Make-it Better
Reged: 06/30/07
CGE power connection
      #4396003 - 02/18/11 10:11 PM
Does anyone know for certain if the CGE power connection is "center positive" or "center negative"?
Thanks in advance,
Roy
mclewis1
Thread Killer
Reged: 02/25/06
Loc: New Brunswick, Canada
Re: CGE power connection new [Re: Make-it Better]
      #4396004 - 02/18/11 10:13 PM
Absolutely center positive, and the dimensions are 2.1 x 5.5mm
Make-it Better
Reged: 06/30/07
Re: CGE power connection new [Re: mclewis1]
      #4396006 - 02/18/11 10:15 PM
Thank you very much Mark.
Roy
SkipW
Reged: 02/03/11
Loc: Oklahoma, USA
      #4422697 - 03/02/11 11:20 PM
Thank you for the exact info, Mark. I presumed that the same connector was also used to power the Celestron CG-5 Advanced series mount, and it is.
I looked for that size connector on the Radio Shack website and saw it's an enercell size 'M' Adaptaplug Tip (273-344). With their Car Power Adapter (270-048) it works a treat on the CG-5. With your exact dimensions, I knew precisely what to look for.
I couldn't get the stock DC power cable to work at all with a 7 Ah 12V power pack I picked up from Walmart. Naturally, I thought it was a problem with that cheap power pack, but the included cable didn't work with my (not cheap) car power outlet, either. The CG-5 worked perfectly with a Celestron AC adapter, so I knew it wasn't a problem with the mount itself. Replacing the Celestron 12V cord with the combo from RS, the CG-5 works well.
After successfully trying the replacement DC adapter, I measured the resistance of the supplied adapter... 6 Ohms on the positive lead and 5 Ohms on the negative! Yikes! No wonder it didn't work! The new RS plug cord and tip measures much less than one Ohm on each side.
I just noticed that the Adapter packaging has a sticker on it that says that one Adaptaplug Tip is included in the $12.99 price... neither I nor the clerk noticed this in the store. Now to see if I can get my $6.99 retail for the 'M' Tip back.
[Edit] They cheerfully refunded the $6.99 plus tax today.
Edited by SkipW (03/04/11 12:09 AM)
Arbacia
Reged: 04/18/07
Loc: Madrid, Spain
Re: CGE power connection new [Re: SkipW]
      #4423343 - 03/03/11 09:26 AM
Center +
If inverted, simply doesn't work. No damage as it is protected.
Check the volts of the power suply. Some 12v power suply are not 12v output but 15-16v for charging 12v batteries.
17 registered and 30 anonymous users are browsing this forum.
