kbastro
Reged: 04/20/08
Loc: Running from Clouds
Anyone make a cheap but useable eq mount??? new
      #4358366 - 02/02/11 02:56 PM
This post is for another person, and they want to mount a camera and a 200mm lens on a cheap eq mount with a motor drive.
All the "driven" mounts seem to be in the 6$600 - $700+ range and she doesn't want to spend that much on something that may or may not work for her.
Can anyone reccommend a mount that can move a camera and track fairly well and cost in the $200 - $400 range???
kbastro
mcoren
Reged: 01/11/06
Loc: Virginia, USA
Re: Anyone make a cheap but useable eq mount??? new [Re: kbastro]
      #4358522 - 02/02/11 04:02 PM
$600-700 seems a lot for just a driven mount. Does she need GOTO? If so, that's probably what she'll need to pay.
If all she wants is an equatorial mount with tracking, a 200mm lens should be fine on something like an EQ-2 mount for $180 (9 lb payload rating). The motor drive is another $73, for a total investment of $253.
Falcon-
Reged: 09/11/09
Loc: Gambier Island, BC, Canada
Re: Anyone make a cheap but useable eq mount??? new [Re: mcoren]
      #4358651 - 02/02/11 04:44 PM
Having used an EQ-2 mount for AP I think there may be problems with that mount and a 200mm lens. Now my particular EQ-2 is 35 years old and rather beat up, so perhaps it performs poorly compared to new EQ-2 mounts, but I found the periodic error too large to successfully image at anything longer then about 90mm focal length with my mount.
A used CG-5, LDX-75, LDX55 or EQ-5 might be a good way to go. In fact there is a used CG-5 with dual axis drives on astromart right now that even includes a mod to allow autoguiding.
Alternately a new Skywatcher EQ-3 or Celestron CG-4 might work if you can find one with at least a RA drive. Sometimes "CG-5 Clone" mounts show up on ebay too that are basically the skywatcher EQ-5 or EQ-3.
It is possible that a well polar aligned brand-new well cared for EQ-2 would be perfectly fine at 200mm, but if it can be afforded one of the higher mounts would be more of a sure bet. For myself I used my beat up EQ-2 for about 4 months till I could afford a brand new CG-5 and have been able to do so very much more since I got it!
Ad Astra
Reged: 05/12/10
Loc: Riverside Co., California
Re: Anyone make a cheap but useable eq mount??? new [Re: Falcon-]
      #4358786 - 02/02/11 05:41 PM
Orion makes a camera tracking platform for about $200 ... teletrack??? something like that. It's on their website and designed to track a DSLR and a big lens (or a very small scope) easily.
Hope that helps!
Dan
Lane
Reged: 11/19/07
Loc: Frisco, Texas
Re: Anyone make a cheap but useable eq mount??? new [Re: Ad Astra]
      #4358956 - 02/02/11 06:57 PM
This music box tracker looks pretty cool.
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: Anyone make a cheap but useable eq mount??? new [Re: Lane]
      #4362140 - 02/04/11 02:19 AM
I'm using a Vixen GP that I got for $180. But then I attached Vixen MT-1 motors to it which cost $300. Not so good..
The Orion dual-axis drives can be had for about $110 and will bolt up to an EQ-5, CG-5, or Vixen GP. All will work well.
How long are the shots going to be at 200mm? I noticed that around that focal length, with an APS-C DSLR (Pentax K20D), a fairly accurate drift polar alignment is needed to avoid oblong stars even at 30 second exposure times.
neveruseforever
Reged: 11/25/09
Re: Anyone make a cheap but useable eq mount??? new [Re: orlyandico]
      #4362350 - 02/04/11 07:30 AM
For several years I have collected and kept updating a list of small equatorial mounts and their data:
http://www.mitbbs.com/article_t/Astronomy/31167323.html
It's in Chinese, but you can at least check the models and their official websites. All data is taken from internet so I don't guarantee anything. You need to do more research before you buy.
If people are interested I may make a english version in the future.
neveruseforever
Reged: 11/25/09
Re: Anyone make a cheap but useable eq mount??? new [Re: neveruseforever]
      #4362370 - 02/04/11 07:58 AM
If astrophotography with a camera lens is your primary purpose, the most popular mount I know are AstroTrac TT320X-AG and Eyebell CD-1. They are light and small, easy to carry for a long journey.
gnowellsct
Reged: 06/24/09
      #4362613 - 02/04/11 10:44 AM
I would look for a used super polaris with single axis drive. Greg N
dymy24
Reged: 07/28/08
Loc: Fayetteville, NC
Re: Anyone make a cheap but useable eq mount??? new [Re: gnowellsct]
      #4363183 - 02/04/11 02:59 PM
If the criterion are "track fairly well" and "hold a camera" and "cost in the $200-$400 range", then a Barn Door Tracker might fit the bill. They require assembly, but dozens of plans are available for free.
wasyoungonce
Reged: 06/07/07
Loc: Land Downunder
      #4363249 - 02/04/11 03:30 PM
Now that's a cheap good idea that entertains to boot!
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: Anyone make a cheap but useable eq mount??? new [Re: wasyoungonce]
      #4364452 - 02/05/11 04:21 AM
the trouble with the barndoor tracker and the OPT music box is that it would be hard to polar align.
i have noticed that at 330mm focal length, even a 30-second exposure shows oblong stars at 30 seconds, a drift alignment is needed.
dymy24
Reged: 07/28/08
      #4364758 - 02/05/11 09:29 AM
Wonder why that is? I've been able to take 60 second exposures on AltAz mounts at 400mm (prime) without too much field rotation. Does drift on an Eq mount with a rough polar alignment have a greater impact than field rotation an an alt az with no alignment?
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: Anyone make a cheap but useable eq mount??? [Re: dymy24]
      #4364786 - 02/05/11 09:39 AM
depends on your tolerance for oblong stars i guess... what i'm talking about is oblong stars at 1:1 on a 15MP APS-C sensor. of course at web resolutions the non-round stars aren't visible..
EDIT: i haven't seen field rotation but drift in an imperfectly-aligned polar mount shows up as a straight line. so even a tiny bit of drift causes the stars to elongate.
9 registered and 26 anonymous users are browsing this forum.
