hongxu chen
Reged: 02/14/11
GPS FOR EQ5
      #4448851 - 03/14/11 11:37 AM
Can my celestron cn16 gps unit be used to HEQ5?
hongxu chen
Reged: 02/14/11
Re: GPS FOR EQ5 new [Re: hongxu chen]
      #4450514 - 03/14/11 11:33 PM
Is there any one know?
Trev
Reged: 12/18/05
Loc: Fort McMurray, AB
      #4451293 - 03/15/11 11:10 AM
The CN-16 is only compatible with Celestron mounts, different programming than the Skywatcher mount.
hongxu chen
Reged: 02/14/11
Re: GPS FOR EQ5 new [Re: Trev]
      #4453753 - 03/16/11 01:32 PM
They are both made by same manufacturer. Have you test that before?
Trev
Reged: 12/18/05
      #4453923 - 03/16/11 03:08 PM
The programming that Skywatcher uses is not compatible with the Celestron programming even though they are made by the same manufacturer now, until Synta bought Celestron a few years ago the programs were developed independently.
mega256
Reged: 05/10/07
Loc: N of Tampa
      #4453953 - 03/16/11 03:24 PM
Check out EQMOD...may work with ur gps,,
Phil Sherman
Reged: 12/07/10
Loc: Cleveland, Ohio
Re: GPS FOR EQ5 new [Re: mega256]
      #4458851 - 03/18/11 10:29 PM
If your GPS outputs a standard NMEA (I think that's the correct acronym) data stream; then you can use it with EQMOD.
I have an old DeLorme GPS that uses a serial port and was, after making a little hardware box to initialize the unit, able to use it with EQMOD. The initialization box has a pushbutton that jumpers the unit's output into its input. Once initialized; the data stream is used by EQMOD to set your location and a "time offset" to correct the PC's clock.
I used the USB to serial adapter I use for my Canon camera's shutter control. Once EQMOD has set things up; I disconnect the GPS so the serial adapter is available for the camera. I rarely need the time correction because my PC's clock is set using NTP (Network Time Protocol) or my GPS corrected clock and is normally within a couple of seconds of the correct time.
Phil
14 registered and 31 anonymous users are browsing this forum.
