EightyFive
Reged: 03/19/07
Loc: Italy
Help... Repair Meade DS goto mount..
      #3770935 - 04/27/10 05:30 AM
My small meade Ds mount recently had a problem.
The autostar handpad tell me that there's a problem with motors and they didn't move.
I tried to check it but i'm not able to disassemble the mount base.
Could you please help me if you know something about it?
I just open the mount's arm and it seems to be ok. Mechanically is perfect.
Also gears are in good condition and motor doesn't show sigms of burns or overheating. Maybe it's a problem of wiring.
So i need to dismount the base but i don't find a way to do that.
I didn't use for some month this mount and last time i tried it motors move well.
Some days ago I tried to use it again ( because also my cg5 motors have problems now ) but it didn't move.
Help me please if you could
Reged: 07/06/07
Re: Help... Repair Meade DS goto mount.. new [Re: EightyFive]
      #3770977 - 04/27/10 06:25 AM
Before you go tearin' into anything, try "Calibrate motors" from the Autostar.
EightyFive
Reged: 03/19/07
Loc: Italy
Re: Help... Repair Meade DS goto mount.. new [Re: rmollise]
      #3771064 - 04/27/10 08:23 AM
when I turn on the power in the autostar handpad, after the initialization, the motor problem error appears..
EightyFive
Reged: 03/19/07
Loc: Italy
      #3771123 - 04/27/10 09:01 AM
"motor unit fault" is the message.
Motors doesnt make any sounds...
Brian Risley
Reged: 09/04/06
Loc: SW Florida
      #3771687 - 04/27/10 01:40 PM
George Cushing (Geo) may be able to help, he works on these alot. Also, check with the guys in the roboscoping Yahoo group.
Brian
EightyFive
Reged: 03/19/07
Loc: Italy
Re: Help... Repair Meade DS goto mount.. new [Re: Brian Risley]
      #3771992 - 04/27/10 03:54 PM
Is he a user of this forum? I din't find it :|
Brian Risley
Reged: 09/04/06
Loc: SW Florida
      #3772156 - 04/27/10 05:18 PM
His user ID is Geo.
Note the period. He is on page 20 or so of the user list if you select the G's.
There is another geo without the period too.
Brian
EightyFive
Reged: 03/19/07
Loc: Italy
      #3773023 - 04/28/10 05:22 AM
I've just sent a PM to Geo. I hope to solve this problem
EightyFive
Reged: 03/19/07
Loc: Italy
      #3774860 - 04/29/10 05:20 AM
no answer..
Tomorrow I'll try to take it to a friend who is good in mechanic reparation..
I hope to find a solution..
Geo.
Reged: 10/01/08
Loc: Upstate NY
      #3775857 - 04/29/10 03:41 PM
There's a 13mm cap screw (bolt) under the battery box. Remove it and the upper assembly should pull up off the base unit.
If you are getting a "Motor fault error" it may be a bad MOSFET on the motor control board. If the Autostar isn't powering up check the modular connectors, they give a lot of trouble.
Geo.
EightyFive
Reged: 03/19/07
Loc: Italy
Re: Help... Repair Meade DS goto mount.. new [Re: Geo.]
      #3776276 - 04/29/10 06:40 PM
Hi Geo.!!!
I've removed it but the upper assembly didn't pull off :|
EightyFive
Reged: 03/19/07
Loc: Italy
      #3783167 - 05/03/10 08:56 AM
nothing.. I'm not able to open it
17 registered and 28 anonymous users are browsing this forum.
