luukieboy2
Reged: 05/01/10
PST or Lunt new
      #4464006 - 03/21/11 12:08 PM
Heey guys,
We've got some great wheather, with a lot of sun. 7-8-9 march where really nice days for watching the sun in white light. But I'm looking for something that can't be seen with white light. Do you know what I mean I want a H-alpha telescope. Being a student, I've got a tight budget. So that leaves me with the 35mm lunt or the 40mm PST. What would you choice?
Your help is appreciated,
Greetings from the sunny Netherlands,
Edited by luukieboy2 (03/21/11 12:35 PM)
brianb11213
Reged: 02/25/09
Loc: 55.215N 6.554W
Re: PST or Lunt new [Re: luukieboy2]
      #4464031 - 03/21/11 12:21 PM
Not a lot of difference IMO.
Edited by Don W (03/21/11 06:26 PM)
luukieboy2
Reged: 05/01/10
Re: PST or Lunt new [Re: brianb11213]
      #4464066 - 03/21/11 12:35 PM
I'm sorry for that, will change post immediatly.
jrcrillyAdministrator
Refractor wienie no more
Reged: 04/30/03
Loc: NE Ohio
      #4464194 - 03/21/11 01:45 PM
I've owned and/or used many of the popular Ha systems, including the two you mention. I'm a fan of full aperture etalons so I'd choose the Lunt 35mm if I were buying today, though I currently own a PST. The Lunt also specs a significantly tighter bandwidth which is a big help on surface detail, though at 35-40mm you'll probably be using it mostly on proms..
Phil Wheeler
Reged: 12/31/05
Loc: 3 miles WNW of Celestron
Re: PST or Lunt new [Re: jrcrilly]
      #4464326 - 03/21/11 02:44 PM
I'd go with the Lunt. All other things being equal, the Lunt is a newer design and has better build quality.
Phil
la200o
Reged: 09/09/08
Loc: SE Michigan, USA
      #4464399 - 03/21/11 03:15 PM
Haven't tried the Lunt. I find the PST to be a remarkable instrument for the price and I think the build quality is good, tho' not in the same class as my SM 90 (which is what one would expect).
Bill
Naturlich
Reged: 10/30/09
Loc: Dukinfield, Cheshire, UK
Re: PST or Lunt [Re: la200o]
      #4464515 - 03/21/11 04:07 PM
tbh I couldn't give a personal comparision since I've never looked through a PST. The LS35 is good visually, better on proms than surface detail, but actually good for viewing active regions on the surface if you give your eye time to adjust, thats when the LS35 starts to supprise you.
Imaging with the Lunt isn't too difficult either if thats what you would like to do and yields more detial than your eye can pick up.
The Deluxe model is a better purchase than the basic model, but solar disk size and image quality is pretty much identical except for the smaller FOV of the basic (which I personally find too small).
I read alot of reviews before buying the Lunt, just about all put it ahead of the PST, but as said, I have no personal experience with a PST.
Nat
Phil Wheeler
Reged: 12/31/05
Re: PST or Lunt new [Re: la200o]
      #4464635 - 03/21/11 05:08 PM
To be more specific, I think the PST focuser is worse than bad .. and imaging with a PST takes more trouble than it should. The 5 mm Blocking Filter is also limiting. Sure it's usable, and when first released it was a fantastic way to get into H-a. But the Lunt 35 is a better choice today.
la200o
Reged: 09/09/08
Re: PST or Lunt new [Re: Phil Wheeler]
      #4465089 - 03/21/11 09:01 PM
I don't image, so can't address that.
But. . . The PST focuser is simple and very precise. The BF is not at all limiting for visual. The optics of the scope seem quite good and I cannot imagine seeing more detail either on the surface or on the limb with a scope in this class, whoever the manufacturer. I'd think any improvement with the Lunt would be a matter of individual differences.
Maybe you had a bad one; the PST is still a fine choice.
