Tel
Reged: 03/31/06
Loc: Wallingford England
Re: NexStar Imaging Showcase
[Re: Smittty692k4]
#4812553 - 09/17/11 11:14 AM
Hi Matt,
First and foremost, I have to declare that I have no practical experience whatsoever of using a Hyperstar with any of our Hyperstar compatible SCT 'scopes, so if you want to venture more deeply into this, I'm definitely not the person to ask !
What I can tell you though, and "Stop me if you've heard it" is that in the first place your 8SE has to be compatible. As of now, some are and some aren't. Those that are indicate such, (I hear), in writing on the secondary mirror. If your particular 8SE IS compatible, this means that your secondary mirror may be removed, (unscrewed), from the corrector plate to be replaced by the Hyperstar unit. When fixed, this potentially reduces the focal ratio from f/10 to f/2, bringing with it a much wider field for astrophotography coupled with a far less exposure time requirement.
Effectively this has converted your relatively "slow", long focal ratio 'scope into a very "fast" small, focal ratio one. However, with this accessory in place, the camera used has to be defined as one probably of the CCD ilk and small in size, otherwise its size will impinge on the light path; remembering that in using a Hyperstar the camera is placed at the front directly over the corrector plate. Thus any excess size of camera body will obscure proportionally the light entering the 'scope.
Such cameras as Starlight Express or SBIG types are the norm. These do not however come cheap !
Hoping that this helps explain a little, but please ignore me if you were already way ahead !
Best regards,
Tel
Edited by Tel (09/17/11 11:26 AM)
Smittty692k4
Reged: 07/05/11
Loc: East Bernard, TX
[Re: Tel]
#4812598 - 09/17/11 11:37 AM
HAHA, Thanks Tel, and Yes, mine is Fastar Compatible. There was an image online of the hyperstar unit on a 6 or 8SE, but had a cord comming off of the ccd unit THROUGH the view of the scope (like hanging in front of the lens). Seems that might get in the way or create a line in the image, right?
Tel
Reged: 03/31/06
[Re: Smittty692k4]
#4812620 - 09/17/11 11:48 AM
Hi Matt,
No, it's hghly unlikely that the cord will interfere at all. It will be well out of focus and as such will not register on the image.
Sure, it will reduce the incoming light minimally but when you consider what area it might represent contrasted with that of the whole corrector plate, such will be negligible.
Best regards, Tel
Skip
Starlifter Driver
Reged: 01/23/08
Loc: Fort Worth, Texas, USA
[Re: Tel]
#4812678 - 09/17/11 12:23 PM
Agreed Tel. I doubt there would be any affect from the VERY slightly reduced light from the cord. Add to that the high speed of the Hyperstar (~f/2) and the images from a setup like that are superb! Starizona website has lots of pictures taken with Hyperstar.
Matt, as Tel mentioned, you will need a CCD camera to use Hyperstar. My friend has a high-end SBIG monochrome camera and he spent beaucoup bucks on it. There are some less expensive options though. But bottom-line, you can't use a DSLR on a Hyperstar.
Midnight Dan
Reged: 01/23/08
[Re: Skip]
#4812914 - 09/17/11 02:43 PM
Well ... you can use a DSLR on a Hyperstar, but you'd want it to be on a bigger than 8" OTA so that the DSLR isn't extending too far beyond the size of the Hyperstar. Anything that's in the light path will create diffraction patterns just like the spider on a newt, or a Bahtinov focusing mask.
I've seen photos taken with a Hyperstar and DSLR, and you can see that the difraction pattern around stars hints at the shape of a DSLR! It's very strange looking.
