Don.Key
Reged: 10/14/10
Loc: Alps
2" Filter Wheel with visual back / for visual use
      #4496599 - 04/04/11 07:59 PM
I would like to equip my scope with 2" filter wheel for use with 2" UWA EP's.
Ideally, this would be same mechanism as with 1.25" wheels where front / scope side has a tube which goes into diagonal (male) and back / EP side has a tube into which EP is inserted (female), also called visual back.
Unfortunately something like this does not seem to exist at all for 2" filters. I purchased a used Orion 2" filter wheel just to find out that it lacks visual back or as orion states: "not intended for visual use"
Is there a way to add a female visual back to orion 2" wheel or is there a 2" wheel which comes with a visual back?
Edited by Don.Key (04/04/11 08:03 PM)
Arbacia
Reged: 04/18/07
Loc: Madrid, Spain
Re: 2" Filter Wheel with visual back / for visual use new [Re: Don.Key]
      #4496653 - 04/04/11 08:28 PM
Check for the Baader ClickLock 2" with nosepiece 2". The nosepiece can be disambled.
Check for T2 eyepiece holders.
Arbacia
Reged: 04/18/07
Loc: Madrid, Spain
Re: 2" Filter Wheel with visual back / for visual use new [Re: Arbacia]
      #4496665 - 04/04/11 08:37 PM
from
http://www.alpineastro.com/eyepiece_adapters/eyepiece_adapters.htm
For use with all of the Baader Astro T-2 components, the T2-28a Expanding Ring is used to convert the 2" threading of the 2" Clicklock Holder (CLSC-2) or T2-17 holder into internal T-2 threads. It's ultra-low profile takes up only 1mm of length.
dyslexic nam
Reged: 01/28/08
Loc: PEI, Canada
      #4496691 - 04/04/11 08:54 PM
This is the 2" ep holder I use with mine:
http://agenaastro.com/blue-fireball-2-eyepiece-t2-female-thread-adapter-visual-back.html
I installed a Moonlite (low profile) focuser as well to give me enough in-focus on my 8" f6. The filter wheel needs a fair bit of extra travel, so you have to be sure your scope has the right amount to accomodate the extra length.
dyslexic nam
Reged: 01/28/08
Loc: PEI, Canada
Re: 2" Filter Wheel with visual back / for visual use new [Re: dyslexic nam]
      #4496699 - 04/04/11 08:57 PM Attachment (117 downloads)
Pic:
Don.Key
Reged: 10/14/10
Loc: Alps
      #4510613 - 04/11/11 08:56 AM
Thanks for advises, that is exactly what I needed.
But, as dyslexic has mentioned I will most probably hit a focus issue We will see, part is ordered.
Cheers
dyslexic nam
Reged: 01/28/08
Loc: PEI, Canada
      #4511149 - 04/11/11 12:57 PM
If it turns out that you do have focus issues, one possible strategy is to use a barlow lens to move the point-of-focus out further from the scope. A barlow extends the light path outward, so it would eliminate the need for some additional focus travel. I don't know if it would be enough to accomodate the filter wheel in your particular set up, but it is one strategy that might allow you to bring some ep's to focus with a filter wheel.
You can either use the whole barlow or, depending on the barlow, you can just thread the front lens element into the filter wheel. On the Orion 2" filter wheel, the nosepiece (on the telescope-side) screws into the main filter wheel piece using standard M48 filter threads. This is also the threading used in the lens element of the 2" GSO 2x ED barlow (other barlows may use it as well, but I know the GSO oes for sure). This means that you can screw the barlow lens element directly into the filter wheel in place of the nosepiece. This reduces the distance between the lens element and the eyepiece that you insert into the ep holder you just ordered, which keeps the magnification increase more reasonable.
There is some discussion of this here.
tonyt
Reged: 09/02/09
Loc: Australia
      #4639395 - 06/14/11 09:51 PM Attachment (458 downloads)
While searching for info on the filter wheel for visual use I didn't find much but I did find this thread, so I'll add another option to the list. The wheel can be joined to a WO diagonal using Baader part # T2-29.
Edited by tonyt (06/14/11 09:53 PM)
gnowellsct
Reged: 06/24/09
Re: 2" Filter Wheel with visual back / for visual use new [Re: tonyt]
      #4639620 - 06/15/11 12:48 AM
well it is certainly a laudable way to stimulate the economy. And I see thatthe Orionfilter wheel is made in Portugal, which very much needs the boost. So I say let everyone get a filter wheel.
Greg N
tonyt
Reged: 09/02/09
Loc: Australia
Re: 2" Filter Wheel with visual back / for visual use new [Re: gnowellsct]
      #4639654 - 06/15/11 01:43 AM
It is a bit pricey but I think I'll get a lot of use out of the wheel - makes it so easy to use the filters and keep them protected. Having to change them over in the dark is quite a disincentive.
The setup above only has a 38mm clear aperture (due to T2 components) but I have adapters on the way from Germany which should allow me to connect the wheel to a GSO diagonal giving 46mm CA.
- Tony
dyslexic nam
Reged: 01/28/08
Loc: PEI, Canada
      #4639837 - 06/15/11 07:50 AM
I got sick of trying to change filters in the dark, accidentally touching the glass while handling, and occasionally dropping a filter in the grass. Now that I have a FW set-up that works, it is way less hassle and I find myself enjoying my filters a lot more.
I am really looking forward to the next Mars opposition when I can do some quick A-B-C filter comparisons.
