bykhed
Reged: 10/22/07
Loc: Westminster, CO
Convert cine motorized alt-az head for telescope? new
      #4404162 - 02/22/11 04:17 PM Attachment (33 downloads)
I recently acquired a heavy duty motorized alt-az head designed for cine (movie-making) use. It's a Houston Fearless RCH pan-tilt unit and has a wired remote for the axis motors.
My evil plan is to convert this to use with a telescope. Possible stumbling blocks/questions are:
- I don't believe there are clutches on the drives. How difficult would it be to add clutches?
- The seller said the drives operated slowly, which make sense for both camera and telescope use. How difficult would it be to make a controller that can operate the motors at variable speeds?
Any insights from the geniuses & craftsmen here would be appreciated. Thanks!
-Matt
Edited by bykhed (02/22/11 07:18 PM)
bykhed
Reged: 10/22/07
Re: Convert cine motorized alt-az head for telescope? new [Re: bykhed]
      #4404164 - 02/22/11 04:18 PM Attachment (29 downloads)
Another view of the head.
bykhed
Reged: 10/22/07
      #4404167 - 02/22/11 04:19 PM Attachment (24 downloads)
The wired remote - quite the deluxe job here!
Eddgie
Reged: 02/01/06
Re: Convert cine motorized alt-az head for telescope? [Re: bykhed]
      #4405549 - 02/23/11 09:05 AM
Are you sure that there aren't any clutches on it already?
Those big flat disks look like clutch plates. It could be that if you twist, they will move against drag.
If so, then it is just a matter of finding out hot to adjust the drag, which may mean partical dis-assembly.
If this were the case, the mod would likely be as easy as drilling a hole through the case and extenting the adjustment screw(s) with T-handle.
Otherwise, one gets into the situation where one has to realize that what is very easy to one person migth be impossible to many.
18 registered and 38 anonymous users are browsing this forum.
