Roy Salisbury
Reged: 05/26/09
Loc: Las Vegas, NV
CPC Mount Drift
      #3864360 - 06/14/10 02:26 PM
I'm pretty sure I did a very accurate polar alignment last night but I still get some serious eastward drift with my mount. Is it possible that the drive moter is tracking too fast east-west? My autoguider just can't seem to account for it so I can't get tracking over say 2 minutes before noticable star trails show up in my photos.
If it is the drive motor tracking too fast, how can I solve it? If it's not, then what could it be?
Roy
Edited by Roy Salisbury (06/14/10 03:28 PM)
jrcrillyAdministrator
Refractor wienie no more
Reged: 04/30/03
Loc: NE Ohio
Re: CPC Mount Drift new [Re: Roy Salisbury]
      #3864406 - 06/14/10 02:42 PM
Roy
Hi, Roy.
Some possibilities exist. A really bad PEC training can cause an effective tracking rate error (too many East corrections). Slop between the guide scope and the imaging scope can cause apparent drift. Turning off both PEC and the guide camera would eliminate those as possibilities.
Newfie Ninja
Reged: 06/27/08
Loc: Newfoundland, Canada
      #3864437 - 06/14/10 02:54 PM
I had a similar problem last year and it turned out to be a balance issue. I arrived at the local dark site and realized that I had forgotten my dew shield which plays an important role in the balance of my scope. I could get a good alignment and goto a target but after a few minutes the scope had comptletly tracked past whatever target was in the eyepiece. A couple of nights later I balanced it with my ADM counterweight set and put all the usual observing gear onto the scope including dewshield and it worked fine. Needless to say I double check now before leaving for a darksite. Hopefully your problem will turn out to be a simple fix like mine.
Good Luck
Roy Salisbury
Reged: 05/26/09
Loc: Las Vegas, NV
Re: CPC Mount Drift new [Re: jrcrilly]
      #3864500 - 06/14/10 03:19 PM
I looked into the PEC last night. I did a 5 minute guided run with both PEC on and off and it was pretty much the same end result (though the autoguider was working a bit harder with the PEC off).
Slop on the guide scope should not be an issue. Its pretty solid.
Roy
Roy Salisbury
Reged: 05/26/09
Loc: Las Vegas, NV
Re: CPC Mount Drift new [Re: Newfie Ninja]
      #3864520 - 06/14/10 03:26 PM
I'll double check today and make sure things are balanced correctly as well. But could be that becuase of the new filter wheel the balance through the night gets out of wack.
Roy
CT Sound Shooter
Reged: 02/01/10
Loc: Connecticut, USA
      #3864537 - 06/14/10 03:32 PM
Roy,
You didn't say whether you drift-aligned after you polar aligned the mount.
I know that if I only polar align using the CPC built in function on the mount, my polar alignment is not nearly accurate enough.
Hope this helps,
CTSS
Roy Salisbury
Reged: 05/26/09
Loc: Las Vegas, NV
Re: CPC Mount Drift new [Re: CT Sound Shooter]
      #3864677 - 06/14/10 04:32 PM
My precise polar alignment was not using the built in methods, but rather drift aligning. I only use the built in one to get a "close" match. This is on a permanent pier so once I get it exact I should not have to do it again (one would think anyway).
I also checked my balance and while it was off just a bit, it was not on the axis I am having issue with.
Roy
Peter in Reno
Reged: 07/15/08
Loc: Reno, NV
      #3864686 - 06/14/10 04:36 PM
If you are guiding an SCT with moving mirrors using a guide scope, it's a classic mirror flop. It does not matter how tight your guiding system is, you will always get image shifts in between subs. The guide scope has no idea the SCT mirror is moving during guiding and the guide scope will never be in sync with a moving SCT mirror. I know this and I have been there.
Your best solution is Off Axis Guider. I replaced my ST80 guide scope with OAG and the problem went away. I never drift align. I polar align using CPC hand controller and it works pretty well. I always do two star align, then polar align, then double check two star align, double check polar align and once more triple check two star align. I know the latest firmware says it's not necessary to double check but I do anyway. Also, I always forget to do this, after polar align, ALWAYS do an UNSYNC otherwise your GOTO may be quite a bit off. One night I did the triple checking, I didn't UNSYNC after each polar align and my GOTO was a mile off.
See my latest M57 image taken last Saturday using Hutech OAG and Lodestar autoguider:
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/3862995/page/1/view/collapsed/sb/5/o/all/fpart/1
The nice thing about using OAG is I don't need to add counterweight. I have an ADM Losmandy dovetail with a ADM CW adapter but no CW is mounted. The CW adapter acts like a CW. It's not even 100% balanced but very close so don't try too hard to get it perfectly balanced.
Also, make sure both RA and Dec locks are pretty tight. This is equally important as balancing. Over tightening won't hurt anything.
