JoshH
Reged: 11/07/08
Loc: Jefferson City, MO
Sky Commander interface with planetarium software new
      #4413096 - 02/26/11 02:12 PM
I am wanting in interface my Sky Commander with a Planetarium software program. I want the on screen display to follow where the telescope is pointing. I've seen this done before but I don't know how to set it up. I would like to use Starry Night as well since that is the software I have and am most familiar with.
Thanks, Josh
Reged: 07/06/07
Re: Sky Commander interface with planetarium software new [Re: JoshH]
      #4413116 - 02/26/11 02:27 PM
Thanks, Josh
Starry night uses the ASCOM interface. You need to download and install that along with the driver for the Sky Commanders. And you will need the proper serial cable, of course.
JoshH
Reged: 11/07/08
Re: Sky Commander interface with planetarium software new [Re: rmollise]
      #4413166 - 02/26/11 02:45 PM
I have the serial cable. I also have the ASCOM interface installed. Where do I get the drivers for the Sky Commander. I don't see it on the Sky Engineering Website. Unless it comes with the Boot Flasher software?
Reged: 07/06/07
      #4413195 - 02/26/11 02:57 PM
With the latest version of ASCOM, the driver should already be there. Just select "Sky Commander" with the ASCOM Chooser.
JoshH
Reged: 11/07/08
      #4413419 - 02/26/11 05:22 PM
Well I got it to work with Cartes Du Ciel, so that is progress. Starry Night says there are no telescope plugins installed. Have to work on figuring that out. Thanks!
Reged: 07/06/07
Re: Sky Commander interface with planetarium software [Re: JoshH]
      #4414563 - 02/27/11 10:09 AM
I'm not completely sure, since, while I have a copy of SNPP, I don't use it much, but I believe in the Starry Night world "plugin" = ASCOM. If you can't solve this you might want to check in with the Starry Night Yahoogroup.
14 registered and 32 anonymous users are browsing this forum.
