jnewton
Reged: 12/20/07
Suggestions for mount head for WO66 new
      #4423124 - 03/03/11 07:05 AM
What would be a good mount head for mounting my little WO66?
I have a good camera mount, but I want it to be able to point to the zenith. I have a good tripod. Looking at a Stellarvue M1 or M2.
Any thoughts would be appreciated.
gnowellsct
Reged: 06/24/09
Re: Suggestions for mount head for WO66 new [Re: jnewton]
      #4423150 - 03/03/11 07:22 AM
I think that stability is the most important thing in photography. You should be looking at the AP3600 or the Losmandy Titan at a minimum.
Good luck,
GN
jnewton
Reged: 12/20/07
Re: Suggestions for mount head for WO66 new [Re: gnowellsct]
      #4423250 - 03/03/11 08:35 AM
I am using the little scope for visual only.
Trev
Reged: 12/18/05
Loc: Fort McMurray, AB
      #4423277 - 03/03/11 08:49 AM
A mount with 100lb capacity for a 66mm scope? Definately wouldn't be undermounted...
The M1 is a nice smooth mount.
Ravenous
Reged: 11/14/09
Loc: UK
      #4423342 - 03/03/11 09:26 AM
Some camera tripod heads allow you to get to the zenith if you use the head backwards - in other words with the pan/tilt handle in front of the scope. Clumsy but you get used to it.
mak7
Reged: 09/29/07
Loc: light polluted Phoenix AZ
Re: Suggestions for mount head for WO66 new [Re: Ravenous]
      #4423814 - 03/03/11 12:52 PM
Your WO 66 is nice and light so a good camera tripod might do it well. To get something more substantial that would allow you to upgrade scopes to 80 or 90mm, take a look at Desert Sky Astro and their DSV-1. I have been very happy with it for several years for my WO 80FD. The head can be adapted to HD carmera tripods if you already have one.
http://www.desertskyastro.com/Mounts.html
Lots of choices out there so do your homework.
Brad
Jim7728
Reged: 04/10/05
      #4424487 - 03/03/11 06:30 PM Attachment (28 downloads)
Any alt/az setup with a panning handle for the 66mm will do. My favorite is the UA Unistar light.
I recommend using a extra long universal dovetail bar to help balance the heavy rear forward.
Reged: 07/06/07
      #4424550 - 03/03/11 07:02 PM
Synta AZ-4. A camera tripod is one of the _worst_ mounts for a telescope.
gnowellsct
Reged: 06/24/09
      #4424597 - 03/03/11 07:22 PM
Well really if you put it on a Losmandy Titan or AP1200 you won't need vibration damping pads. Greg N
mrki233
Reged: 03/14/07
Loc: Carlsbad, CA
      #4424642 - 03/03/11 07:38 PM
This and a sturdy tripod work well.
http://www.manfrotto.com/product/0/128LP/_/128LP_Micro_Fluid_Video_Head
The 128Lp is beefy enough to support the scope, but not too heavy. I use one with my AT 72ED and it works great. The head is not too expensive, either.
Pedestal
Reged: 03/11/06
Loc: Smoggy Bottom, Baytown,Texas
      #4424817 - 03/03/11 08:56 PM
I would recommend one of the various EQ-1's. You'd have the advantage of a real astronomical mount, and they are almost as light as a decent camera mount. With some, you can get a small battery drive also. I have a Celestron branded one, with a 9v battery powered drive. Very light, very easy to handle.
TONGKW
Reged: 01/16/07
      #4425209 - 03/04/11 12:29 AM Attachment (24 downloads)
If you prefer to stick to photo equipment, I would recommend a Manfrotto 410 gear head which is quite stable with my WO Zenith 80FD on it. The manfrotto 410 gear head has both quick positioning and slow motion on 3 axes and can reach zenith with no problem.
http://www.adorama.com/BG3275.html
K W TONG
C8+CG5 GT, TSA102+HEQ5 PRO, MK67+Voyager, NexStar 6SE, C5+Mizar K, WO ZS80FD+Kenko NES, Megrez 72FD+Kenko KDS, Mini Borg 50, PST
MikeB 2
Reged: 02/28/05
Loc: Bidwell, OH
      #4430321 - 03/06/11 02:53 PM Attachment (26 downloads)
I like my Vixen Mini Porta Mount with my WO66.
Ed Wiley
Reged: 05/18/05
Loc: Kansas, USA
Re: Suggestions for mount head for WO66 [Re: MikeB 2]
      #4431326 - 03/06/11 11:46 PM
I ditto the Desert Sky mount, I have one for my WO66. BUT, get the long dovetail, not the stock one. You will need it if you have a 2" star diagonal and something like a Panoptic.
Edited by Ed Wiley (03/06/11 11:48 PM)
27 registered and 45 anonymous users are browsing this forum.
