teskridg
Reged: 01/15/08
Loc: PA
Central obstruction shadow.
      #4269951 - 12/24/10 04:50 PM
Just got my A-P visual back for my CPC-1100 and installed my Earthwin binoviewers and power x switch and noticed the central obstruction shadow when daylight viewing some trees with a pair of Televue 32mm Plossls. Is this due to the daylight viewing and the smaller pupil and will it be visible at night? Tim
Arizona-Ken
Reged: 08/31/08
Loc: Scottsdale, Arizona
Re: Central obstruction shadow. new [Re: teskridg]
      #4270139 - 12/24/10 06:21 PM
Be patient my friend! I have the CPC1100 and EarthWin combination like you and the views are dynamic at night.
Be patient and have a Merry Christmas!
Arizona Ken
hbanich
Reged: 06/17/05
Loc: Portland, Oregon
      #4272986 - 12/26/10 05:01 PM
Hi Tim,
I think you're right - your smaller daytime pupil diameter is the reason you're seeing the central obsruction at low power. With 32mm Plossls I doubt you'll notice this at night.
teskridg
Reged: 01/15/08
Loc: PA
Re: Central obstruction shadow. new [Re: hbanich]
      #4274409 - 12/27/10 12:55 PM
Thanks all for the replies. I had 24mm Panoptics which I sold because of severe vignetting in the reduced mode of the p x s and got the 32mm Televue Plossls; for some reason there's less vignetting with these despite what I gather is the same field stop diameter. In addition, I like the appox. 100x magnification with these (considering the longer effective focal length of the 11" SCT rendered by adding the p x s diagonal and binoviewer) better than that provided by the 24mm Panoptics. Anyone else with an opinion on this? In the barlowed mode of the power x switch, the 24's would yield about 260x, which for my seeing conditions is usually excessive. Tim
Fred1
Reged: 09/19/07
Loc: Somewhere in the Orion Spur
      #4274460 - 12/27/10 01:33 PM
Tim, the TV 32mm Plossl and the 24mm Pan provide the same TFOV, however the 32mm is probably giving about 50x less and a brighter image, so I imagine the vignetting is less noticeable because of the lower power, narrower "apparent" field and additional brightness. I'm sure others can provide a more technical explanation regarding how the eye/brain overcomes the vignetting.
0 registered and 3 anonymous users are browsing this forum.
Moderator:  Geo557, panhard
