Announcements and News >> Discussion of CN Articles, Reviews, and Reports
Olivier Biot
Amused
Reged: 04/25/05
Loc: 51°N (Belgium)
CGE Pro Review
      #4321053 - 01/17/11 05:49 PM
CGE Pro Review
By Jim Welisek.
gio24
newbie
Reged: 01/26/11
Re: CGE Pro Review new [Re: Olivier Biot]
      #4343266 - 01/27/11 03:25 AM
hello!
I'm writing to you because I have a very big problem with my cge pro that anybody can solve.
as you can see form this video ( http://www.youtube.com/watch?v=Y-eAqRxzU5Y) have problem with motors and the mount can't be used.
All is properly balanced and this is the second mount that i change for the same problem, of course in warranty.
Before shipping the mount in california (i'm writing you from italy) i would like to know your opinion about this.
Thank you very much
Snaproll
Reged: 02/20/04
Loc: Green Bay
Re: CGE Pro Review new [Re: gio24]
      #4343539 - 01/27/11 09:20 AM
Wow, interesting video. Has it always been that way? Or did it just start? It sounds like the gears are binding. It is my understanding that the RA motor housing pivots to engage the gears. I was told that there are a couple bolts on the side that can be loosened and the engagement pressure between the gears changed. I have not tried it or looked at it so I don't know if this is true. It sounds like the motor is okm but just powering through an area where the gears are binding.
Hopefully there is a solution without sending it back to Celestron. The service experience I had with them with the original CGE was disturbing.
gio24
newbie
Reged: 01/26/11
Re: CGE Pro Review new [Re: Snaproll]
      #4343619 - 01/27/11 10:12 AM
thanks a lot for your kind answer.
I would like to try also to have more amps in order to give to the motors more power.
If it is possible can you detail what you where explaining about the bolts or tell where i can search?
gio24
newbie
Reged: 01/26/11
      #4343629 - 01/27/11 10:16 AM
another question if i can...
which maximum weight to you recommend should have a guiding scope in order to avoid problem to the mount during astrophotography sessions?
thank you again
Snaproll
Reged: 02/20/04
Loc: Green Bay
      #4343688 - 01/27/11 10:46 AM
I was told by one of the vendors that the RA worm may bind and that the housing can be moved by loosening two bolts. He suggested loosening one at a time. It was during a phone conversation and I never did try to adjust the motor housing so that is as much as I know. I don't know which two bolts he is talking about, I never looked closely at the mount to find them. I'm just passing on what I heard but have no first hand knowledge of.
The mount is rated for 90 lbs but a good rule of thumb is to only put 2/3rds the amount of weight which would be 60 lbs. I am running a C14 with a 100mm f9 guidescope. The mount seems to handle the weight fairly well.
The mount is a good mount from a tracking standpoint, it does very well. When I got the mount it had two serious problems right out of the box. Once I got those solved and figured out how to run the cabling without getting it snagged up on all the knobs the rount is doing ok.
I also posted in the Mounts forum do direct those that may be able to help to this thread.
gio24
newbie
Reged: 01/26/11
      #4343747 - 01/27/11 11:16 AM
thank you so much!!!!
WayneJ
Reged: 08/20/09
Loc: West Chester, PA
      #4343752 - 01/27/11 11:17 AM
Excellent review and very, very accurate. I've had my CGE Pro for a year now and have suffered through the same head-scratching gaps in QC and questionable design choices regarding the knobs. On the flip side, this does seem to be a pretty solid mount that tracks as well as can be expected.
My *only* note is that you cannot properly evaluate the goto performance of the mount if you aligned it through the C14. I also run a C14 on mine and the alignment/goto performance is ok, but nothing special. However, when aligned through my refractor, the goto performance is spot-on. The mirror flop in the C14 seems to limit the accuracy of the pointing model to a small area around the target. I overcame this with the "Precise Goto" function... which works remarkably well.
Wayne
Snaproll
Reged: 02/20/04
Loc: Green Bay
Re: CGE Pro Review new [Re: WayneJ]
      #4344378 - 01/27/11 03:45 PM
Yeah, besides mirror flop there are flexture issues as well (saddle plate etc). Plus the C14 has such a long focal length and narrow field of view. Still, the accuracy does appear to "drift". I can do a goto on a star, slew off of it, then a goto right back to the same star and it will be "off". The repeatability of the encoders seems ok, in other words repeatedly slewing back to the same star after a sync and the error seems to be repeatable, it misses the target by the same amount each time. (Mount calibration etc done).
To be honest, the few CGE Pro folks that I have talked to, (don't know many) but every one of them has some "problem" with the mount right out of the box.
Candidly I asked a vendor friend of mine that sells them, "What's the real failure rate on the Pros?". He told me what he has experienced, and then said, "... and that's not for publication...".
I can only go on my own exerience, but it really gets me wondering if Celestron is going the same route as Meade. I sure hope they get a handle on customer service and ditch the "we're too big to fail" mentality. I had a lot of issues with getting the old CGE repaired. You have to pay up front for the repairs and there is no real 'delivery date' until you start procedings to get your money back. That tells me they either don't have enough people hired and trained, they are overloaded with warrantee repairs or they are having cashflow problems. It really concerns me once the Pro is out of warrantee. I certainly hope that they have straightened out their issues by then and/or are still in business.
      #4344537 - 01/27/11 04:52 PM
Great, fair and balanced review Jim.
Thanks for posting it!
(another) Jim
scope dog
Reged: 07/26/04
Loc: USA
      #4345056 - 01/27/11 09:28 PM
Sounds like the encoder. Hunting. Half way through the pulse begins to break up. "either the encoder lead is being pinched or something and the connection is broken on one of the encoder leads." when this occurs the computer will hunt and rev up to max speed looking for a pulse. Your job is to look and track the encoder lead from the RA motor" I believe it's just the RA motor". If you can plug the DEC into the RA motor and see if it does it. I don't have this mount but here is some info to try and track the problem down.