If you have, say a 14" SCT, the secondary is much larger than in an 8" so a DSLR is pretty well masked by the round obstruction of the secondary. Check out this photo of a DSLR in place on a 14" http://www.pbase.com/samirkharusi/image/118540988
Matt:
To add to Tel's comments - If your 8SE is Fastar compatible, that means that the secondary is designed to be easily removed and replaced with the Hyperstar lens. If your 8SE is NOT Fastar compatible, you can buy a conversion kit that will make it Faster compatible. Here's the conversion kit: http://starizona.com/acb/HyperStar-Conversion-Kit---Celestron-8-SCT-P2615C648.aspx Here's the Hyperstar:http://starizona.com/acb/HyperStar-3-Lens---8-Celestron-P991C773.aspx
While your overall scope design is f/10 at 2000mm focal length, the primary mirror of you scope is actually f/2 at 400mm focal length. The secondary mirror is convex instead of concave like the primary, so that's what changes the effective focal length and focal ratio. If you remove the secondary, you're left with an f/2 scope with the image plane a little bit outside the front of the scope's corrector. The Hyperstar puts a lens there to bring the image plane to the right point for the camera, and performs field flattening as well.
The Hyperstar allows you to take pictures with much shorter exposure than normal because it's an f/2 - BUT ... remember it also changes the focal length to 400mm so you're taking *different* images. You get much lower magnification and much wider views so you have to choose appropriate targets.
-Dan
Smittty692k4
Reged: 07/05/11
[Re: Midnight Dan]
#4813099 - 09/17/11 04:54 PM
Yea, I went to Starizona's website earlier and read up on it. The views of the DSO's are amazing. Imaging the Orion Nebula in 2 minutes is an incredible feat, HOWEVER, It does state that the Hyperstar setup is used 99.99% of the time(im paraphrasing) for DSO's only and not on planets. SO, therefore, you COULD buy the Hyperstar kit and a CCD Cam for the DSO's, BUT you would still need to get a better mount, and other stuff to image through the visual back for planets. HMMM, tough call.
BLINEAU
Reged: 05/23/11
Loc: Paris, France
[Re: Smittty692k4]
#4813284 - 09/17/11 06:43 PM
Hi !
As promised, the animation :
Regards Eric
astroman68
Reged: 07/09/07
Loc: West Yorkshire, UK
[Re: BLINEAU]
#4813490 - 09/17/11 08:43 PM
Nice..
Midnight Dan
Reged: 01/23/08
[Re: astroman68]
#4813769 - 09/17/11 11:30 PM
All I can say is WOW!
-Dan
Arthur Dent
Galactic Hitch-Hiker
Reged: 10/23/08
Loc: South Yorkshire, UK
[Re: Midnight Dan]
#4814192 - 09/18/11 08:26 AM
Peter9
Reged: 10/30/08
Loc: Yorkshire - Born & Bred
[Re: Arthur Dent]
#4814219 - 09/18/11 08:57 AM
As good as they come Eric.
Thanks for posting.
Regards. Peter.
Skip
Starlifter Driver
Reged: 01/23/08
[Re: BLINEAU]
#4814556 - 09/18/11 01:06 PM
Love it, Eric!!
Tel
Reged: 03/31/06
[Re: Skip]
#4814596 - 09/18/11 01:31 PM
Superb animation, Eric ! How many hours' rotation does that actually represent ? I estimate between two and two and a half. (?)
Best regards, Tel
svtdoug
Reged: 02/07/11
Loc: Gig Harbor, WA, USA
[Re: BLINEAU]
#4815063 - 09/18/11 07:59 PM
What an image! Another bench mark set!
Thanks for posting!
kwad
Reged: 08/11/09
Loc: Northern Virginia
[Re: svtdoug]
#4862244 - 10/15/11 11:17 AM Attachment (16 downloads)
Hi everyone,
This is my first post. I have a NexStar 8SE and a C5 Spotter Scope for travel use. I’ve used the 8SE to do a little AP with the Neximage webcam, but I’ve not been satisfied with the image quality that I’ve been able to achieve so far. Jerry Lodriguss’ recent EdgeHD 11 images of the Moon and Jupiter using a Canon EOS T2i in movie Crop 640x480 mode on his www.astropix.com site encouraged me to try my hand at using a DSLR in movie mode in place of the Neximage. I recently purchased a T2i and just started experimenting with it.
