TimK
Reged: 01/21/06
Loc: Avon, OH
Looking for Alt-Az tracking mount
      #4454023 - 03/16/11 03:56 PM
I recently acquired an Orion 100mm F6 refractor and need a new mount for it. I would like a simple alt-az mount for grab and go (visual use) but I would also like to use this for outreach so tracking is mandatory.
I do not really want the added complexity of a goto mount. I have several but I want something simple here. I don't really want DSC's either. I want to visually locate an object, lock down the scope and let it track (at least for a while) without having to constantly nudge the scope. I would like positive locks so that overeager viewers won't move the scope off target and slow motion controls would be a real plus.
I have tried various EQ mounts and dislike the extended setup times required for accurate alignment.
I would like to keep the cost of the mount plus tripod under $1000.
Any suggestions?
Mark9473
Reged: 07/21/05
Loc: 51N 4E
Re: Looking for Alt-Az tracking mount new [Re: TimK]
      #4454077 - 03/16/11 04:21 PM
I'm really interested to find out if this exists, as it would perfectly suit my needs too.
I thought that for an alt-az mount to track, it has to be goto.
stevenf
Reged: 10/11/09
Loc: Vancouver, BC
Re: Looking for Alt-Az tracking mount new [Re: Mark9473]
      #4454158 - 03/16/11 05:07 PM
How about the Orion teletrack?
http://www.telescope.com/control/accessories/mounts-and-tripods/orion-teletrack-altazimuth-tracking-telescope-mount
TimK
Reged: 01/21/06
Loc: Avon, OH
Re: Looking for Alt-Az tracking mount new [Re: stevenf]
      #4455449 - 03/17/11 09:45 AM
I think I remember hearing about this one awhile back.
I checked the Orion website and downloaded the manual. It sounds pretty good but it won't track objects above 60 degrees (above the horizon). Even if it could I don't think a long refractor would work without the tube hitting the mount. But we are definitely on the right track.
Trev
Reged: 12/18/05
Loc: Fort McMurray, AB
      #4455818 - 03/17/11 12:18 PM
I know it's a goto but have you considered a Celestron SLT mount? They offer it with a 102mm f/6.5 so your scope should fit with no problems. You can still "star hop" using the HC and then let it track for you.
I have a couple of them so if you have any questions let me know.
http://www.celestron.com/c3/product.php?CatID=16&ProdID=661
MikeBOKC
Reged: 05/10/10
Loc: Oklahoma City, OK
Re: Looking for Alt-Az tracking mount new [Re: Trev]
      #4455964 - 03/17/11 01:27 PM
I got the SLT mount for my solar scope and now use it with a T|MB 92L and it works very well. Sowould either of the slightly larger Nexstar mounts, and they run from $300 to abuot $500. . . versatile and handy.
skybsd
Reged: 02/01/08
Re: Looking for Alt-Az tracking mount new [Re: MikeBOKC]
      #4455977 - 03/17/11 01:33 PM
Hello,
The NexStar SE mounts to indeed track, but the thing to bear in mind with mounting refractors to this mount is the OTA length and balance point.
You'll then need to be sure you understand and set the slewing limits so that your OTA won't slam into the mount base when slewing to targets close to or at Zenith.
Another option would be to use something like the APT Astro Wedge in order to mitigate against this.
skybsd
Kfrank
Reged: 12/20/08
Loc: Northern Colorado
      #4456185 - 03/17/11 03:14 PM
The OP wants this mount for an f6, 100mm scope focal length of 600mm).
The Teletrack (in addition to its 60 degree limit) is only intended for optical tubes up to 15" long and weighing 8.8 lbs or less. This limits its use to very short tube refractors or small Cassegrain type scopes (90mm Maks, etc).
It's a pretty limited use mount.
TimK
Reged: 01/21/06
Loc: Avon, OH
Re: Looking for Alt-Az tracking mount new [Re: Kfrank]
      #4465876 - 03/22/11 09:38 AM
Thank you for your comments and suggestions. It looks like what I really want doesn't exist yet!
Ira
Reged: 08/22/10
Loc: Mitzpe Ramon, Israel
      #4465908 - 03/22/11 09:51 AM
Get the Vixen PortaMount (II) and then the after market JMI drive for it. Should do exactly what you want.
/Ira
neotesla
Reged: 11/18/10
Loc: Canada
Re: Looking for Alt-Az tracking mount new [Re: Ira]
      #4465959 - 03/22/11 10:18 AM
iOptron Cube and Cube Pro or the mini tower is what I have been looking at, but there seems to be a quality control issue with them right now.
Fox1971
Reged: 01/27/09
Loc: Oregon
      #4466014 - 03/22/11 10:48 AM
You can get an astrotech voyager and then use the JMI train and track system. I believe that will give you what you want and at not too great a cost.
Ira
Reged: 08/22/10
Re: Looking for Alt-Az tracking mount new [Re: Fox1971]
      #4467347 - 03/22/11 08:54 PM
I am getting the iOptron MiniTower Pro with after-market upgrades by Steve Forbes to address the QC and reliability issues.
/Ira
TimK
Reged: 01/21/06
Loc: Avon, OH
      #4467382 - 03/22/11 09:18 PM
I checked the website and the JMI train-n-track sounds interesting.
I will have to give them a call for more details. On the Portamount or Voyager it could do the trick. I will let you know if this works out.
dscarpa
Reged: 03/15/08
Loc: San Diego Ca.
      #4468962 - 03/23/11 03:49 PM
I think the Porta would be over loaded with a 4" refractor. My Voyager on a Oberwerk tripod handles my 20lb WO ZS110 with ease. Let us know how your quest for tracking-goto with a stand alone alt az goes. David
DaveE
Reged: 12/08/10
Loc: Long Island, NY USA
Re: Looking for Alt-Az tracking mount new [Re: dscarpa]
      #4469004 - 03/23/11 04:03 PM
I tried a TV-102 on a Porta II and the mount could not handle it. Actually, to be more specific, the legs couldn't handle it. The head was fine.
-Dave
Ira
Reged: 08/22/10
Re: Looking for Alt-Az tracking mount new [Re: DaveE]
      #4469137 - 03/23/11 05:12 PM
The PortaMount head is quite robust. The stock legs are a bit iffy. They carry my 4" 2-element WO refractor, but it is fairly light. If it were heavier I would probably swap them for something stronger. Still, it's a sweet alt-az mount.
/Ira
AlienRatDog
Reged: 07/15/05
Loc: Ann Arbor
      #4469521 - 03/23/11 08:04 PM
Just add a wood tripod...works fine with my ED100 f/9...
TimK
Reged: 01/21/06
Loc: Avon, OH
Re: Looking for Alt-Az tracking mount new [Re: AlienRatDog]
      #4472997 - 03/25/11 09:47 AM
I have decided to pull the trigger on a AstroTech Voyager. It is a simple mount with slow motion controls which I like.
I also went to JMI and ordered the Train-n-Track unit. I am not exactly convinced this will work as I want it but it seems pretty close.
The testing begins next week.
Naviguessor
Reged: 08/06/08
Loc: MI
      #4474404 - 03/25/11 09:27 PM
Do keep us posted on its perfomance, very curious how it works out.
28 registered and 30 anonymous users are browsing this forum.
