Bart
Reged: 05/28/06
Loc: Somewhere near Charlottesville...
Re: cast aluminum repair? new [Re: Midnight Dan]
      #4464516 - 03/21/11 04:07 PM
Post deleted by Bart
Midnight Dan
Reged: 01/23/08
Re: cast aluminum repair? new [Re: Bart]
      #4465004 - 03/21/11 08:10 PM
Check this page out on ADM's site:
http://www.admaccessories.com/V_Series_Saddle.htm
There's a variety of options here, one of which might fit your mount exactly. Just based on looks, the $99 VSAD-HEQ5 version has a circular base that might work on your mount.
I'd give Anthony at ADM a call. He's very helpful and if you talk to him I'm sure he can provide something that will work with your mount. Given the right dimensions, Anthony can actually make you up a custom adapter for the saddle - not sure what he'd charge though. Worst case, get the bare dovetail saddle for $69, and mount it to your circular base as mentioned above.
Added advantage - ADM parts are MUCH higher quality than most original parts!
-Dan
DavidD
Reged: 07/23/09
Loc: Phoenix, AZ
      #4465033 - 03/21/11 08:29 PM
I have both an ADM shoe and one of the OPT shoes. The issue is going to be the retro fit to your mount. Anthony at ADM is capable of custom making whatever you need - he made me one that fits my EQ2.
The OPT one I bought has a 1/4-20 center hole, but has other holes in the arrangement. I can't tell how large the center hole is on your shoe, but it looks larger than that. Thus, you'd have to drill a hole to match. I bought it to mount a finder scope.
I can send more info on the OPT shoe if needed (and BTW, it's a lot cheaper), though OPT should be able to provide the information for you. Email ADM directly for info on what Anthony can do for you.
David
TEDious
Reged: 05/19/10
Loc: Harrison Twp., Michigan, USA
Re: cast aluminum repair? new [Re: OzarksEric]
      #4465139 - 03/21/11 09:26 PM
I might be able to cast you a replacement....
Starhawk
Reged: 09/16/08
Loc: Tucson, Arizona
Re: cast aluminum repair? new [Re: TEDious]
      #4465507 - 03/22/11 01:30 AM
For $200, you can have twice the mount:
http://www.astronomics.com/main/product.asp/catalog_name/Astronomics/category_name/LRNUN3QEHVXV9JJ389JS82DRU0/product_id/CG-4
-Rich
orlyandico
Reged: 08/10/09
Loc: Singapore
Re: cast aluminum repair? new [Re: Starhawk]
      #4465711 - 03/22/11 06:52 AM
This fellow on the CN Ads Forum sold me a dovetail shoe that I put on my Vixen Polaris. The workmanship was rather rough, but heck it works and looks plenty strong (carried my Orion 100ED). And cheap-ish ($20 + Postage). You can email him tlee7@hotmail.com
Another option is to buy the GSO dovetail mount which is $43
http://agenaastro.com/gso-dovetail-mount-dovetail-bar.html
and somehow find a way to bolt it to your existing mount head.
charles1317
Open Mouth, Insert Foot
Reged: 03/05/10
Loc: Olympia, Wa USA
Re: cast aluminum repair? [Re: frolinmod]
      #4466050 - 03/22/11 11:08 AM
Repair of that saddle is problematic. The only solution I see is to grind the front and back of the saddle flat, pin the piece and then hold in place with a strap attached with three screws on each side and at least two going through the strap and the broken part into the main saddle casting.
I'm not making any judgment calls on if it's worth repairing, that's up to you. I just think it would be very difficult to do with any assurance that the repair would not fail and allow the scope to drop out.
Please let us know what you decide to do!
18 registered and 23 anonymous users are browsing this forum.
