Bill Possel
Reged: 02/24/08
Loc: Colorado
Discmount DM6 question
      #4446303 - 03/13/11 09:24 AM
I'm considering a DM-6. I have a DM-4 on a Berlebach UNI 19C. Would this tripod work with the DM-6 also? Here are the specs on the UNI 19C -
- Weight: 15.65 lb.
- Transportation length: 38 inch
- Minimum height: 21 inch
- Maximum height: 70 inch
- Load capacity: 44.09 lb.
It's a terrific tripod for the DM-4 but is it sturdy enough for DM-6?
Bill
skybsd
Reged: 02/01/08
Re: Discmount DM6 question new [Re: Bill Possel]
      #4446549 - 03/13/11 11:48 AM
Hello Bill,
The DM-6 weighs 16.2lbs on its own - I'd get another, higher rated tripod, really.
skybsd
johnnyha
Reged: 11/12/06
Loc: Sherman Oaks, CA
Re: Discmount DM6 question new [Re: skybsd]
      #4448020 - 03/13/11 11:20 PM
I found even the Uni 24 was not enough, there was over 3 seconds of damping time with my 6" refractor. The DM6 tripod is much better.
mountain monk
Reged: 11/06/09
Loc: Grand Teton National Park
Re: Discmount DM6 question new [Re: johnnyha]
      #4448162 - 03/14/11 12:57 AM
I use the Planet and it is rock solid but heavy--the whole system is over 40lbs (with 8" extension, handle, etc). It stays on my screened in porch and I don't have to carry it far into the backyard--so it works great for me. YMMV.
Dark skies.
mm
variable111
Reged: 02/13/07
Re: Discmount DM6 question new [Re: mountain monk]
      #4449406 - 03/14/11 02:58 PM
The best tripod for the best mount: Losmandy G-11 tripod for Discmount DM-6
Specs:
with adjustable leg design. Height range from 33" to 48"
All heights are from ground level to top of tripod, vertical.
Carries up to 300 lbs. Fits GM 8, G-9, G-11 mounts.
Wt. 35 lbs.
mistyridge
Reged: 10/28/05
Loc: Loomis, CA
Re: Discmount DM6 question new [Re: variable111]
      #4449415 - 03/14/11 03:01 PM
I Ues the tripod that is sold with the DM-6.
7331Peg
Sirius Observer
Reged: 09/01/08
Loc: North coast of Oregon
Re: Discmount DM6 question new [Re: mistyridge]
      #4450734 - 03/15/11 02:14 AM
The DM-6 tripod is more than adequate for that mount. You can certainly use the G11 tripod under it, but unless you're putting something hefty, like a C11 on the DM-6 mount, you don't need that much capacity.
John
Bill Possel
Reged: 02/24/08
Loc: Colorado
Re: Discmount DM6 question new [Re: 7331Peg]
      #4450942 - 03/15/11 07:13 AM
Thanks for all th suggestions.
Portability is a major factor but so is stability. I would like to find a tripod which I could carry (with DM-6 attached) from the house to the backyard. A combined weight of 30 lbs would be nice, 40 lbs is ok, 50 lbs is too heavy.
Bill
mistyridge
Reged: 10/28/05
Loc: Loomis, CA
      #4451845 - 03/15/11 04:04 PM
My DM-6 plus the Discmount tripod weigh about 30 pounds.
Ed Kessler
Reged: 05/17/06
Loc: Millersburg, PA
      #4452492 - 03/15/11 09:30 PM
I use a Meade Field Tripod.
Meade Field Tripod + Losmandy adapter + homemade 8" extension + DM6
It's quite solid.
24 registered and 30 anonymous users are browsing this forum.
