Privacy Policy | Please read our Terms of Service | Signup and Troubleshooting FAQ | Problems? PM a Red or a Green GuÖ uh, User
Starhawk
Space Ranger
Reged: 09/16/08
Loc: Tucson, Arizona
Taking up Slop in CGEM DEC axis
      #4521999 - 04/16/11 12:10 PM
I have a new CGEM which has worked well, but has a small amount of slop in the DEC axis. A small amount of force on the DEC axis will cause it to move a short distance before it touches down on the drive in thd other direction. In the past, I have seen this on Vixen mounts, ANC it was very easy to adjust the worm shaft stop to take it out. But it is far from obvious where to get to that on a CGEM.
Anyone had this?
-Rich
BlueGrass
Reged: 07/25/09
Loc: Wasatch Front, UT
Re: Taking up Slop in CGEM DEC axis new [Re: Starhawk]
      #4522032 - 04/16/11 12:27 PM
Rich,
There are a few posts here about adjusting the CGEM but Ed Thomas has put together some new videos on servicing and adjusting the CGEM. I think he's at NEAF but I'd suggest contacting him and see what he can do for you. The adjustment is not difficult but watching someone actually do it is worth a thousand words ...
RTLR 12
Reged: 12/04/08
Re: Taking up Slop in CGEM DEC axis new [Re: BlueGrass]
      #4522078 - 04/16/11 01:03 PM
Ed has this posted on the Yahoo Celestron CGEM site...
Adjusting the worm gear spacing on the Atlas/EQ6/CGEM and similar mounts.
Before you start adjusting things, make sure that the worm gear is not loose in the housing. Do
this by removing the caps from the worm gear housings on the control panel side of the mount.
Tapping around the edge of the metal caps with the hard plastic end of a screw driver will often
make these caps much easier to remove. Once removed, place your finger on the end of the
worm gear shaft and try to move the axis back and forth. The worm gear should not move in and
out when you do this. If it does, then the worm gear will need to be tightened before making any
other adjustments. This is best done with the worm gear housing removed from the mount which
I will not get into here.
To adjust the worm gear spacing you will want to have the RA balanced. You can do this with
as little or as much weight on the mount as you want. If the mount is unloaded, you donít need
to balance the DEC. If it is loaded, then you need to balance the DEC as well.
Assuming the worm gear is tight, loosen up the four 5mm allen head bolts that hold the worm
gear housing on and then snug them down just to the point that they start to tighten. The housing
needs to be able to slide while not moving up and down. Turn the mount on and set the slew
speed to 9. There are two small 2mm allen socket adjustment screws, one on the top of the
worm housing and one on the bottom. The one on the bottom pushes the worm gear and ring
gear apart while the one on the top pulls them together. If your axis is too loose so that you have
a lot of backlash, then back the bottom screw out a little and run the top set screw in while you
are slewing the mount. As soon as the gears bind, stop the slew and back the set screw out a
fraction of a turn. Then start slewing again and if the gears are still bound then run the bottom
screw in a bit. You need to do this until the gears are close to binding, but not quite there. You
will notice as you do this, the play in the axis will lessen and probably not be noticeable. There
are occasionally slight defects in the worm and ring gear or the spur gears that will keep you
from getting the gears too close, but that is not usually a problem. The adjustment will have to
be made to these high spots if they are present in your gear set and may leave some noticeable
backlash. Once you are done adjusting the set screws, tighten down the four allen head bolts. I
usually do this while the mount is slewing as well because sometimes it can start binding again
when you tighten these down. If that happens, you need to back the worm off a bit. Again,
backing the worm off is done with the bottom set screw. You will want to slew the axis in both
directions all the way around (if your mount allows) to ensure that there are no high spots that
will cause binding. You must be more careful making these adjustments with the CGEM that
uses servo motors than the Atlas/EQ6 with steppers. The stepper motors can handle some
binding with no damage while the servo motors can be damaged if run too long with the gears
bound up.
Be aware that the tighter the gear mesh, the noisier the mount is likely to be (some Atlas mounts
sound like sewing machines). You can loosen up the worm gear mesh and adjust the spur gear
mesh (which I wonít get into here) to lower the noise level but you do so at the expense of slop
in the axis and increased backlash. Also, it is generally a good idea to be more careful with
balance once you have the gears tightened up so that you put less stress on the gears.
Ed Thomas
Deep Space Products
www.deepspaceproducts.com
23 registered and 33 anonymous users are browsing this forum.
