BlueGrass
Reged: 07/25/09
Loc: Wasatch Front, UT
Re: What can I say - A Mach1 and Eagle new [Re: RAKing]
      #4450062 - 03/14/11 08:10 PM
Ron,
That's what I'm finding out about the Mach1. It seems to be very underrated for its class, the 40lb limit listed by AP being conservative. Given that I'll probably order the 1.87 extension so that it mates with the short shaft properly and another 10lb CW, that should balance my current OTA AP setups nicely. If the standard short shafts would join properly, there would be no need for the extension but there is about a 1/4" gap.
RAKing
Reged: 12/28/07
Loc: West of the D.C. Nebula
Re: What can I say - A Mach1 and Eagle new [Re: BlueGrass]
      #4451501 - 03/15/11 01:05 PM
I wondered what was wrong. The M12675 shaft extension should mate perfectly with the short shaft.
The 45 pound capacity is given for imaging loads. I've seen much greater visual loads on this mount.
If your sig line is representative of your imaging gear, you will be very happy with the Mach1. I use a C8 with an SV80S riding piggyback and the mount doesn't even break a sweat. When I come home from NEAF, I expect to have an 8 inch R-C in the trunk.
Ron
BlueGrass
Reged: 07/25/09
      #4451587 - 03/15/11 01:48 PM
Ron,
The short shaft threaded end is what keeps them from joining without the small gap. I'll probably sell the second shaft to help fund more weights.
Yes, an 8" RC is what my next imaging scope will be too. The AT8RC is a perfect package, just have been waiting a bit in case the price drops after NEAF. And of course, there have been 'other' expenses ... ROFL ....
Finally, had first light last night for 4 hours ... I'll post more later this evening with some Phd graphs .... It's been said, but needs to be said again... This is an impressive mount.
BlueGrass
Reged: 07/25/09
      #4452846 - 03/16/11 12:48 AM Attachment (41 downloads)
Mach1 first light –
Well, I’ve had the mount for almost two weeks now and finally had a chance to get it outside last night. The skies began to clear around 6pm but it looked like more clouds were coming in from the West. I thought: Right, there goes the CSC forecast….
After a brief nap and reading email, I checked the sky again around 8:30. Wow! Clear as a bell. I was tired after working all day but just couldn’t pass up this chance. If the forecast held, I should have at least 4 hours of cloud-free skies.
Looking over all the gear I wanted to setup and use, I decided to setup on the deck instead of in the yard. It had rained during the day and the grass was wet and cold. I’ve always had problems aligning and using my CGx mounts on my deck because of vibration and the deck boards flexing but really didn’t want to spend the evening in the mushy cold yard …
I was leery of how difficult setup and alignment would be, with the added instability caused by the deck. Just do it, I said … you have to get this puppy outside. You can’t let it sit in the den for another 2 weeks and then decide to do the initial setup away from home at a dark site with maybe something left behind ……
First off, let me say that the Mach1 and Eagle are easy to carry compared to my CGEM and its stock tripod. The Eagle is heavier than the CGEM tripod but is still easy to transport because of its design. The legs are held in-place by the center braces and don't flop around or bang into each other. The real advantage is the mount head itself. The CGEM head is heavier than the Mach1, probably due to it being rough cast instead of machined. It has always been a pain to pickup and carry. The Mach1 is lighter and stiffer in the axis so even if the clutches are loose, it doesn’t flop around in your arms ... :-)
I thought over the various ways given in the GTO manual for polar alignment or trying to use the Losmandy polar scope that came with the mount, but decided to try the first method listed in the manual. This involves sighting Polaris through the DEC bore hole and then using a sequence of slews and star alignments to adjust the mount's AZM and ALT settings to incrementally reduce the PA error. One very important point about this method. There is no initial GOTO slew to the first star that most of you who've used the Celestron firmware are familiar with. Instead, you manually move the OTA to the first alignment star and then the mount slews to where it calculates Polaris should be. This means that it's critical that you identify and know what star your using for the initial calibration slew to Polaris.
From a suburban sky, this is not a problem, but from a dark sky site where there are thousands and thousands of stars you can't see at home, it will be harder. So, for the initial alignment star, pick one that you can easily identify. I used Aldebaran. With this method, you can pick and choose what stars you want, until the mount begins to put Polaris in the cross-hairs of your reticule. On my first slew, the star was just slightly off center. I was amazed. I used another 3 stars just to check and refine the alignment and the final slew put Polaris dead in the center.
