Mike Holland
Reged: 12/22/06
GM-8 and TMB 130 SS new
      #4535558 - 04/21/11 10:53 PM
For anyone is using this combination, how much counterweight do you use to balance the tube? It seems like the standard weight would be too little. Thanks!
BRCoz
Reged: 10/21/05
Loc: Moreno Valley, CA
Re: GM-8 and TMB 130 SS new [Re: Mike Holland]
      #4535621 - 04/21/11 11:43 PM
I have the APM/TMB 130/1200, I added an 11 lb weight. The scope is 15 lbs. I am not sure what the SS is.
Mike Holland
Reged: 12/22/06
Re: GM-8 and TMB 130 SS new [Re: BRCoz]
      #4535897 - 04/22/11 05:40 AM
It is listed as 18.5 pounds, and the rings are another 3 pounds. Add in a finder, and I think that 22 pounds is a good number.
I'd just get 22 pounds in counterweight, but with the weights sitting at the end of a shaft and the scope closer in I know that it doesn't have to be 1:1. Thanks!
drksky
Reged: 09/01/09
Loc: Bloomington, IL
      #4535942 - 04/22/11 06:56 AM
I was using mine on a CGEM with one 23lb CW about halfway down the shaft. The 21lbs losmandy weight should be enough as long as you don't any heavy accessories.
Mike Holland
Reged: 12/22/06
Re: GM-8 and TMB 130 SS [Re: drksky]
      #4536965 - 04/22/11 04:20 PM
Ok, thanks!
28 registered and 31 anonymous users are browsing this forum.
