Privacy Policy |
Please read our Terms
of Service | Signup and
RenoNV
Reged: 12/01/10
Loc: South South Reno
CG-5GT : Setting declination in User Database
#4494954 - 04/04/11 01:53 AM
HC firmware 4.16 (don't have an upgrade cable yet)
I wanted to add some objects to the hand controller via the user database found under Menu. I was able to select the database slot, add the Right Ascension, but with the Declination, I couldn't get the hand controller to stop blinking the "+". None of the numbered keys worked, and the arrow keys just stopped the blinking, but didn't advanced to the numeric value.
So what key selects "+" or "-" declination in a user defined goto?
TIA
RTLR 12
Reged: 12/04/08
Loc: Capistrano Beach, Ca
Re: CG-5GT : Setting declination in User Database
[Re: RenoNV]
#4494992 - 04/04/11 02:38 AM
Press the up and down key to select '+' or '-' then press the 'Enter' key to lock it in. You can then proceed with entering the rest of the numbers.
Stan
RenoNV
Reged: 12/01/10
[Re: RTLR 12]
#4495178 - 04/04/11 07:08 AM
Thank you Stan,
I should have tried that, I could have always pressed Undo if it didn't work.
22 registered and 24 anonymous users are browsing this forum.
