Privacy Policy |
Please read our Terms
of Service | Signup and
whduke
Reged: 04/22/08
Loc: Clayton NC
CGE Hand Controller Busted?
#4458334 - 03/18/11 04:53 PM
Well I took the scope out last night to try out the new cam, and focuser for the first time. I knew it was odd to have clear skies just after receiving the new gadgets. You guessed it the CGE hand controller is stuck in transmit data I have unplugged, and plugged in the hand controller several times, reupdated the firmware several times, and it still will not get off of the transmit data screen. Does anyone have some advice, or is the hand controller busted?
Thanks, Mitchell
mclewis1
Thread Killer
Reged: 02/25/06
Loc: New Brunswick, Canada
Re: CGE Hand Controller Busted?
[Re: whduke]
#4458346 - 03/18/11 05:03 PM
If you've been through the firmware update routine and it's still in the same mode I think it's time to have a look inside the HC. You may have a bad internal connection or a bad key, both of which can sometimes be fixed by re connecting the cables (there are a couple of flat ribbon cables that can be carefully removed and reinserted). The key pad areas can be carefully cleaned as well.
RTLR 12
Reged: 12/04/08
Loc: Capistrano Beach, Ca
[Re: whduke]
#4458362 - 03/18/11 05:08 PM
If the HC stays in 'Transmit Data' mode after you have downloaded new firmware, according to Celestron it is NG. I have not had this happen to me, but I have seen this problem explained on the Celestron's support site.
Stan
28 registered and 38 anonymous users are browsing this forum.
