Megawatt
Reged: 05/02/09
Loc: Flamborough, Ontario
EQ mount for beginner? new
      #4434786 - 03/08/11 12:27 PM
I am often asked for purchasing advice by people looking for their first telescope. My experience is almost exclusively with manual al-az mounts and I've never even laid a finger on an EQ mount, but I see many entry-level refractors, reflectors, and Maksutovs equipped with mounts like EQ1 and EQ2. How suitable would such a setup be for a beginner? Advantages and disadvantages? I want to give sound advice but my experience is lacking here.
bbbriggs
Reged: 04/10/09
Loc: Graham WA
Re: EQ mount for beginner? new [Re: Megawatt]
      #4435161 - 03/08/11 03:12 PM
I have an EQ1. It is suitable for a PST Solar Scope are a very small refractor but not much else. I have a Televue ranger and a PST that it works great with.
Megawatt
Reged: 05/02/09
Re: EQ mount for beginner? new [Re: bbbriggs]
      #4435348 - 03/08/11 04:29 PM
How about ease of use? Are EQ mounts tricky to figure out or pretty self-explanatory?
Bart
Reged: 05/28/06
Loc: Somewhere near Charlottesville...
      #4435367 - 03/08/11 04:37 PM
No such thing as a beginner German Equatorial Mount [GEM] in terms of it being self explanatory. You simply have to get the manual and dig in. It can be intimidating, but eventually you'll figure it out.
Eddgie
Reged: 02/01/06
      #4435418 - 03/08/11 04:55 PM
Now I only use GEMS, but the FIRST question I would ask is "Why do you want a GEM mount?"
If the answer is NOT "I want a mount that tracks the target" then you may find little benefit in a GEM mount.
There ARE some benefits, but they may not be worth the (not all that really) extra complexity.
First, GEM mounts are EASY to use. It doesn't SEEM like that would be the case, but they are.
The initial setup consists of setting the tilt of the polar housing (the main housing of the mount) back so that it is at an angle to the ground for your latitude. Most have scales, and even if these scales are not all that accurate, they will get you close enough for motorized tracking.
Once you have that, you only need to point it at the North Star (not as accurate as a polar alignment, but good enough for tracking).
When you have it set up, you train your telscope on a target, lock the levers on the two axises, flip a switch, and the mount starts tracking the target.
Now, if you want to use a manual GEM to LOCATE targers, that is an entirely different ball game. Here, the mount has to be set up carefully and the setting circles have to be adjusted. You may have to do things like shim the OTA to remove Cone Error.
All of this can be done, and in fact 30 years ago, if you used a GEM, it was pretty well required for using the setting circles to locate objects.
There is a simple joy to this, similar to flying a plane using dead reckoning. I enjoy both activieies, but the fact is that if I am serious about navigation, I use electronic aids, and if I am serious about finding targets, I use a go-to scope.
But I know HOW to use setting circles, and it can be tedious to learn.
So, it really depends on your desires. If you just want a mount that tracks the sky, a simple GEM will do (though I would recommend a CG4 or CG5, or Vixen Polaris/SP/GP).
If you want a manual mount that can also be used to locate targets, depending on the telscope, one of these might work (the Polaris actually has quite good setting circles), but if the scope is a longer focal lenght scope, you may want to move to a GM8 because these mounts have large, usable setting circles.
Otheriwse, I would go with a Go-to mount. They have gotten very inexpensive, and you have both motors already built in.
You don't NEED to use the Go-To. Most have a way to quickly get them tracking
That way, you have motors for moving the mount and never have touch a knob, which almost always induces shaking.
So, using an EQ mount is pretty easy if you just want tracking.
Using an EQ mount to FIND things has a learning curve.
You don't NEED a Dec motor on an EQ mount, but by the time you add one, you might do better just bying a Go-to mount.
Bart
Reged: 05/28/06
Re: EQ mount for beginner? new [Re: Eddgie]
      #4435427 - 03/08/11 04:59 PM
Like I said, it can be intimidating......