I used my C5 Spotter Scope mounted on the 8SE mount to capture several Moon video clips. I used a Hyperion Mark III 8-24mm Zoom with T2i attached to it with the Baader eyepiece-to-T-ring adapter for easy eyepiece projection imaging. I did this to gain some basic experience using the T2i with an SCT and a zoom eyepiece before moving up to the 8SE. I found the setup quite easy to use and the fact that a laptop was not necessary during imaging provided an extra degree of psychological freedom beyond that of my Neximage experience. I have a JMI MotoFocuser on the 8” OTA, but not on the C5, so focusing was a bit frustrating for my preliminary tests.
The T2i was set Auto movie mode so that ISO and shutter speed where selected by the camera. I varied the zoom over the 24 mm to 8 mm range to get a feel for the overall behavior of the scope-eyepiece-camera combination. The setup was mechanically smooth to work with. I put a Baader 2” SCT Click-Lock on C5 to provide secure attachment of the diagonal-eyepiece-camera train. I used my WO 2” Dielectric Diagonal to provide a comfortable view of the T2i Live View Screen without having to perform contortions to see the camera LCD screen. The SE tripod was in its shortest configuration allowing me to sit comfortably in my observer’s chair while performing the captures. The Moon was used as the alignment target under the SE Solar and Planetary alignment option on the SE mount HC unit. The setup was fast and easy to use.
The T2i’s MOV video clips were easily transformed into AVI format by the freeware program SUPER. Registax 5 was to align, optimize, stack, apply wavelets, and adjust the gamma (curves) to produce the final images.
I concentrated on two Lunar Craters, Plato and Copernicus to perform my preliminary experiments with the equipment. If my memory is correct, these are at a nominal f/20 zoom setting. I’ve included Flickr links to the final images here in case my attempts to attach them in two posts to that will follow fails due to my inexperience with posting here.
Plato image link:
http://www.flickr.com/photos/quadstar/6246539192/in/photostream/
Copernicus image link:
http://www.flickr.com/photos/quadstar/6245402112/in/photostream/
The preliminary results of using the T2i with the SE setup are encouraging. The Plato image shows at least three of the nominal 2 mile diameter cratelets on the floor of the crater. Perhaps a better Sun angle would make them stand out better? This image was taken 2 days after the First Quarter. I was surprised to be even see them in the image of the Plato since the seeing was just average and C5 is a rather small scope. The Plato video clip was about 75 seconds long at 60 fps.
The Copernicus image was about 40 seconds long at 60 fps. The SE HC was used to keep the crater from drifting too far during the making of the video clips.
The results of this experiment are encouraging. The video clips from the T2i produce more robust stacked images than the Neximage webcam and the logistics of image capturing are significantly less complicated than the working with the webcam and laptop. The weather is now clearing up and I will be able to start using the 8SE with this imaging setup.
Carl
kwad
Reged: 08/11/09
[Re: kwad]
#4862255 - 10/15/11 11:21 AM Attachment (16 downloads)
Here is the Copernicus image.
flboy
Reged: 08/10/10
Loc: De Leon Springs, FL
[Re: kwad]
#4862275 - 10/15/11 11:31 AM
Hi Carl,
Welcome to the NexStar forum!
Those are some nice images. Congrats!!
kwad
Reged: 08/11/09
[Re: flboy]
#4862469 - 10/15/11 01:15 PM
Hi John,
Thanks for the compliment on the images.
Carl
Midnight Dan
Reged: 01/23/08
[Re: flboy]
#4862472 - 10/15/11 01:16 PM
Nice Carl! Looks like using the movie mode on that camera does a great job. I have an older Canon camera that has live view, but not movie mode. I use a laptop and software that can grab a movie off the live view screen but at much less resolution than movie mode would be.
You may want to post these in the newer thread called "AP Images taken with original Nexstar". This one had gotten too long, plus it started to mix Nexstar images with those taken on GEM mounts. Alex was kind enough to start two new thread, one for Nexstar images and the other for people who have "graduated" from the Nexstar mount.
-Dan
kwad
Reged: 08/11/09
[Re: Midnight Dan]
#4862490 - 10/15/11 01:27 PM
Hi Dan,
Thanks for the info on the newer thread. I'll take you suggestion and repost on that thread. I saw the several threads for imaging but wasn't sure which was the best.
Carl