Clear skies,
Bill
brianb11213
Reged: 02/25/09
Loc: 55.215N 6.554W
      #4465630 - 03/22/11 04:57 AM
Yes. OTOH the rotating helical focuser on the Lunt 35 is not the easiest to work with if you have a diagonal mounted, and it makes orientation of a camera difficult.
Like I said above, there's not a lot to choose (between "good" examples) - swings & roundabouts - personal preferences will have a lot to do with which you prefer. Just beg, borrow, steal (or, if the worst comes to the worst, buy ) one or the other & enjoy using it.
earl@hapb.net
Reged: 11/21/10
Loc: Garland, TX
      #4465670 - 03/22/11 06:17 AM
I use a PST for all my imaging. No problems getting it to focus and no trouble at all. You can't go wrong with either scope so if you are on a budget get the one that make sense for you. Look in the swap section of the forum and see if a h-a is for sale. That is probably the cheapest way of getting into h-a on a student budget.
Phil Wheeler
Reged: 12/31/05
      #4465709 - 03/22/11 06:49 AM
I ran across this comparison, which may be useful (and is pretty neutral in its conclusion).
http://stargazerslounge.com/archive/index.php/t-104723.html
I've never used an LS35. My negative comments on the PST are from having used one and finding it a bit "fussy" (e.g., focusing knob moves an internal prism and it also shifts the image). But the LS35 likely has its own problems (the helical focuser being one of them).
I suspect either scope would be a good entry point -- and I've seen some very nice images captured with each.
Montana
Reged: 01/02/10
Loc: Cheshire, UK
      #4465779 - 03/22/11 08:18 AM
I love my PST, I have never used a Lunt 35 so I couldn't compare but I don't think you would be disappointed with either. Certainly imaging is very easy with the PST if you use a webcam. I have never had a problem with the focuser, it is so delicate and precise and makes imaging a dream. I think the choice is yours.
Regards
Alexandra
luukieboy2
Reged: 05/01/10
Re: PST or Lunt new [Re: Montana]
      #4465813 - 03/22/11 08:56 AM
Thanks everyone, it is confusing to notice that both PST and Lunt produce'good' and 'bad' telescopes. You are just have to be lucky, if you want a good h-alpha telescope. But I think I've made my decision. It is gonna be a 35mm Lunt, probably gonna by it directly from Lunt, 499 Dollar --> 350 Euro's. In the Netherlands they cost 690 Euro --> 980 Dollars. I will ship them to a family in the USA. Can somebody explain me this price difference? Thanks a lot,
brianb11213
Reged: 02/25/09
Loc: 55.215N 6.554W
      #4465894 - 03/22/11 09:43 AM
No. I suspect someone is profiteering.
Naturlich
Reged: 10/30/09
      #4465934 - 03/22/11 10:02 AM
Good luck with your choice of scope luukie
If I may make a suggestion, pay the extra and get the deluxe version, I know you will enjoy the view and day to day use much more.
Nat
Fogboundturtle
Reged: 05/20/09
Loc: Burnaby, BC
Re: PST or Lunt new [Re: Naturlich]
      #4465941 - 03/22/11 10:07 AM
Just to add to this discussion : The wait time for an Lunt 35mm is currently 8 months according to Lunt.
highfnum
Reged: 09/06/06
Loc: NE USA
Re: PST or Lunt new [Re: Fogboundturtle]
      #4465944 - 03/22/11 10:10 AM
At this point in time go for Lunt
I have PST - at that time Lunt did not exist.
I have a Lunt CaK - based on that I would go for Lunt Ha
la200o
Reged: 09/09/08
      #4465954 - 03/22/11 10:14 AM
OPT lists the base model as in stock.
Bill
Montana
Reged: 01/02/10
Loc: Cheshire, UK
      #4466046 - 03/22/11 11:06 AM
Enjoy your little Lunt I am sure you will have years of fun and pleasure marveling at our lovely sun!
As to the price difference, that is what really upset me and put me off Lunt. I asked that exact question and received no comment back, so I buy another brand, that's the way it goes.
Regards
Alexandra
10 registered and 13 anonymous users are browsing this forum.
Moderator:  Phillip Creed, nitegeezer
