Observing >> Variable Star Observing and Radio Astronomy
Pages: 1 | 2 | 3 | (show all)
ASTERON
Reged: 11/24/07
Loc: ISRAEL
photometry questions
      #4311186 - 01/13/11 07:59 AM
Is it possible to do Science quality photometry from a medium light polluted area ?
Is there any narowband filter which may be used for cutting off the sodium lamp spectrum which is the main light poluter in my back yard so that photometery can be done, or would any type of filtering be self defeating because I do not integrate the entire spectrum coming from a star ?
I apologize if the question is dumb but I'm new to this and need to make some decisions.
Mirzam
Reged: 04/01/08
Loc: Lovettsville, VA
Re: photometry questions new [Re: ASTERON]
      #4311307 - 01/13/11 09:18 AM
In general, you typically will be making short (~1 min or less) exposures and will be measuring differences between target and reference stars. The sky background light level is subtracted from the target and reference stars as part of the calibration process.
The answer to the filter question depends on the type of photometry you are performing. I'm not an expert so perhaps some others here will comment.
JimC
rutherfordt
Reged: 05/07/06
Loc: Northeast Tennessee USA
      #4311462 - 01/13/11 10:31 AM
Asteron:
It is definitely possible to do photometry from a light polluted area since you normally do use filters that exclude most light pollution (the exact filters will depend on what you are actually doing).
With a CCD camera (mono) most people use a "V" filter (the "V" stands for "visual so it is a sort of yellow-green). There are also "R" (red) and "B" (blue) filters as well as others. These are not the same as the RGB filters that are used to take "pretty pictures."
I am currently using an infrared photoelectric photometer using "H" and "J" filters-- both are in the near infrared. They are very much immune to light pollution-- I have had car headlights sweep across the telescope, outside house lights turned on, etc. all to no effect-- in fact, I could do it from a mall parking lot and would have no issues.
Edited by rutherfordt (01/13/11 10:36 AM)
kohudson
Reged: 01/21/09
Loc: Mayhill, NM
      #4311519 - 01/13/11 11:00 AM
You can also do spectroscopy. Check out this link: http://valerie.desnoux.free.fr/paris%20saint-charles/Paris_obs_en.html
I think this is SO cool!
Hubert
Reged: 09/26/06
Loc: Belgium
Re: photometry questions new [Re: kohudson]
      #4311544 - 01/13/11 11:18 AM
You can even do unfiltered photometric observations from light polluted area. It's all about how bright your target is.
Clear skies, Hubert
http://www.vvs.be/wg/wvs/
ASTERON
Reged: 11/24/07
Loc: ISRAEL
Re: photometry questions new [Re: Hubert]
      #4312137 - 01/13/11 03:34 PM
Hi Tom,
that's very encouraging.
What is the IR photometer you are using and at what wavelength does it have peak sensitivity ?
I thought that most infrared is absorbed by water vapor and other junk in the atmosphere.
What type of observations do you do in IR ?
ASTERON
Reged: 11/24/07
Loc: ISRAEL
      #4312176 - 01/13/11 03:47 PM
Ken,
the spectroscopy data from the heart of Paris is very impressive.
Thanks for pointing this out and the link.
ASTERON
Reged: 11/24/07
Loc: ISRAEL
      #4312200 - 01/13/11 03:55 PM
Hi Hubert,
good to know. It seems that once i jump into the water I will most probably start with the brightest stars before I try very faint ones.
It Seems that for real faint targets it will make sense to select targets that show very fast variability so that one can do some work from a few hours at a dark site and still get some meaningful data.
slower brighter targets will probably best be done from my home which is more light polluted but I will be able to collect more data at higher collection rate (more nights).
Edited by ASTERON (01/13/11 03:57 PM)
jgraham
Reged: 12/02/04
Loc: Miami Valley Astronomical Soci...
      #4312452 - 01/13/11 05:51 PM
No problem! I do my photometry from my back yard usng a V filter. My skies are pretty bad with the faintest stars I can see wirh my unaided eyes being about magnitude 3-4ish. However, I can easily do very accurate photometry down to about magnitude 17.
Have fun!
rutherfordt
Reged: 05/07/06
      #4312792 - 01/13/11 08:23 PM
Asteron:
The photometer is an Optec SSP-4. It comes with two filters, H and J. Peak response is around 1250nm (J) with still good sensitivity at around 1650nm (H).
You're right about the water vapor-- it stops most IR, but these two wavelengths (and a few others) can sort of get through-- they are not immune, though. I have to keep an eye on the water vapor maps and fog or high cirrus will put a stop to the photometry.
You also need as large a telescope as possible-- I'm working with an 8-inch SCT and its almost too small (I've also used a C14 and its much better :-)). I am restricted to bright IR targets (about mag. 2.5 and brighter). Fortunately, there are lots of IR bright stars out there-- R Lyrae is faint visually, in the IR it shines at mag. -2.
ASTERON
Reged: 11/24/07
Loc: ISRAEL
Re: photometry questions new [Re: rutherfordt]
      #4313559 - 01/14/11 07:50 AM
Tom,
Thanks for the details.
