yoram
newbie
Reged: 04/07/08
Degrease a stuck mount new
      #4475317 - 03/26/11 11:16 AM
Hi. After years in storage I came back to my Celestron CG4 mount and found it all sticky with grease.
The cylinder of the coarse movement is totally stuck in
place.
Anyone knows how to dissolve this grease. (it's the transparent type)
Thanks, Yoram
nemo129
Reged: 01/03/10
Loc: WMass
Re: Degrease a stuck mount new [Re: yoram]
      #4475400 - 03/26/11 11:50 AM
First of all, welcome to Cloudy Nights. Glad to hear you are taking out the astro gear!
I have used a Citrus based degreaser for this called ZEP. It has the advantage of being able to dispose of easily since it is water based and it is less dangerous than some of the alternatives.
bluedandelion
Reged: 08/17/07
Loc: Hazy Hollow, Western WA
Re: Degrease a stuck mount new [Re: nemo129]
      #4475576 - 03/26/11 01:30 PM
Read the label carefully. Some citrus based degreasers can harm rubber gaskets! If there are no rubber gaskets in the areas you are cleaning then ignore this warning.
I used Clean Streak when I regreased my Atlas.
http://www.whitelightningco.com/products/clean-streak.htm
Ajay
Don Trinko
Reged: 07/05/09
Loc: Ohio
Re: Degrease a stuck mount new [Re: bluedandelion]
      #4475784 - 03/26/11 02:57 PM
I have a TV EQ mount that had the same problem. I sprayed light oil into the mount and worked it back and forth. It took a lot of back and forth but It diluted the grease enough that is works easy and smooth again. Don T.
nemo129
Reged: 01/03/10
Loc: WMass
Re: Degrease a stuck mount [Re: bluedandelion]
      #4476145 - 03/26/11 06:40 PM
Hey, that's some neat stuff there. You are correct about being careful with the citrus based degreasers as they will degrade some polymers. I was thinking ZEP if the OP was going to take the mount apart and clean it. For cleaning in place the Clean Streak looks like a much better idea! Thanks for the link.
22 registered and 25 anonymous users are browsing this forum.