The next test I wanted to perform was guiding using PhD and my 9x50 SSAG setup. This was an important test since it's the lightest guide setup. All my ring assemblies and the C8 have a Vixen dovetail mounted on top to use this guider or to carry the AT65Q. If the 9x50 and PhD worked well, that means I could use it as the guider and piggyback it atop the AT65Q that would ride the AT106 or C8. The 65 and 106 or C8 could then be used strictly for imaging and not have to exchange roles to guide. Some mount their 9x50 in a finder bracket. I prefer to simply use a V clamp and rail that keeps it firmly inline with the imaging train. No flexure. I reset PhD to its default settings, picked a star in the west and began calibration. PhD ran through 15 steps W, E and then 15 steps N, S. Locked onto the star and that was it. Coming from the trials and tribulations of having to watch PhD during guiding with my CGEM, I sat there for some time. Here's a sample of the guiding:
Edited by BlueGrass (03/16/11 12:55 AM)
BlueGrass
Reged: 07/25/09
      #4452850 - 03/16/11 12:51 AM Attachment (40 downloads)
So for its first night out, the mount has met my expectations. Given AP's reputation, I expected nothing less. To be honest, it has exceeded my expectations in every respect. This is the guiding graph an hour and 30 minutes later. All tracking was done to the west since my house blocks the eastern sky. I don't think there will be much if any change in its performance tracking east. Balance is not that critical with this mount so having to balance heavy east may not even be a factor. My first dark site trip will answer my remaining questions. Until then, I'll have to content myself with lunar or cluster images since DSO imaging in the valley is disappointing.
I have yet to use the copy of PemPro I purchased to download and save the factory corrections for future use or to refine the mount's performance. At this point, given the guider setup I used, I don't see much point unless the performance changes over time.
I won't have any clear weather for the next few weeks to make a dark site trip worthwhile but by then I should have everything configured, balance settings made and the various equipment boxes and bags redone. The mount fits perfectly in the Pelican I used for the CGEM so that saves me that cost of a new case. Last weekend, I packed my CG5 and CGEM back into their factory boxes and stacked them in the basement. At some point, they'll be sold to help pay for the Mach1. I don't think they'll see much use from me, from this point on.
Edited by BlueGrass (03/16/11 01:09 AM)
BlueGrass
Reged: 07/25/09
      #4452888 - 03/16/11 01:27 AM
Oh and to expand on the problems of imaging off the deck. This mount and tripod handle and dampen vibrations very well, much better than the CGEM. I had learned to walk on the deck much like Kwai Chang Caine on rice paper, hoping to keep the vibrations to a minimum while moving back and forth during focusing or when changing the angle of the CCD. The Eagle, with its weight, low center of gravity and wide leg splay make this much less necessary. I used to have to wait for 3 or 4 loops during focusing for the vibrations to settle. Now, they're almost negligible.
mewmartigan
Reged: 07/02/08
      #4453358 - 03/16/11 10:38 AM
After reading this I really can't wait until those notifications go out for the new round of Mach1s.
I am also glad to hear you had a good experience on your deck. This is where I will do my first few imaging runs to familiarize myself before I travel somewhere.
RAKing
Reged: 12/28/07
Re: What can I say - A Mach1 and Eagle new [Re: mewmartigan]
      #4453610 - 03/16/11 12:26 PM
I guess I should mention that I also set up my stuff on the back deck.
My deck is very sturdy, but I still walk carefully when the camera shutter is open.
BTW - nice graphs. I have never bothered to check mine, but I can start up the mount, sync it up, go eat dinner, and come back to find the selected star right next to the crosshairs. That is good enough for me.
Ron
BlueGrass
Reged: 07/25/09
Re: What can I say - A Mach1 and Eagle [Re: RAKing]
      #4454828 - 03/16/11 11:01 PM
Ron,
I saw your deck in your excellent picture above and was wondering how it performed. This pier does seem to be a very stable platform. I don't think you'll find a better solution for a Mach1 unless of course you use a permanent pier, but that means no portability.
As for the graphs, next night out I'm going to try and capture the mount's unguided performance with the basic alignment procedure I used above. Obviously, it's not as accurate as a drift alignment, but if I can plot its uncorrected performance, this should give me a baseline on which to build. I think PhD can do this, just turn on Manual guiding and let it plot the uncorrected movements? I've never done this before and don't know if it'll work. If someone else has used PhD this way, please chime in ...
I don't think the weather will improve enough over the next few weeks to try and use PemPro to do any PEC testing or training. I'd want very good to excellent skies before attempting it. There appears to be a periodic bump in the RA graph above that PemPro should be able to smooth out. Just have to wait patiently for the weather to clear ...
18 registered and 32 anonymous users are browsing this forum.