Did you start doing IR photometry because your favorite targets were bright in IR, or for other reasons ?
Hubert
Reged: 09/26/06
Loc: Belgium
      #4314035 - 01/14/11 12:35 PM
Hi Asteron,
You don't have to choose faint stars with fast variability. There are plenty bright stars (7 - 10 mag) with periods ranging from 2 till 4 hours.
Clear skies, Hubert
rutherfordt
Reged: 05/07/06
      #4314466 - 01/14/11 03:54 PM
Actually, a local university asked me if I was interested in doing a project for them-- IR photometry of the epsilon Aurigae eclipse-- and I said yes. I've found that I really enjoy doing it, too.
Another bonus, at least for me, is that very few other people (amateurs, at least) are doing this. I appear to be the only person submitting H and J data to the AAVSO on Eps Aur-- there are probably other people doing it, but they're sitting on their data, probably so that papers can be written from it.
ASTERON
Reged: 11/24/07
Loc: ISRAEL
      #4315499 - 01/15/11 04:14 AM
Hi Hubert,
Thanks, thats good to know.
I dont really know much about variable stars and photometry.
I am basically just researching my options before I buy any specific equipment.
While I may have the patience to do objects which have long periodicity, I just thought that it may be more prudent and stimulating initially to start with objects which can give results within a period of hours or days, so that I can get exposed to the entire data acquisition, reduction and processing and plotting within a short time so I can get a better notion of what this is all about.
Edited by ASTERON (01/15/11 05:55 AM)
Hubert
Reged: 09/26/06
Loc: Belgium
      #4316170 - 01/15/11 01:27 PM
I do photometry on High Amplitude Delta Scuti-stars (HADS) and some eclipsing binaries. You can read more about the HADS here http://www.vvs.be/wg/wvs/vvs_wvs_HADSproject.php
but it's in dutch. Maybe you can let it translate by google or something. I think it's better that I make a English version to put in on our English section of the website. Anyway, its' a project that were are running in our Belgium variable star section and every year we make a publication as an IBVS.
There are some bright stars in the 8 - 10 mag range and you can see that a lot of them have periods of 1.5 - 3 hours. Perfect for a short night.
Clear skies, Hubert
jgraham
Reged: 12/02/04
      #4316367 - 01/15/11 02:59 PM
When I first started with photometry I also looked for stars with short periods, but I found that long period variables where actually better suited for my environment. Clear weather here is very spotty (my last notebook entries were in November) and with long period variables its okay to only get a look at them once a week or so. They also don't tie up my scope all night. I'll usually make a sweep through my current observing list before switching over to deep sky imaging. Another nice thing about long period varibles is that they typically span a very wide range in brightness. I also take a peek at a set of cataclysmic variables. Now those are fun! Night after night these little gems will sit just at the edge of where I can see them hiding around magnitude 15 or 16, and then bam! They become the brightest star in the field!
Fun stuff.
ASTERON
Reged: 11/24/07
Loc: ISRAEL
Re: photometry questions new [Re: jgraham]
      #4317543 - 01/16/11 05:43 AM
Hubert,
Thanks for the tip - I may try the google translation but I dont have good experience with it (at least not on German and Japanese).
I think after I figure our what projects I want to do It would be possible to better focus on what equipment I need.
I think currently the weakest link in my equipment chain is the mount (Atlas EQG). I may be able to get away using a 8" scope with Imaging gear on it but it definitely would not be good with my 40 pound 12" LX200R OTA +Camera on it.
If I get a good mount I may not have enough $ left for a good camera.
I am still looking for the best solution (If I stay with the Atlas mount I would be restricted to a lighter OTA - I was thinking about maybe a 8" AT8RC with Carbon Fiber OTA which may be light enough to sit confortably on my Atlas.
I was wondering if my FSQ106 refractor being a widefield 4" will be good enough for this kind of work - I have both the focal reducer and the focal extender for it so I can have three different focal lengths to select from (if so I would only have to buy the CCD so I can start working on this.
Edited by ASTERON (01/16/11 05:49 AM)
ASTERON
Reged: 11/24/07
Loc: ISRAEL
      #4317547 - 01/16/11 05:53 AM
John,
Thanks for sharing your experience.
I understand your reasons for choosing long period variables. If you observe regularly and have an ongoing program it does make a lot of sense to operate as you do.
Cataclismic variable sound exciting - are there any good ones with brighter baseline magnitudes such as 8-10 ?
Hubert
Reged: 09/26/06
Loc: Belgium
Re: photometry questions [Re: ASTERON]
      #4317625 - 01/16/11 08:16 AM
Asteron,
I use a C8 on a EQ6 with a SBIG ST7. Works very good for me.
A 4" refractor will also do the job. Very soon I'm going to do tests with a 10 cm refractor equipped with a DSLR.
Clear skies, Hubert
Hubert
Reged: 09/26/06
Loc: Belgium
      #4317626 - 01/16/11 08:18 AM
The famous ones becomes as bright as magnitude 8-10.
SS Cyg, R Gem, RX And, RU Peg ....
Moderator:  Rich (RLTYS)