Peter
Roy Salisbury
Reged: 05/26/09
Loc: Las Vegas, NV
Re: CPC Mount Drift new [Re: Peter in Reno]
      #3864755 - 06/14/10 05:07 PM
Ok.. This sounds like a perfectly valid reason. I had not thought about the mirror in the SCT moving, but it does explain a number of other things as well (focus changing more than one would expect is one that comes to mind).
I tried an OAG at one point .. But to be fair, it was a cheap Meade OAG along with my SSAG .. it just never worked well. I guess I can try the one your using and see how it does. Also (and I know this is not on topic), how well does the Loadstar guider work .. it is pretty sensative (compared to the SSAG).
Very nice. This is why I would have expected the mount itself to not have so much of an issue. I'm still a long way off from 10 min subs, but as soon as I get the tracking working then I hope to get something close.
Roy
Peter in Reno
Reged: 07/15/08
Loc: Reno, NV
      #3864835 - 06/14/10 05:45 PM
I had SSAG and Lodestar is by far more sensitive. Also, I really like the 1.25" cylinder shape of Lodestar. The shape allows me a greater range of focusing by moving the Lodestar up and down in guide port of OAG.
OAG is always difficult to use for beginners. There is no good training manual for this. My trick is to get both image and guide cameras parfocal (focused) during the day. Then I mark the parfocal position of Lodestar with a parfocalizing ring ( http://www.scopestuff.com/ss_par1.htm ). I tried using OAG for the first time at night and it was a nightmare. Now, after using several times, it's as easy (or easier) than using guide scope.
My OAG is not cheap but worth every penny: http://www.sciencecenter.net/hutech/mitsub/oag.htm . There are other high quality OAGs out there at about the same price as mine. Google for "Off Axis Guider".
Good luck,
Peter
Roy Salisbury
Reged: 05/26/09
Loc: Las Vegas, NV
      #3864913 - 06/14/10 06:16 PM
I'm going to try my current OAG tonight with my DSLR (don't have the necessary adapters for the QHY9). I'll see if I can get them working just enough to test to the mirror shift theory and see what type of guiding I can get.
I may also try another test as well and take the SCT mirror out of play all together. I can hook up my SSAG to my finder scope (I have an adapter for that) and the camera to my AT66 guide scope. Then I know I have no mirror shift involved.
Roy
Edited by Roy Salisbury (06/14/10 06:36 PM)
Peter in Reno
Reged: 07/15/08
Loc: Reno, NV
      #3864974 - 06/14/10 07:00 PM
When I first started imaging with OAG, I was shocked to see no image shifts in between subs. That's how good OAG is as compared to guide scope on top of SCT.
When you test with OAG, make sure the setup is well balanced and RA/Dec lock knobs are TIGHT.
Peter
Roy Salisbury
Reged: 05/26/09
Loc: Las Vegas, NV
      #3881932 - 06/23/10 03:04 PM
Ok. I tried using my Meade OAG and it was very hard to use and not that good. However, I went ahead and ordered the OAG you recommended anyway (thinking the Meade is just a bad device).
Can you tell me about any hard to use issues you have had and was to make things easier. I hope to have it this weekend to play with before the next full moon.
Peter in Reno
Reged: 07/15/08
Loc: Reno, NV
      #3881994 - 06/23/10 03:32 PM
Hi Roy,
I practice parfocalizing both image and guide cameras during the day. I focus at a street light about half an mile away. Once I got both cameras focused, I marked the focus point on the autoguider by using parfocal ring ( http://www.scopestuff.com/ss_par1.htm ) so that the guide camera will always be at the same spot everytime. It should be at the same spot with or without focal reducer. Daytime is the best and easiest way to make the setup much easier at night. Do not over-expose, start at 0.001 sec (1 msec) and go from there. Be patient and once you get the hang of it, it'll be as easy as using the guide scope. So far I have not had to hunt for a guide star in my very heavily light polluted area. I give most credits to Lodestar because it's so much more sensitive than SSAG.
Here is my latest image from last Friday night:
NGC 4565: http://img819.imageshack.us/img819/9841/ngc456517acblevelsgradx.jpg
7 x 15 minutes at F/10 (no focal reducer) using SXVR-M25C CCD color camera, Hutech OAG and Lodestar. This was taken during first quarter moon and the moon was near the galaxy.
Peter
Roy Salisbury
Reged: 05/26/09
Loc: Las Vegas, NV
      #3882404 - 06/23/10 07:22 PM
Great. I will make sure to let you know how it goes. I have great dark skies now with my new observatory, and with the longer exposures I am finding a lot of issues that I did not have with light polluted short exposures. I'm hoping this will help out.
I also tested my mount using just my current guidescope (AT66ED) and was able to do 10 min exposures with NO GUIDING and had very little (if even noticable) errors on the individual subs (the offset was visible on the stacked images). So I am hoping that an OAG on the main scope will be just as good if not better.
Thanks for the help!
Roy
13 registered and 34 anonymous users are browsing this forum.
