Privacy Policy | Please read our Terms of Service | Signup and Troubleshooting FAQ | Problems? PM a Red or a Green GuÖ uh, User
John Miele
Reged: 05/29/05
Loc: North Alabama
IEQ45 Spreader Tray Rebuild new
      #4258792 - 12/19/10 04:33 PM Attachment (129 downloads)
My new Ieq45 mount came with a tripod spreader (as does other brand mounts) that leaves a bit to be desired from a functional POV. It essentially only makes line contact with the legs along the edge of the leg cutout. Itís plastic. It hits the legs too high to provide much stability. And it has no room at all to hold accessories. I decided the only way to remedy these issues was to make a completely new combination spreader and accessory tray. I unscrewed the threaded rod that holds the spreader from the bottom of the tripod head. I found a similarly threaded rod left over from another project that was 12 inches long. I bought a 1 inch thick x 15 inch diameter pine round from Lowes that looked about the right size to work well. I drilled three leg holes by tilting my drill press at a 30 deg. angle and using a 2 inch hole saw. This left little segments at each hole that had to be cut off with a coping saw. I laid out a pattern of 1.25 inch and 2 inch eyepiece holes and drilled them through along with the central hole. I then cut three short pieces of 1x2 red oak to use as stiffener ribs and screwed and glued them to the underside. I test fit the new spreader onto the tripod and took the pics here. The old spreader hit the legs only 4 inches below the pivot bolts. The new spreader hits 8 inches down. Not perfect, but much better. It also contacts the leg along the entire thickness of the wood. I put two thick washers under the spreader tightening knob to spreader the load out onto the oak ribs. This spreader feels very sturdy, is plenty stiff, and has lots of room for accessories. Iíll prime it and paint it and then turn it loose in the field! Ö John
Stock spreader shown first...
John Miele
Reged: 05/29/05
Loc: North Alabama
Re: IEQ45 Spreader Tray Rebuild new [Re: John Miele]
      #4258796 - 12/19/10 04:35 PM Attachment (90 downloads)
Drilling leg holes in new spreader...
John Miele
Reged: 05/29/05
Loc: North Alabama
      #4258798 - 12/19/10 04:36 PM Attachment (96 downloads)
New spreader next to stock. New threaded rod next to stock...
John Miele
Reged: 05/29/05
Loc: North Alabama
      #4258800 - 12/19/10 04:37 PM Attachment (83 downloads)
Underside of new spreader/tray...
John Miele
Reged: 05/29/05
Loc: North Alabama
      #4258804 - 12/19/10 04:37 PM Attachment (105 downloads)
Mounted on the tripod...
John Miele
Reged: 05/29/05
Loc: North Alabama
      #4258810 - 12/19/10 04:38 PM Attachment (77 downloads)
Lower side of attachment...
MDearingJaxFL
Astronomicus
Reged: 08/28/04
Loc: Florida
      #4258823 - 12/19/10 04:43 PM
Nice job, John........
:>) mark
tjay
Reged: 02/03/07
Loc: just outside of Toronto
Re: IEQ45 Spreader Tray Rebuild new [Re: MDearingJaxFL]
      #4259139 - 12/19/10 07:16 PM
Looks great John. Want to make one for my Nexstar Tripod? Please?
islandsteve11
Reged: 01/08/07
Loc: World Class LP of Las Vegas
Re: IEQ45 Spreader Tray Rebuild new [Re: tjay]
      #4259226 - 12/19/10 07:54 PM
John, both an excellent idea and execution!
Lane
Reged: 11/19/07
Loc: Frisco, Texas
      #4259824 - 12/20/10 04:32 AM Attachment (62 downloads)
Just get yourself the 2" and 1.25" Forstner drill bits and a hand drill to make the holes. That is all you really need. The 3 slanted slots on the sides require a drill press but you can actually make it work without them. You can just cut 3 v-notches with a hack saw. Made this one below in less than an hour. The circular pine board can be bought at Lowes. A little sanding and some clear outdoor varnish is all your need to complete the task.
tjay
Reged: 02/03/07
Re: IEQ45 Spreader Tray Rebuild new [Re: Lane]
      #4260194 - 12/20/10 10:55 AM
It looks like a good Christmas vacation project. Maybe I can score a drill press in a after Christmas sale.
LouP
Reged: 12/27/09
      #4260314 - 12/20/10 12:21 PM
Give it a few months and you will see these on the commercial market. I would pick one up after I get my iEQ45
LouP
SteveG
Reged: 09/27/06
Loc: Seattle, WA
Re: IEQ45 Spreader Tray Rebuild new [Re: LouP]
      #4260768 - 12/20/10 04:59 PM
Very nice - and you will love the wood eyepiece holes.
islandsteve11
Reged: 01/08/07
      #4261170 - 12/20/10 08:41 PM
I like the OP's 3 oak reinforcements under the the pine round since they are subject to warping, even without all the EP holes.
Lane
Reged: 11/19/07
Loc: Frisco, Texas
Re: IEQ45 Spreader Tray Rebuild new [Re: islandsteve11]
      #4261702 - 12/21/10 02:45 AM
Been using that one about a year and a half now on my CGEM and no warping at all. Also have one on my Sirius mount and no warping there either. As long as you apply a good outdoor varnish you should have no problems with warping. We have a lot of dew at our site and the water just beads up and wipes right off. I don't like the cross brace idea because it interferes with putting in more eyepiece holes and putting them where I want. But you do want to get a thick board to keep it from breaking when you tighten up the center bolt. The ones at Lowes vary a lot in thickness. I looked through whole stacks of them at several different Lowes locations to get a few boards that were about 1/2 inch thicker compared to the others.
John Miele
Reged: 05/29/05
Loc: North Alabama
      #4263521 - 12/21/10 07:58 PM
If you look more closely at mine, you will see there is plenty of room to add many more EP holes if desired. My EP hold pattern works for me.
I did not add the ribs to prevent warping. That round board is made from pine which is soft and about the worst wood you can buy from a strength standpoint. I added the ribs to provide strength and stiffness so that the center knob can be tightened down HARD like it needs to be to preload the tripod legs without any worry of breaking the plate...and I have no worries about that now ...John
John Miele
Reged: 05/29/05
Loc: North Alabama
Re: IEQ45 Spreader Tray Rebuild [Re: John Miele]
      #4359176 - 02/02/11 08:32 PM Attachment (61 downloads)
Update: Hereís a picture of the finished spreader. I finally primed it, painted it, and covered the top with white self adhesive felt. I like the felt because it absorbs moisture and keeps the surface from getting slick with dew. It also makes it a little harder for things to slide off and acts as a cushion of sorts. Itís white to make it easier to see the edges at night...John
24 registered and 42 anonymous users are browsing this forum.
