Astrojensen
Reged: 10/05/08
Loc: Bornholm, Denmark
M81 widefield new
      #4530874 - 04/20/11 05:40 AM
Hello folks!
Last evening I had less than an hour between the end of astronomical twilight and moonrise. I had the C8 out to cool, for a later look at Saturn, but before moonrise, it was deep-sky time. I wanted to test my WO 72mm f/6 Megrez apo with Baader Maxbright binoviewer on some deep-sky objects. After quick looks at M51/NGC 5195, I aimed the scope at M81/82. The 72mm and Baader Maxbright with 1.25x corrector and 25mm Kellners give 21x power and a field just shy of 2.5 degrees, well into binocular territory.
The view was incredibly nice. M81 appeared twice its usual size and M82 was a tiny, bright streak. It clearly showed the dust band and the two bright clumps, despite the low power. To my delight, I could also hold not only NGC 3077, but also NGC 2976 in the field together with M81/82 at once. It was a stunning sight. The image is mirror-reversed.
The sketch is made by printing a chart from Cartes du Ciel in negative and sketch the galaxies on it, then scan the drawing and convert it to a positive in MS Paint. I think it came out rather well, even if the stars look too large for my taste. The reason for this technique is that I didn't have enough time at the eyepiece before moonrise to sketch the literally hundreds of stars that littered the field. I took notes on the galaxies only and even here I didn't have enough time. It sure was a quick way to make a sketch, though. I may use this a lot more. I have an idea of drawing all the Messiers with a small scope, so I need the help I can get.
Clear skies!
Thomas, Denmark
Asbytec
Guy in a furry hat
Reged: 08/08/07
Loc: La Union, PI
Re: M81 widefield new [Re: Astrojensen]
      #4530984 - 04/20/11 07:52 AM
Envy is a sin and I am a sinner. Nice, Thomas...just nice.
Rutilus
Reged: 12/17/10
Re: M81 widefield new [Re: Asbytec]
      #4531159 - 04/20/11 09:48 AM
Yet again Thomas I take my hat off to you, for not only a wonderful sketch, but also a superb observation indeed.
With my 20x60 binoculars I can pick-up M81/82, but I will have to give them a go with my 20x100mm giant binoculars.
These were two galaxies that were on my regular supernovae hunting list, many years ago. I remember seeing my first supernovae in M81, a really bright one of the ninth magnitude, that I observed with a 4 inch refractor.
Jef De Wit
Reged: 03/06/09
Loc: Hove, Belgium
      #4531439 - 04/20/11 12:07 PM
Why not? Good idea when you have not enough time or you want to spent more time on the DSO than sketching all those stars!
blb
Reged: 11/25/05
Loc: Piedmont NC
Re: M81 widefield new [Re: Jef De Wit]
      #4531466 - 04/20/11 12:17 PM
Wow Thomas, in all the times that I have looked at M81 & M82, I have never seen NGC 2976 and NGC 3077. The sketch of all four galaxies in one field of view is great. I leave out so many stars in my sketches when the field is so full of them. I only show the brighter stars so using your technique gives a much more realistic view. GOOD JOB! Well done.
Reged: 10/05/09
      #4531576 - 04/20/11 01:05 PM
Thomas,
Very nice sketch of M-81 .
JakeSaloranta
Reged: 09/18/08
Loc: Finlandia
      #4531611 - 04/20/11 01:15 PM
Or simply draw some of the brightest stars in the field. Objects such as open clusters can get quite easily lost in a rich field if you sketch ALL the stars you can see. Also it takes far too long - at least for me when you got like 30-40 clear nights a year.
/Jake
JayinUTModerator
I'm not Sleepy
Reged: 09/19/08
Loc: Utah
Re: M81 widefield new [Re: JakeSaloranta]
      #4531795 - 04/20/11 02:23 PM
Thomas,
An excellent capture of there four galaxies.
Mentor
Reged: 09/30/10
Loc: Ontario, Canada
Re: M81 widefield new [Re: JayinUT]
      #4532366 - 04/20/11 06:13 PM
I really like views of multiple DSOs in a single field. It adds a depth to the image that an isolated object is somehow missing. Your rich portrayal of the field stars only adds to this depth.
Very nice work!
Reged: 06/13/06
Loc: Illinois
Re: M81 widefield new [Re: Mentor]
      #4532729 - 04/20/11 08:44 PM
Thomas,
Wide views of deep sky targets are just great. This sketch looks very nice indeed.
Frank
CarlosEH
Reged: 01/19/05
Loc: Pembroke Pines, Broward County...
Re: M81 widefield [Re: frank5817]
      #4533368 - 04/21/11 02:52 AM
Thomas,
An excellent wide field view of M81/82, NGC 2976, and NGC 3077. Your refractor did a very nice job capturing all of these objects. Thank you for sharing it with us all.
Carlos
2 registered and 13 anonymous users are browsing this forum.
Moderator:  cildarith, JayinUT, WOBentley