Fred1
Reged: 09/19/07
Loc: Somewhere in the Orion Spur
      #4641217 - 06/15/11 11:19 PM Attachment (61 downloads)
And you can piggy-back them, too.
tonyt
Reged: 09/02/09
Loc: Australia
Re: 2" Filter Wheel with visual back / for visual use new [Re: Fred1]
      #4641315 - 06/16/11 12:24 AM
The people at Orion are going to have to start giving us commission if this catches on Fred, and you'll get double
What do you do with the dual filter wheels?
- Tony
chuen
Reged: 10/13/06
Loc: England
      #4641571 - 06/16/11 07:54 AM
Denkmeier and Earthwin make filter switches, where you can have 2 filters, and slide them in and out of the light path. Not sure if they sell them separate to diagonals/binos though. I bought one attached to a diagonal, and found I used my filters a lot more.
UmaDog
Reged: 09/15/10
Loc: Long Island, NY
Re: 2" Filter Wheel with visual back / for visual use new [Re: chuen]
      #4641586 - 06/16/11 08:06 AM
For a Newt, a common solution is to place the filters before the focuser: http://www.astrocrumb.com/
Arbacia
Reged: 04/18/07
Loc: Madrid, Spain
Re: 2" Filter Wheel with visual back / for visual use new [Re: UmaDog]
      #4641674 - 06/16/11 09:11 AM
Video:
http://www.youtube.com/watch?v=__emqwuFe28
To reach focus I have had to saw off 3 cm from the lower edge of the upper cage. (the video is previous to cutting the edge). Also I have turn the upper cage at the shame position that the focuser is in LB12" and 10". In the LB 16" it is just above the fulcrum (pivot), so the focuser tube is Always horizontal and for low elevation objects I had to sit very low.
The body of Baader steeltrack focuser can be put instead of the original focuser in the origigal base plat. A couple of headless allen screws keep the fosuser in place. This is a lower profile focuser than the original.
The filter wheel is for four 2" filters. I will use NPB, OIII, H beta and an empty space for unfiltering vision. In the nosepiece I can put the 2" variable Polarizer or neutral filters I have. The filter wheel comes with 2" (M48mm) filter screw plus T T adapters. For the eyepiece holder I order a Baader click-lock 2" clamp (model for C8-C9.25 + SCT srew-T screw adapter). Temporally, I am using a SCT Meade visualback +SCT srew-T screw adapter.
I want to share this filter wheel with my C11, in which I use also Click-lock clamps (visual back + diagonal)
Patricio
tonyt
Reged: 09/02/09
Loc: Australia
      #4645083 - 06/18/11 12:12 AM
I'm posting a response here I made to a PM should others find the info useful:
some more details here: http://www.iceinspace.com.au/forum/showthread.php?t=76917
I use a nosepiece on the front of the filter wheel since I have a feathertouch crayford focuser on the C11. There are all sorts of adapters from Baader and Telescope Service (in Germany) but the SCT adapter sold by WO for their diagonal would let you connect the filter wheel directly to your 9.25; note that the M48 threads are not a perfect match between the WO gear and the Orion filter wheel but they are secure enough IMO.
The clear aperture of the WO diagonal/filter wheel setup is 38mm but I think that's the same as the C9.25 so no problem there. I intend to mate the wheel with a GSO diagonal giving 46mm clear aperture since I want to use it with a 41mm Panoptic.
The Eathwin setup also looks like a good option though you can only mount 2 filters rather than three in the filter wheel (in addition to one left empty) and you have to pay extra to get the dielectric mirror. I think the Earthwin is 40mm clear aperture which is not a problem for you but is a restriction in the C11 when using an eyepiece with a 46mm field stop.
Hope that helps and feel free to ask any more questions.
- Tony
Lane
Reged: 11/19/07
Loc: Frisco, Texas
      #4646741 - 06/18/11 11:10 PM
Hey, this what I was looking for last year. I finally bought the Lumicon slider when I could not figure out how to adapt the Orion 2" filter wheel to my C11 for visual use.
I would like to connect the filter wheel directly to the back of my C11 and then have a 2" nose piece sticking out for me to insert my regular diagonal. Is that possible or not? There is no way I can turn the filter wheel all the way around because of the feather touch focuser that sticks out a lot, but I need to be able to rotate the diagonal easily.
tonyt
Reged: 09/02/09
Loc: Australia
Re: 2" Filter Wheel with visual back / for visual use new [Re: Lane]
      #4646882 - 06/19/11 01:37 AM
In order to preserve clear aperture the best way I can see to connect the wheel to the C11 rear cell is to use the Astro-Physics part# ADASCTLC which adapts from the 3.25" rear cell to 2" accessories.
From there you could connect a Baader clicklock eyepiece holder to the M48 threads in the filter wheel body using the apropriate adapter - I'm not sure which adapter but I'll be able to tell you next week if you're interested as I have some new parts arriving (including clicklock eyepiece holder).
If you only needed the 38mm CA of the T2 threads there are simpler options.
Lane
Reged: 11/19/07
Loc: Frisco, Texas
      #4646893 - 06/19/11 01:45 AM
I am definitely interested, put up a pic if you can, as soon as you get it all assembled.
The main concern I have is that there is no room to tighten the filterwheel onto the scope due to that big feather touch focuser, it sticks out like 3 inches.
13 registered and 28 anonymous users are browsing this forum.
Moderator:  zjc26138, tecmage, rflinn68
