rmallen
Reged: 09/30/08
Loc: Michigan
Atlas/Sirius Counterweight compatible with CG5? new
      #4383032 - 02/13/11 10:38 AM
Does anyone know if the Orion Atlas/Sirius 11 lb counterweight (#09863) will fit on the CG5? I need another counterweight for my CG5 mount and the Orion counterweight is on sale right now.
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: Atlas/Sirius Counterweight compatible with CG5? new [Re: rmallen]
      #4383087 - 02/13/11 10:59 AM
No. The Atlas uses an 18mm C/W shaft while the CG-5/Vixen GP uses a 20mm shaft.
I am using 2 Atlas weights on my Vixen but I had to have someone bore them out with a big honking drill bit.
rmallen
Reged: 09/30/08
Loc: Michigan
Re: Atlas/Sirius Counterweight compatible with CG5? new [Re: orlyandico]
      #4383098 - 02/13/11 11:05 AM
OK, thanks. Guess I will have to go with the Celestron CG5 weight.
ad701xx
Reged: 11/22/03
Loc: Oregon, USA
      #4383193 - 02/13/11 11:49 AM
The Orion Skyview Pro counterweights (#07384) are on sale also and fit the CG5. Why not order those?
Edited by ad701xx (02/13/11 11:50 AM)
rmallen
Reged: 09/30/08
Loc: Michigan
Re: Atlas/Sirius Counterweight compatible with CG5? new [Re: ad701xx]
      #4383257 - 02/13/11 12:17 PM
Thanks Dave. Unfortunately, it looks like the Skyview Pro counterweights are only 7.5lb and I need a little more weight than that.
ad701xx
Reged: 11/22/03
Loc: Oregon, USA
      #4383295 - 02/13/11 12:30 PM
Sorry, I read your post too fast and missed the 11 lbs part.
Jeff in Austin
Reged: 02/26/07
Loc: TEXAS
      #4383649 - 02/13/11 02:48 PM
I'm using the Atlas and CG5 counterweights on my Atlas. One of them has a plastic sleeve, I think thats the Atlas one. The sleeve pops out easily.
Here are some diameters I measured today: CG5 shaft is .780, Atlas is .710. CG5 weights have a .815 opening, Atlas has .800 if the sleeve is popped out, .715 with the sleeve.
vinnie
Minister of Misinformation . . . Oh Yes
Reged: 01/05/08
Loc: Queensland, Australia
Re: Atlas/Sirius Counterweight compatible with CG5? new [Re: Jeff in Austin]
      #4383982 - 02/13/11 05:28 PM
That's correct Jeff
All Synta CWs are bored to suit the 20mm shaft which is the shaft size for CG5/EQ5/EQ3. Those sold to suit the 18mm shaft as fitted to EQ6/HEQ5 (Atlas/Sirius) simply have a plastic sleeve fitted which is easily removed.
rmallen
Reged: 09/30/08
Loc: Michigan
Re: Atlas/Sirius Counterweight compatible with CG5? new [Re: vinnie]
      #4384276 - 02/13/11 07:43 PM
Thanks guys. I ended up ordering the CG5 counterweight. I found one at a reasonable price with free shipping. It was only $1.64 more than the price for the Orion weight after figuring in the shipping.
RandallK
Reged: 11/10/06
Loc: Nanaimo, B. C. Canada
      #4388102 - 02/15/11 01:22 PM
I always put my finger inside the counterweight hole when when I loosen the knob to dismount or mount it so that sleeve doesn't come out. I think all the Synta weights have the same potential problem.
Mary B
Reged: 05/21/10
Loc: Minnesota
Re: Atlas/Sirius Counterweight compatible with CG5? [Re: RandallK]
      #4388587 - 02/15/11 05:27 PM
It fits with the plastic spacer out. Just put one on my CG5.
28 registered and 51 anonymous users are browsing this forum.
