Stellarfire
Reged: 07/10/11
Loc: Switzerland
Re: TEC 200 new [Re: M13 Observer]
      #5543266 - 11/28/12 03:32 AM
I can't even imagine how I would go about handling such a beast!
Considering the dimensions of the TEC APO 200, it is surprisingly light. According the 2006 Owner's Manual, the OTA net weights are as following:
ED f/9 = 50lb / 23kg
FL f/8 = 45lb / 20kg
Anyway, for safe handling of that mighty OTA, a pair of Scope Totes would be a highly recommended accessory.
Stephan
mark8888
Reged: 09/24/10
Re: TEC 200 new [Re: Stellarfire]
      #5543270 - 11/28/12 04:14 AM
Here's the best pic I've seen which compares the sizes of the various TECs. Sometimes in pictures it's difficult to know what you're looking at because of the angle, but this one is reeeally clear.
http://www.unitronitalia.com/prodotti/TE-00-yuri.jpg
Astrojensen
Reged: 10/05/08
Loc: Bornholm, Denmark
Re: TEC 200 new [Re: mark8888]
      #5543280 - 11/28/12 04:58 AM
There is surprisingly little difference between the TEC 140 and the TEC 180. And the TEC 140 is quite a small telescope, physically, IMO. A Sky-Wathcer 150mm f/8 achro is a bit larger, in fact, to put things into a more common perspective.
Clear skies!
Thomas, Denmark
Max Lattanzi
Reged: 06/27/07
      #5543302 - 11/28/12 05:51 AM Attachment (44 downloads)
And, to put things in perspective, this is 'the kid' nearby 'the father'...
-- Max
snommisbor
Reged: 06/15/09
Loc: Cedar Park, TX
Re: TEC 200 new [Re: Max Lattanzi]
      #5543519 - 11/28/12 10:01 AM
The TEC 200 makes that FT focuser look so small compared to the other scopes.
M13 Observer
Reged: 12/09/06
Re: TEC 200 new [Re: Daniel Mounsey]
      #5543799 - 11/28/12 12:38 PM
The TEC200 is an astonishing 20 lbs. lighter than this 8" TMB at least.
At this size, they each have exceeded what I would personally call "portable". They are each a wonder to behold. On the other hand, had I a permanent observatory in a dark site . . . I can only dream of such. Which one performs best or is this the TMB with cell issues?
Scott99
Reged: 05/10/07
Loc: New England
      #5543810 - 11/28/12 12:42 PM
what a great picture! They should sell posters
Really I feel lucky to have a 6.3 inch refractor that is under 30 pounds and easy to handle. Compared to historic 6 inch refractors, that is a miraculous feat.
When you start to look at the 7 and 8 inchers....wow. magical machines for sure. Incredible amount of performance packed into a small package. You used to need an entire observatory building to use a 7 or 8 inch refractor!
M13 Observer
Reged: 12/09/06
Re: TEC 200 new [Re: Astrojensen]
      #5544144 - 11/28/12 04:03 PM
Clear skies!
Thomas, Denmark
Well, maybe. I find that while it appears like there is only a small difference on paper, and even when the OTA's are lying side by side, there is actually quite a considerable difference in the handling of OTA's as one progresses through the sequence of, SOB (some other brand) from 105mm through 180mm. For one thing, it is not just the OTA but attached accessories as well. I double ring with my 155 and 180, and the second set of rings with attached dovetail saddle plate must be on the tube before it is placed into the primary rings on the mount, similar to how Mike works it with his 200. That really starts adding a lot of cumbersome weight.
Stellarfire
Reged: 07/10/11
Loc: Switzerland
      #5544352 - 11/28/12 06:29 PM
As far as I know, TEC offered the giant 200 APO in three versions: the ED f/9 and two Fluorite versions at f/7 and f/8. Production of the 200 has ceased and total production number is quite small, resulting in little user data available.
Considering such a large aperture with its heavy lens elements, combined with a focal ratio as fast as f/7, one automatically thinks on the reliability of the lens cell construction. But despite the surprisingly light OTA weight of the TEC 200, it is not renowed for lens cell issues.
Yuri knows his job.
Stephan
Mirzam
Reged: 04/01/08
Loc: Lovettsville, VA
      #5544428 - 11/28/12 07:29 PM
The TMB scope with the lens cell issues is the 180ED f/9.
The TECs have no such issues.
JimC
suburbanskies
Reged: 12/18/04
Loc: New Jersey, USA
      #5544524 - 11/28/12 08:50 PM
-- Max
Ah, the son is taller than the father!
9 registered and 21 anonymous users are browsing this forum.
Moderator:  Scott in NC, FirstSight, panhard, star drop
