Montana
Reged: 01/02/10
Loc: Cheshire, UK
EQ3-2 RA motor arm help
      #3984159 - 08/15/10 11:17 AM Attachment (47 downloads)
I have an old Helios (Skywatcher) EQ3-2 mount which I recently bought some motors for to get it tracking. I fitted them following the instructions and last night went out to try it. I spent a long time trying to move the telescope towards Jupiter but it just wasn't moving. I then noticed that the RA arm which is attached to the telescope had snapped. I enclose a photo.
I have 2 questions:
1. Can a replacement be easy to buy or is there anyway I can fix this eg superglue?
2. I really don't understand how you can move the telescope with the motors attached, as I must have broken it by slewing round manually. The motor doesn't turn when not in use and was attached to the arm of the telescope. Therefore when I moved it manually I must have ripped it off. If I moved the scope using the 8x speed from north it would take 4 hours to get to where Jupiter was. What have I done wrong and how do you move the telescope when these motors are attached?
I've probably been really silly and missed the obvious but I really need help, I was so disappointed last night. Hopefully the picture will help you understand what I have done.
Thanks for any help.
Regards
Alexandra
Andy Taylor
Twisted, but in a Good Way
Reged: 09/24/08
Loc: Epsom - UK
Re: EQ3-2 RA motor arm help new [Re: Montana]
      #3984391 - 08/15/10 12:48 PM
No fix - it's knackered.
There is no clutch between the motor and worm drive so the motor cannot be disengaged without loosening screws - you have to loosen the lock levers to slew the scope. Sorry.
As to a replacement, I've seen these flexible couplings at RS Components but they ain't cheap! Try Maplins - they have solid shaft couplers that may fit.
Maybe a trip to your local model shop? They stock loads of nerdy (useful) stuff...
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: EQ3-2 RA motor arm help new [Re: Andy Taylor]
      #3985215 - 08/15/10 09:33 PM
You can buy 'em on ebay too about $10.
Or go to smallparts.com
http://www.smallparts.com/Climax-Metal-RC-025-S-Coupling-Stainless/dp/B000PKTFCO?ie=UTF8&sr=1-1&qid=1281922216&pf_rd_r=0KBS89RH22JTEH6D99DF&pf_rd_m=A2LPUKX2E7NPQV&pf_rd_t=101&pf_rd_i=16411881&pf_rd_p=1261382302&pf_rd_s=center-3
the flexible coupling is better though (like the original). digi-key and RS only have some.
Montana
Reged: 01/02/10
Loc: Cheshire, UK
Re: EQ3-2 RA motor arm help new [Re: orlyandico]
      #3985694 - 08/16/10 05:19 AM
Thanks for the bad news folks, I feel such an idiot that I didn't think about it properly. What a bad design though to have to take it apart every time you want to view something different! I guess in the summer it isn't too bad but I can't imaging trying to unpick that little screw without loosing it with numb fingers in winter.
I have had a go at superglueing it but it may just snap again but doesn't hurt to give it a try while I source another. I just need another clear sky at night to test (took 6 weeks to get one the first time!).
Regards
Alexandra
naavis
journeyman
Reged: 08/09/10
      #3985712 - 08/16/10 05:48 AM
You don't actually have to take it apart everytime you want to view something different. You can't use the manual RA fine-slewing while the motor is connected, but you can always open the RA axis lock and just turn the telescope by hand.
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: EQ3-2 RA motor arm help new [Re: naavis]
      #3985845 - 08/16/10 08:53 AM
superglue will not work. order the part from smallparts :-)
i agree, the design is poor. you can loosen the RA lock and push the tube by hand, but you lose fine manual control. What I do is loosen the lock, use a low-power eyepiece, point the tube by moving it, then after locking the RA, using the forward/reverse buttons to center the object.
22 registered and 27 anonymous users are browsing this forum.
