shams42
Reged: 01/05/09
Loc: Kingsport, TN
an Atlas guiding experiment
#4445873 - 03/13/11 12:40 AM Attachment (73 downloads)
I've been imaging with a Meade SN6 but have thinking about moving up to a 8" f/4 Newtonian. I wasn't sure how my Atlas would handle the load, so I borrowed a similar scope from a club member. I did a 45 minute guide test with each scope back to back and did some analysis using the PhD log and a statistics package. I computed distance from the target centroid using the good old Pythagorean theorem at each log entry (sqrt of dx^2 + dy^2) and did an analysis of guide performance using that metric. Results are attached.
I'm guiding with the SSAG and 50mm finder.
You can see that the guide performance was basically identical for the 13 lb SN6 versus the ~18-20 pound 8" Newt. I also had to add another counterweight for the Newtonian, so the mount had quite a lot more weight on it in that configuration.
Seeing was poor tonight (2/5 by CSC), so absolute guide performance wasn't great.
Edited by shams42 (03/15/11 10:33 AM)
AstroGabe
Reged: 01/10/10
Loc: SE Wisconsin
Re: an Atlas guiding experiment
[Re: shams42]
#4446929 - 03/13/11 02:25 PM
Very cool analysis. What analysis package are you using? The plot looks like something R would give. I've been thinking of doing something similar, but haven't had time to do it. Would you mind making your analysis script available?
Jeff in Austin
Reged: 02/26/07
Loc: TEXAS
[Re: AstroGabe]
#4448046 - 03/13/11 11:34 PM
Is Distance in pixels or arcseconds? Is the top one the SN6?
Very interesting analysis. I recently moved from a 29.5 lb guide scope setup to a 22 lb OAG setup and my guiding improved incredibly, mostly due to flexure elimination. Also on the Atlas. Are you using OAG?
Edited by Jeff in Austin (03/13/11 11:48 PM)
shams42
Reged: 01/05/09
Loc: Kingsport, TN
[Re: Jeff in Austin]
#4451235 - 03/15/11 10:32 AM
The top chart is the 8" f/4 Newt, the bottom is the SN6. I'm guiding with a piggybacked 50mm converted finderscope and SSAG. The distance is measured in pixels @ 5.4" / pixel.
AstroGabe, the analysis was done in SAS but I could write a R script to do this if there was sufficient interest.
Gregk
Reged: 11/19/06
Loc: Gilbert Arizona
[Re: shams42]
#4456962 - 03/17/11 11:02 PM
Mind posting your PHD Brain configuration numbers
shams42
Reged: 01/05/09
Loc: Kingsport, TN
[Re: Gregk]
#4456998 - 03/17/11 11:30 PM
RA Aggr: 85 RA Hysteresis: 15 Dec guide mode: Auto Dec algorithm: Resist switching Max Dec duration: 1000 Calibration step: 3000 Min motion: 15
Gregk
Reged: 11/19/06
[Re: shams42]
#4457095 - 03/18/11 01:15 AM
Thanks Taking notes .
I use a 135mm lens and a Orion SS guider here are mine
But I now have a CG-5mount
RA Aggr: 95
RA Hysteresis: 10
Max Dec duration: 400
Calibration step: 1600
Min motion: 15
Edited by Gregk (03/18/11 01:16 AM)
AstroGabe
Reged: 01/10/10
Loc: SE Wisconsin
[Re: shams42]
#4457712 - 03/18/11 11:51 AM
Thanks shams42, never used SAS. Would it be easy to translate to R? If there's not enough interest, perhaps you could explain to me via PM how the data was retrieved and I could write something.
kw6562
Authoritative Ignoramus
Reged: 06/25/08
Loc: MA
[Re: AstroGabe]
#4457913 - 03/18/11 01:25 PM
Nice analysis shams42 - I use JMP at work sometimes which I guess is part of SAS. Re: AstroGabe - This can be done in Excel also - use the FREQUENCY function to bin the data and STDEV to find the standard deviation (assuming it is a normal distribution). What is R? I'm not familiar with it...Clear skies --Keith
