Privacy Policy |
Please read our Terms
of Service | Signup and
Bowmoreman
Clear enough skies
Reged: 09/11/06
Loc: Bolton, MA
Re: PHD/SSAG question
[Re: dymy24]
#4466628 - 03/22/11 03:20 PM
DSS is WAY better/faster at post-processing (calibration of lights, darks, flats, stacking, etc.) than Nebulousity... you can fully automate the entire process...
When I use my QHY8 (OSC) camera, I use Nebulousity for capture, and then use DSS for post processing...
Now that I also have a QSI583WS, I'm having to learn Maxim DL5 instead... jury is still out...
But, thus far, I *miss* DSS...
HTH
kid
Reged: 06/21/09
[Re: Bowmoreman]
#4478321 - 03/27/11 07:10 PM
I met with the same problems recently. The way I fixed it is in the Mount manu choose "on camera" but not "ASCOM". Because the camera is controlling the mount, not the computer via ASCOM.
I have a question about SSAG/PHD as well and I wonder if I can post it here: When I am doing the calibration, firstly I believe it moves along RA from the original position and come back to cailbrate RA movement; This step works fine. Then it moves along DEC for about 60 steps, but it can't come back, and waring shows:"DEC calibration failed: Turning off DEC guiding". Does anyone knows what's the problem? Should I increase the calibration step in the brain manu?
Reged: 07/06/07
[Re: kid]
#4479033 - 03/28/11 06:00 AM
Yes, try increasing calibration steps. The problem is usually dec backlash.
kid
Reged: 06/21/09
[Re: rmollise]
#4479663 - 03/28/11 01:17 PM
THX Rod,
I tried yesterday and now here's the issue:
I increase the calibration step longer, from 1s to 15s. Now after N calibration it will return and do S calibration, but I guess because of the DEC backlash the star doesn't move a lot, and it won't come back to the original point before it starts guiding. So, during the guiding, the RA curve fluctuate along x-axis, while the DEC curves gradually drops with generally a constant slope...
23 registered and 40 anonymous users are browsing this forum.