Megawatt
Reged: 05/02/09
Re: EQ mount for beginner? new [Re: Bart]
      #4435847 - 03/08/11 07:41 PM
Thanks, that's a great explanation.
MikeBOKC
Reged: 05/10/10
Loc: Oklahoma City, OK
      #4436007 - 03/08/11 08:43 PM
I think the OP's question also involved what to tell people who were considering a first scope that comes equipped with an EQ mount. IN fact a lot of fairly entry level scopes do. But many dealers will also sell the OTA separately allowing many of those scopes to be placed on,for example, one of the |Nexstar alt-az mounts.
The truth is that the learning curve is steeper on an EQ mount because of the need to polar align and the motion in both axes, which is somewhat counter-intuitive to folks used to "up-down, left-right." Unless a beginner was truly interested in AP or in starting with a truly high end scope I would tend to steer them to a model that does not come with an EQ mount. I really hate the thought of someone trying this hobby, getting frustrated by the more complex demands of the |EQ mount and leaving it in the garage to gather dust.
Megawatt
Reged: 05/02/09
Re: EQ mount for beginner? new [Re: MikeBOKC]
      #4436877 - 03/09/11 08:06 AM
Thanks Mike, that is what I wanted to know. I am more inclined to recommend a manual alt-az or affordable GoTo, I think.
MikeBOKC
Reged: 05/10/10
      #4436890 - 03/09/11 08:22 AM
I would add that if you know someone who is a skilled tinkerer (like woodworking or working on cars) they likely would not be as intimidated by an equatorial setup. It's really an individual thing. My first scope was on an equatorial mount so I had to learn it, but overall I prefer the simplicity of alt-az today.
EricJD
Reged: 07/24/07
Loc: Chesapeake VA
      #4437010 - 03/09/11 09:44 AM
My first telescope was a Celestron 80mm on a manual EQ2. Took me forever to learn how to properly use the thing.
richardr
Reged: 11/07/06
Loc: Seattle, WA
Polar alignment is hardly difficult for visual new [Re: MikeBOKC]
      #4438227 - 03/09/11 06:55 PM
I just find the pole star and kind of point the viewfinder in its direction while setting up the tripod. It allows the planets and the moon to track for reasonably long periods for visual while using high power eyepieces.
DavidD
Reged: 07/23/09
Loc: Phoenix, AZ
Re: Polar alignment is hardly difficult for visual new [Re: richardr]
      #4438912 - 03/10/11 12:23 AM
I have an EQ2. I have the angle set using a digital level. Once set, it doesn't need to be messed with, unless you travel elsewhere with your scope. I eyeball north.
The difference between using this, and a manual Alt-Az is, once you find an object, on the Alt-Az mount you have to continually tweak both directions to keep your object in view. On the EQ, you only have to tweak one (realistically, you have to tweak the dec to make up for poor eyeballing). In the end, I added an RA motor to do automatic tracking.
For some reason, I like having my reflector on the EQ2. I've since bought an Alt-Az for my refractor. Logic would probably say that most people would flip the two setups. Both with fit on either, though, so I have the flexibility to do what I want.
One note....this isn't true for all EQs, but mine can be set so that it's actually working as an Alt-Az. I used it that way for several sessions until I got the mount figured out and started to understand how the EQ worked.
David
watcher
Reged: 11/21/07
Loc: St. Louis, MO
Re: Polar alignment is hardly difficult for visual [Re: DavidD]
      #4439513 - 03/10/11 10:16 AM
Never had a problem with the first scope I ever owned being an EQ mounted 8" SCT. Always seemed more intuitive to have a single axis follow the motion of objects in the sky. Manual alt az mounts seem rather more clumsy. Ever try to draw a circle with an Etch-a-Sketch?
To the beginner question though. Almost all beginner scope/mount combinations are under mounted. I wouldn't recommend less than an EQ-3 for almost any scope. Even a short 80mm refractor or 90mm Mak will have some focusing jitters on an EQ-2. Not a frustration that a beginner needs.
27 registered and 43 anonymous users are browsing this forum.
