atelierbks
Reged: 01/29/09
Loc: St. Marsal, France & Grahamsto...
Using Giro-type AZ mounts on a wedge
      #4396398 - 02/19/11 05:03 AM
I'm thinking of mounting my Giro 3 on an AstroTrac ATTW3100 wedge (http://www.teleskop-express.de). Anyone have thoughts whether flat-bearing-surface AZ heads of the Giro type can work smoothly & accurately while being rotated significantly off-vertical? I want to minimize elevation compensation while tracking for extended periods. The carried mass would be OTAs of about 15 to 18 lb.
bg2468
Reged: 02/22/05
Loc: Southern California
Re: Using Giro-type AZ mounts on a wedge new [Re: atelierbks]
      #4397356 - 02/19/11 04:11 PM
Douglas....A great question and I wish someone would chime in with an answer. I have a Linhof tripod head (which I took apart to use the bottom plate) and wondered the same thing. This head is just like a wedge and pretty strong. If I ever put it back together I'll pm you with the results (I have a Giro).
Bob
mercedes_sl1970
Reged: 12/02/05
Loc: Canberra, Oz
Re: Using Giro-type AZ mounts on a wedge new [Re: bg2468]
      #4398641 - 02/20/11 05:23 AM
Bob
Hello Bob - I'd be interested to hear about this as well (another Giro user). Can you post your results?
Andrew
dscarpa
Reged: 03/15/08
Loc: San Diego Ca.
      #4404439 - 02/22/11 06:32 PM
I think you might have to keep the axis so tight to keep it from rotating that it wouldn't track smoothly. My Giro isn't sensitive to being level but my WO EZ and AZ4 are. I can't tighten the EZ enough to keep it from rotating if it's a little off level. When the AZ4 isn't level I can tighten the axis to keep it from moving but tracking smoothness is compromised. David
ScottW
Reged: 05/05/05
      #4405779 - 02/23/11 11:19 AM
I think I read once that this should not be done with this mount. I can't recall why but it did have something to do with the design.
I could be wrong, too.
12 registered and 32 anonymous users are browsing this forum.
