Andrew Greenwood
Reged: 03/14/08
Loc: Cheshire, UK
AstroTrac TH3010 fluid head ... new
      #4504901 - 04/08/11 12:07 PM
Hello everyone
I have been looking at a secondhand AstroTrac TH3010 fluid head. I have noticed that when the azimuth locking bolt is unlocked, the whole upper part of the TH3010 lifts off the base. Is this normal? It gave me a little fright because I wondered how safe it would be. I also noticed when locking the bolt again the upper unit 'pulls down' as the tension is increased. If you have a target framed, this will affect its position. I used to have a Mini Giro head, which even when unlocked in azimuth, the unit did not separate.
Any help or advice would be appreciated!
PGW Steve
Reged: 10/03/06
Loc: Winnipeg, Canada
Re: AstroTrac TH3010 fluid head ... [Re: Andrew Greenwood]
      #4510003 - 04/10/11 10:09 PM
I noticed that with mine also. I think they should have put a groove in the male part for the screw to go into, that way when you loosen it off, it is still captive. Same deal as the groove in a TV eyepiece.
30 registered and 52 anonymous users are browsing this forum.