Snaproll
Reged: 02/20/04
Loc: Green Bay
Re: CGE Pro Review new [Re: scope dog]
      #4345083 - 01/27/11 09:42 PM
Good thought Jim.
frolinmod
Reged: 08/06/10
Loc: Southern California
      #4345261 - 01/27/11 11:02 PM
The Pro with this collar on the power cord eliminates this issue. It also makes it a little more difficult to replace the power cord with a shorter, heavy duty one unless you want butt-splice the original M connector and collar on it.
I'm not sure if these are what you are referring to, but you can buy size "M" (2.1mm x 5.5mm) DC coaxial plugs with locking collars from Mouser Electronics. They are part number 171-7391. I bought a bunch of these for use with my Paramount ME -- before I switched over to using separate through the mount wiring with Anderson power pole connectors.
KDizzle
Reged: 09/12/08
Loc: Woodinville, WA
      #4347794 - 01/29/11 02:52 AM
hello!
Thank you very much
I had a very similar issue (both ra and dec):
http://www.youtube.com/watch?v=qnTCU3BEBok
http://www.youtube.com/watch?v=tuEUiNuydTQ
I contacted the vendor who had a celestron rep call me the same day. they arranged for it to be shipped back. I was told it arrived there and was further damaged in shipping about three weeks ago... still waiting to hear back.
Luckily, it's pretty much been cloudy for the past to months anyway, so i'm not yet ready to complain and I have high hopes. I know sometimes things go wrong and so far the service and response has been great; so i have high hopes for getting it back and having it happily function when it does!
I'd recommend you contact you vendor and/or celestron. Dinkering around with the worm will probably impact your warranty.
Snaproll
Reged: 02/20/04
Loc: Green Bay
Re: CGE Pro Review new [Re: KDizzle]
      #4348141 - 01/29/11 09:45 AM
What you say is probably true about possibly voiding the warranty. Unless it's a simple fix or you know what you are doing, I would consider returning it, but there are risks there too.
The folks I know that have had Pros and problems got good service fairly quickly. My concern is for out of warranty repairs. What happens when the $5,000 dollar mount needs to be repaired out of warranty? I really got the impression "out of warranty, out of mind". That concerns me.
KDizzle
Reged: 09/12/08
      #4375819 - 02/10/11 03:08 AM
For what it's worth, I received my CGE Pro back today from Celestron. Everything seems to be running just fine on it now. I can't speak as far as the frequency of issue or anything like that -- but I own several Celestron products, and the this is my first issue with any of them. The service seemed great - several phone calls to let me know what the status was and everything seems to be in working order again!
Snaproll
Reged: 02/20/04
Loc: Green Bay
      #4376036 - 02/10/11 08:44 AM
I hope you find the same level of service when your Pro needs to be repaired out of warranty.
alrosm
Reged: 07/27/10
      #4381550 - 02/12/11 04:30 PM
Great review.
Tony Bonanno
Reged: 04/03/07
Loc: Santa Fe, New Mexico
Re: CGE Pro Review new [Re: alrosm]
      #4543976 - 04/25/11 08:30 PM
Very good review Jim. Balanced and honest. These are the kinds of reviews I like. I'm currently running a CGE and a CGEM (and a DOB too). My CGE seems to be working OK for my needs (10" Vixen VMC-260L). I've modified a couple of things on the CGE (cables, Casady saddle, etc.). I looked at the CGE PRO at the TSP a couple of years ago when it first came out. It really was TALL (I'm not). I still thought about it. But hearing about the QC problems and some of the design issues from a real user like yourself has reinforced my decision to stay clear of it for now.
JS999R
Reged: 12/07/11
Re: CGE Pro Review new [Re: Tony Bonanno]
      #5020035 - 01/16/12 04:37 AM
Excellent review. I recently bought a CG5 demo and it was defective. Basically stopped mid slew for no apparent reason. I exchanged it for a new one, paying the difference and it was at that time the vendor told me the ratio of failure out of the box for these units. I almost requested a refund after hearing the number. I can't recall the number, but it was unacceptable in anyone's book. That simply tells me Celestron's final check-out in manufacturing is non existent. Fortunately there is a warranty period, but as the OP stated, what happens after the warranty expires? Another indication that concerns me is the fact you have to pay up front before the service can be commenced, whats up with that? Is it good faith money or has Celestron experienced a great number of walk aways? I'm a pessimist so the cash flow suggestion is also a possibility. In my case during start up and afterwards I had issues getting the mount to align properly and I believe at this point it was nothing more than human error on my part. I've had two alignments in a row that were correct after doing the two star with four calibration stars using targets I pre-selected from Stellarium that I made sure were on both sides of the Meridian. I lost alignment another time when the scope ran into the controller holder, apparently the stepper motors stepped on themselves as a result. I got it back on track after repeating the two star alignment, but without calibration stars. Lastly, I agree with not overloading any mount, but there was a review posted on the CG5 where the mount was loaded down with 34 lbs of gear and according to the owner had no problems at all with it. The advanced GT CG5 is rated at 35 lbs, my point being maybe the numbers are on the conservative side just in case. Granted, I would like to know if the mount is still happy with 34 lbs on it's back a year from now. I have a plan to upgrade to a larger refractor and expect a max weight of 25-27 lbs, I think that will be under my own limit of how much weight to put on it with some room to spare if I ever wanted to attach a DSLR to it down the road.
BTW, this is the first time I've heard the term "fair and balanced" used in a factual context, if you catch my drift.
3 registered and 3 anonymous users are browsing this forum.
Moderator:  iceblaze
