/04
Re: CG-5 Goto mount problem... new [Re: RTLR 12]
      #3741579 - 04/12/10 10:57 PM
Yep, polar aligned. It seems to be powering up OK (using their cig lighter car adapter), though perhaps the connection needs to be cleaned. I will try the factory reset as well. Thanks!
Fred1
Reged: 09/19/07
Loc: Somewhere in the Orion Spur
      #3741583 - 04/12/10 11:01 PM
Are you sure you're getting at least 11-12V from your power supply?
RTLR 12
Reged: 12/04/08
Re: CG-5 Goto mount problem... new [Re: Fred1]
      #3741602 - 04/12/10 11:12 PM
You had better make that 12-13V. At 11 volts you will have problems...
Stan
Chris Rowland
Reged: 02/28/05
      #3741874 - 04/13/10 03:41 AM
If the power and factory reset solutions don't work then it could be a problem with the connections to the motors. If the encoder signals are bad the controllers don't know what the motors are doing and tend to keep driving them.
Check all the cables and connectors to the motors, inside and out. It may help to push the cables a bit further into the IDC connectors.
Chris
guyinthesky
Reged: 04/13/07
Loc: western ma.
Re: CG-5 Goto mount problem... new [Re: Chris Rowland]
      #3742036 - 04/13/10 07:33 AM
if the car is not running its only getting 12 volts, try it with it running, 13.8 volts.
Agnosticus
Reged: 09/12/04
Re: CG-5 Goto mount problem... new [Re: guyinthesky]
      #3742040 - 04/13/10 07:38 AM
Great suggestions. I will try them and get back.
Thanks again, gang!
Javier
Reged: 05/03/09
Loc: New Jersey
      #3742051 - 04/13/10 07:50 AM
Kevin,
This sounds like a power issue. Does the display on the hand controller glow a steady red color or does it sort of fade in and out? I learned that the CG-5 and probably all Go-to mounts are very sensitive to power fluctuations.
Agnosticus
Reged: 09/12/04
Re: CG-5 Goto mount problem... new [Re: Javier]
      #3742236 - 04/13/10 09:56 AM
The illumination seems to be pretty consistent.
One other question: with what do you clean the connections? A q-tip will no doubt snag on the little prongs in the cables and the jacks. Use a little brush? Dampen it in alcohol?
Eddgie
Reged: 02/01/06
      #3742568 - 04/13/10 12:55 PM
I don't think it is a power problem. If the power is interruped even for the briefiest instant, the hand controller will reset and you would have to go though the setup again.
I have heard reports that some power supplies with noize will cause problems, but there should be a ferrite core on the power cable (maybe Inch long, half inch diameter plastic housing on the power cable). The role of the ferrite core is to suppress noise and spikes on the power signal.
Still, it is impossiblet rule this out, so the easiest thing to do us plug it into a car cigerette lighter.
Otherwise, I think you have a problem either inside the mount (which I think is unlkely) or with the connections inside the RJ jacks on the mount.
I have had this problem with 3 different mounts in the past. Two were LXD-55s, and one was with a CG5.
The RJ ethernet/Telephone type jack on the housing has tinly little springy metal fingers that press against the pin on the end of the plug on the handset cable. I think that if these loose tension or get any corrosion on them, the signal can be interrupted or corrupted.
I have used a very tiny spring hook tool to pry under these spring contacts and VERY VERY gently "Form" them back up a bit and this has cured intermitttent problesm on these three mounts AND on my CGE, which used to somethimes have runaways.
I don't think it is as likley that there is a problem inside the housing. It couldbe though, and if reseating the dec and RA cables severla times to wipe the contacts (they are self wiping and unplugging and re-plugging can acutally wipe off slight corrosion) or re-arching the springs contacts doesn't work, then it may be necessary to open the housings and reseat the internal plughs, but again, I think this is not a likely cause of the problem.
Contamination on the face of the emmitter disk can cause pointing errors, but the Calibration proceedure I think attemtps to account for a blocked emmitter disk windows.
Your problem sounds more to me like signal distortion.
Good luck.
Reged: 07/06/07
      #3743227 - 04/13/10 05:58 PM
Hi everyone,
This is symptomatic of poor power. First step in troubleshooting is to try an alternate power source, preferably a fully charged battery not resident in an automobile.
Agnosticus
Reged: 09/12/04
Re: CG-5 Goto mount problem... new [Re: rmollise]
      #3743719 - 04/13/10 10:31 PM
Not the power... I made sure of that tonight. I also opened up the housing and ensured the connectors were well seated. I didn't open the DEC housing yet, though. I also haven't cleaned the controller or other jacks yet since I have no contact cleaner. Nor have I tried to gently pry up the connector prongs.
Agnosticus
Reged: 09/12/04
      #3743725 - 04/13/10 10:35 PM
I should also add: If I turn the thing on, if I don't do anything at all for long enough, it will just start slewing on it's own. I hope I don't have to ship this to Celestron. It's not under warranty anymore.
Edited by Agnosticus (04/13/10 10:36 PM)
Agnosticus
Reged: 09/12/04
      #3743759 - 04/13/10 10:51 PM
One last (probably very relevant) detail. When I do my 2 star alignment, I tell it to go to Capella first (since it's fairly high in the sky). It goes approximately to where Capella is, but the little spinny icon in the hand control screen just keeps spinning... then the 'scope proceeds to slew around and point at the ground. Then it will just stop for awhile... scoot a little... stope awhile..etc... It goes through this same process every time.
Reged: 07/06/07
      #3744191 - 04/14/10 08:07 AM
How did you make sure of that? It sure _sounds_ like power problems. Failing that, your best course is "Call Celestron."
Fred1
Reged: 09/19/07
      #3744819 - 04/14/10 02:06 PM
Perhaps the power switch is corroded and not making good contact. Doesn't cost much to replace one. I'm pretty sure this is the one, if you decide to go that route.
dwitek
Reged: 07/03/08
Loc: White Lake, Michigan
Re: CG-5 Goto mount problem... [Re: Fred1]
      #3745495 - 04/14/10 08:12 PM
Just yesterday I received a used CG-5 and mine does the EXACT same thing. It slews close to where the first alignment star should be (it's still daylight), stops for about 10 seconds but the "working" Icon keeps spinning. Then, the scope starts slewing, in dec only, for about half a revolution. Then, it pulses in the same direction until the dec cord wraps itself around the housing and I have to stop it or else it will rip the cord apart.
I checked the raw voltage from the power supply and it shows 15.2 volts. But, this is without a load.
I've reset to factory defaults but I understand that there are some values that don't get reset. The reset command only resets values stored in the hand controller, not the mount itself.
This is my first Celestron equipment and I know everyone raves about this mount but I'm quite disgusted.
I will add that the person that sold the mount to me forgot to send the factory Dec motor cord so I made one myself. It is flat, 6 wire telephone cable with the proper ends for 6 wire but is not shielded. I only mention that because I was reading that the CGEM uses a shielded cable but I could not find any info on the specs of the CG-5. The seller is sending me the factory cord but it's clear tonight so I made my own.
ADD 20:37: I notice that the RATE key changes the slew rate in RA but Dec stays at maximum speed no matter the setting. Is this normal? Could it be related to the homemade cable?
Edited by dwitek (04/14/10 08:35 PM)
27 registered and 33 anonymous users are browsing this forum.
